Old 03-17-2016, 01:08 PM   #1
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
RPMs not dropping to set point on start
Quick question:
I have an auto and in the past when i cold start it, the RPM would drop to about 800 shortly after start.
In the last 3 months on cold start, the RPMs have not been dropping down to that point for me thou...
What i mean is that i start the car, the RPM would be around 1.6k for the warm up period, then it would drop to 1.1k and stay there.
If i warm start the car after this, the sequence would start at about 1.6k and then go down to the usual 800rpm.
Has anyone experienced this?
nos145 is offline   Reply With Quote
Old 03-17-2016, 01:20 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by nos145 View Post
Quick question:
RPM's stay higher when its colder outside and drop once the car reaches a set temperature
/thread
MisterSheep (03-17-2016)
Old 03-17-2016, 01:24 PM   #3
nos145
Cognite
nos145's Avatar
/thread
Car stored in a 17C garage
lets open the thread up again
Old 03-17-2016, 01:27 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
thats still cold enough to do the cold idle thing for a while
Old 03-17-2016, 01:30 PM   #5
nos145
Cognite
nos145's Avatar
Does your do it?
you start it, it revs up, then it warms up and goes down to 1.1k and just stays there. it doesnt go down to the 800 mark (even if you let it sit for 5 minutes)?
Old 03-17-2016, 01:33 PM   #6
mixtape
Posts in the nude
mixtape's Avatar
Drives: 2016 WRB BRZ
Does your do it?
For five minutes that certainly seems like a high idle. Mine sits at the 650-700 mark after warming up in sub-40-Farenheit weather.
What oil are you running?
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography
"Lesbian trees have no wood." - Scoobs McGee
mixtape is offline   Reply With Quote
The Following User Says Thank You to mixtape For This Useful Post:
nos145 (03-17-2016)
Old 03-17-2016, 01:33 PM   #7
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
It's normalish. How long does it take your coolant to get up to temperature?
jawn is offline   Reply With Quote
The Following 5 Users Say Thank You to jawn For This Useful Post:
FRSBRZGT86FAN (03-20-2016), go_a_way1 (03-17-2016), mixtape (03-17-2016), nos145 (03-17-2016), Tectoniic (03-17-2016)
Old 03-17-2016, 01:41 PM   #8
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Does your do it?
Mine is tuned to reduce the high idle a little but it does sit there for about 5 minutes before it drops to the 800 mark in ~10C I also have an oilcooler so I dont think mine is a good comparison haha!
nos145 (03-17-2016)
Old 03-17-2016, 01:51 PM   #9
Does your do it?
Mine does. During the colder weather it won't drop to 800 until after I drive it a bit. It will drop from high (1600 or so) to mid (1000 or so) and stay there for as long as I just let it idle. If I put it in gear once warmed and move it just 2 feet it will drop to low/regular idle. It will change once it gets warmer don't worry.
86kahl (03-17-2016), go_a_way1 (03-17-2016), nos145 (03-17-2016)
Old 03-17-2016, 02:00 PM   #10
nos145
Cognite
nos145's Avatar
k. I was wondering whether this was a common issue or not. I will be getting a wifi obd2 dongle next week to check for temps etc.
was worried as this did not happen in the 3 years that I had the car for, so i'm thinking they sneaked it into one of the firmware updates they pushed a while back.
thank you very much for the feedback
The Following User Says Thank You to nos145 For This Useful Post:
Old 03-17-2016, 02:05 PM   #11
mixtape
Posts in the nude
mixtape's Avatar
I actually just bought a WiFi/Bluetooth Samsung Galaxy 4 Tab tablet and a Bluetooth OBDII scanner yesterday - it's very useful for monitoring stuff like this.
Old 03-17-2016, 03:19 PM   #12
Icecreamtruk
Drives: Track preped NA FRS
Just for more info on it, with an oil cooler (air cooler) and a koyo radiator and at around 30F if my car is already warm up it will sit at around 700-800. But if I just let it iddle at that temperature after driving it a bit, the oil and coolant cool down quick enough to make the engine bump the iddle to 1100 rpms and it stays there until I drive it, no matter how long I let it idle, it is not enough to heat up the car. I doubt your problem is the same (unless you also have a bigger rad and an oil cooler) but you do have an automatic car so maybe it takes longer to warm up? In anyway, it is totally related to outside temperature and not abnormal at all.
Icecreamtruk is offline   Reply With Quote
Old 03-17-2016, 03:20 PM   #13
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
This is definitely normal and is due to it being colder.. just as @go_a_way1 said
Instagram: trevor.parque
Why does my Advance Multiplier keep dropping? jeebus Software Tuning 103 10-17-2016 05:29 PM
Dropping boost at high RPM? Help xkalelx Forced Induction 40 01-25-2016 08:09 PM
Adv Multiplier Dropping from 1 to .7-.88 mcbrawr Software Tuning 16 07-01-2015 03:29 AM
dropping engine and tranny paulchang Engine, Exhaust, Transmission 1 03-05-2015 11:23 PM
RPMs reving and dropping when steering wheel is turned Bach415 Issues | Warranty | Recalls / TSB 24 03-05-2014 05:41 PM
