Old 06-29-2015, 04:34 PM   #1
mcbrawr
Drives: 2014 BRZ Limited
Adv Multiplier Dropping from 1 to .7-.88
Currently running OFT stg 1 93oct in MD with 93oct fuel. Just a catback installed and will be switching to stage 2 with the OFH this week or next.
I'm a complete newcomer to tuning. That being said I'm reading a lot about how it works and I've seen in a few threads to pull timing by 0.3deg increments until the AM stays at 1.
My Question:
In RomRaider, I go to Ignition Timing - Advance -> which table? Base A, Base B, etc?
Also, how long should one wait after flashing to decide if extra tuning is needed? I flashed last night and with my AM at 1 the car felt like it had 20 more hp/tq but today feels like it did before i reflashed (all i changed was LC). Can someone walk me through how to fix this?
mcbrawr is offline   Reply With Quote
Old 06-29-2015, 04:52 PM   #2
phrosty
Wait for your LTFTs to level out. Base Timing B. If you see a consistent knock of -0.8 in a certain cell, take out half of that (0.4). Repeat until it goes away.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 06-29-2015, 05:12 PM   #3
mcbrawr
Consistent knock of -.8 meaning the flkc value consistently showing up at a certain RPM range vs engine load?
Old 06-29-2015, 05:32 PM   #4
steve99
yes if you see knock consisently at a load rpm point pull some timing from Base Timing B table.
Assuming your maf scaling and fueling AFR is ok
also try some different brand fuel some are better than others.
you can also try modding the pi/di ratio tables cold/warm/hot as per below if your seeing higher rpm knock 5000-7000, so you run full DI till 7200 instead of 5200, the lower load changes are for idle stability and takeoff from idle stability
if it below 3000 then just pull a bit of timing
Old 06-29-2015, 06:11 PM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
Have you seen anything suggesting that running 100% DI that high into the range is beneficial? I thought that there wasn't any improvement and actually running some PI helps the mixture.
Don't forget that the ECU pills timing at a minimum set value, usually -0.7 or -1.05. You can check in the map. If you see smaller retard values it's actually restoring back towards 0. Not all negative values in the log correspond to the onset of knock which is why you want to work out the nearest moment that caused the ECU to pull timing. All timing changes on the maps are in 0.35 degree multiples.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-29-2015, 06:45 PM   #6
steve99
On good fuels it makes little difference, on our fuels it appears to work quite well and on south africian fuels (95ron) those guys said they could add back in up to 2 degrees timing in some areas by going full DI
Yes i don't get concerned about anything thats not over -0.7.
see link here from moto-mike
http://www.ft86club.com/forums/showp...2&postcount=17
I agree their no direct power increase due pi/di in it but if you can add timing back in as a result it would appears it worth doing. (and your not maxing out DI as mike says unlikely on NA petrol tune. Gets close on E85 though.
Old 06-29-2015, 06:48 PM   #7
aagun
Drives: 86
what is your LTFT %?? at idle??
aagun is offline   Reply With Quote
Old 06-29-2015, 09:35 PM   #8
steve99
less than 5% usually unless IAT varies widely
or my E% changes 20% or more
http://datazap.me/u/steve99/e85-v7-l...ata=9-10-15-26
http://datazap.me/u/steve99/mt-glorious?log=0&data=1-7
Old 06-29-2015, 10:00 PM   #9
aagun
Drives: 86
i wandering about DI issues that let the ecu add LTFT
Old 06-29-2015, 10:32 PM   #10
mcbrawr
Many thanks guys. My LTFT evened out while I was driving this evening and it only took one adjustment to get it stable @ 1 again. With that said, here's another question:
If I were to add timing, is it as simple as adding .1-.5 per cell? Is there a certain pattern? Is there a location of a general guide of how to do your own custom tunes so I don't bother you guys? My background is in EE and control theory.
Old 06-29-2015, 10:39 PM   #11
JB86'd
JB86'd's Avatar
Drives: JAWS
I'm not sure where exactly you'd decide where to add timing but don't forget- just because your IAM is at 1 during street driving, doesn't mean you won't have knock during hotter days, sustained hard street driving or autox/track. My IAM was at 1 for a long time even with hard street driving, went to an autox event and my IAM dropped down to .8.
As far as pulling/adding timing, Steve99 has a lot of written guides on editing tunes and what to look for, and I also have a basic guide on changing Base Timing in Romraider.
Old 06-29-2015, 10:51 PM   #12
steve99
the minimum add/subtract is 0.35 degrees
on petrol you will generally get knock before you get to MBT (max torque) but on E85 you can often advance the timing past MBT before knock so you need to check your actually making more power .
Old 06-29-2015, 11:12 PM   #13
mcbrawr
My IAM was dropping today during the hot ass humid weather we have going on in Maryland. stayed consistent at 1 this evening... maybe need to adjust during the day in the heat?
Old 06-30-2015, 12:01 AM   #14
steve99
best to adjust knock for average intake air temps then use IAT retard tables to retard only when temps high
see here note his tables displaying the changes not the absolute values, make sure you put in the - signs in the IAT temp compensation table else it will add timing then temps hot :-)
http://www.ft86club.com/forums/showt...47#post2216047
Why does my Advance Multiplier keep dropping? jeebus Software Tuning 103 10-17-2016 05:29 PM
advance multiplier = 0 why???? agent47 Software Tuning 11 01-28-2015 11:11 PM
OFT manager v1.31 ADV Multiplier at 0 DarkestBuddha Software Tuning 7 11-07-2014 02:13 PM
Advanced Multiplier??? What is it? UrmyboyBLUE Software Tuning 8 10-13-2014 09:05 PM
Displaying the Adv Multiplier sw20kosh Software Tuning 12 12-09-2013 10:42 PM
