Old 03-14-2016, 06:16 PM   #715
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by StormTrooper View Post
I've been following this for a while and would like to see results of the cs400 when it's fully tested.
That being said does anyone know if the "tinny resonance" I noticed is unavoidable in an equal length header? (the avcs coming on around 3700 makes a cheap Honda civic eBay exhaust note) ***I had the nameless header with catted and resonated FP.
I didn't notice it in the videos but I'm pretty sure it's something mostly heard inside the car. Anyone who knows what I'm going on about please chime in.
Thanks
I don't find it too bad at all on my catted p&l. It is louder than stock though under the front of the car, probably because the stock header has a shroud. I wonder if header wrap would dampen it for you.
Sent from my SM-N920V using Tapatalk
Old 03-14-2016, 06:27 PM   #716
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Yeah idk, I had a friend who liked it. To me it sounded trashy. Mine was ceramic coated on the outside
GR86 MT premium
StormTrooper is offline   Reply With Quote
The Following User Says Thank You to StormTrooper For This Useful Post:
raven1231 (03-16-2016)
Old 03-16-2016, 07:36 AM   #717
Iwannajag
Drives: 13 FR-S whiteout / blue w2w
B type 150, but no additional power ?
So I have the B type 150 with and ACE FP and a Delicious stage 2 tune for it.
Yet on the dyno (Dynojet), we only see 6 HP improvement (169hp) over the stock header with berk track pipe and stage 1 tune on 93 octane. I still have the stock intake with KN filter. No other mods to the drivetrain
I have submitted the log and the comments were "The logs look great, engine load looks perfect, AFR looks perfect, cams look great and you're running as much timing as we see on any other NA car. "
Anyone seen anything like this ? Any thoughts on what might be causing this ?
Iwannajag is offline   Reply With Quote
The Following User Says Thank You to Iwannajag For This Useful Post:
Old 03-16-2016, 08:15 AM   #718
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Same dyno?
The Following User Says Thank You to Wayno For This Useful Post:
Old 03-16-2016, 09:18 AM   #719
raven1231
At least you didn't lose power, and it sounds great right? On another note as stated above was it the same dyno and under similar conditions?
Old 03-16-2016, 10:43 AM   #720
Kodename47
Kodename47's Avatar
Drives: UK GT86
How about the torque curve rather than peak numbers?
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-16-2016, 10:52 AM   #721
twag4
Drives: frs
Sounds like just a normal equal length tune. The ace isn't a normal equal length header.
twag4 is offline   Reply With Quote
The Following User Says Thank You to twag4 For This Useful Post:
kuno (03-17-2016)
Old 03-16-2016, 11:22 AM   #722
churchx
churchx's Avatar
Drives: 2014 GT86
twag4: But IIRC Delicious had developed specific OTS tune for Ace and as they are mentioned as tuning shop, they should have known if right or not one was used?
raven1231 (03-17-2016)
Old 03-16-2016, 02:49 PM   #723
CSG Mike
CSG Mike's Avatar
Are you using a Delicious Stage 2 tune, or the Ace tune?
There is an Ace specific tune, even from Delicious.
Old 03-16-2016, 08:16 PM   #724
Iwannajag
It is the Ace specific tune.
Old 03-16-2016, 08:28 PM   #725
Iwannajag
Yes, same day even.
Did 7 different configs. 5 done on a dynocom and 2 on a dyno jet to make sure the dyno was not off
Stock header stock tune.
Stock header Spec86 tune (developed for Tomei EL)
Stock header Ace Stg2 tune
ACE header Spec86 tune
ACE header DT ACE stg2 tune
They were all done on a dynocom. Then redid this on a Dynojet to make sure that this was not a dyno issue. None of them showed any significant HP or Torque gain over the stock header with the stock tune. (6-12hp). They were all done on the same day at the same place
Dynocom
OEM header cat removed Berk front pipe (2015 T4)
Stock Tune 165.6hp
Spec86 Tune 171.0hp
Delicous Stage1 Tune 172.2hp
Ace Header + Ace front pipe (T4 + Spec86)
Spec86 Tune 177.9hp
Delicous Ace Stg2 tune 178.3hp
Dynojet 2 days later
Ace header and FP only
Spec86 Tune 169.1
Delicous Ace Stg2 tune 169.2
Old 03-16-2016, 08:31 PM   #726
Iwannajag
The results were validated by DT. So far we are both puzzled. Not blaming them, just wondering if any thing in the car of set up could affect the output. The same tune was send to others and they saw significant more HP.
Old 03-16-2016, 08:41 PM   #727
Iwannajag
Torque curve, is uninspiring as well.
However the 150 is supposed to focus on peak hp and give up some torque, hence i did not focus on it
Something is just really really odd. We were expecting 195-200 HP
Old 03-16-2016, 09:00 PM   #728
CSG Mike
CSG Mike's Avatar
Yes, same day even.
Dynocom
Stock Tune 165.6hp
Spec86 Tune 171.0hp
Spec86 Tune 177.9hp
Spec86 Tune 169.1
Can you give me a breakdown of everything on your car? How many miles are on your car, and what kind of transmission?
That's super low; you should be making way more power.
KRC 9 (06-13-2017)
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
