Old 03-07-2016, 09:14 PM   #701
PA-86
PA-86's Avatar
Drives: Scion FR-S Ultramarine, Triumph STR
Originally Posted by DocWalt View Post
@PA-86 checked his today and he's not touching and he never flattened anything on the skid plate. Maybe he can post up some pics
PA-86 is offline   Reply With Quote
Old 03-07-2016, 10:05 PM   #702
veck
veck's Avatar
Drives: 2014 Subaru BRZ
Originally Posted by tracerit View Post
Is there someone here named "Calvin I." or "Kevin I."? Fedex just tried to deliver me another header lol. I bought one and got it last week but my mom just called and said Fedex tried to deliver it to me so I'm guessing Ace Header put my address under that guy's order? I rejected the delivery so @AceHeader-MT you might want to check with Fedex who's going to be holding it at their location.
This is me. I received it last week. Lol. Now I know where you live! I thought it was just a glitch on the fedex site until the product reached LA but I'm from Norcal. Thanks!
Sent from my SAMSUNG-SM-N910A using Tapatalk
veck is offline   Reply With Quote
Old 03-09-2016, 11:47 PM   #703
twag4
Drives: frs
The numbered badge on my type A header is gone! Pulled the aluminum tray today while changing he oil, and everything looked good- BUT MY NUMBERED BADGE IS GONE OFF OF MY HEADER!!
Nothing has hit it, broken it, or anything. I guess the swelling and shrinking with heat is real. &@#%€¥!!!
Physics.
twag4 is offline   Reply With Quote
Old 03-10-2016, 07:31 AM   #704
veck
veck's Avatar
Physics.
You always have your keychain so you're all good.
Old 03-10-2016, 03:02 PM   #705
twag4
Drives: frs
Yeah but it's not the same. Plus, it now has four broken welds. It is still a great header, I'm just sad that it is long gone.
Old 03-10-2016, 05:13 PM   #706
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Hmm.. I thought you guys would know.. I need a quick "number" for a possible header, intake, tune on e85 for our cars. Can even be the Ace header that does 199 whp on 91. how much could someone see with that 199whp number and then adding E85 into the mix?
Instagram: trevor.parque
Old 03-10-2016, 06:19 PM   #707
CSG Mike
CSG Mike's Avatar
If you read the rest of the review, there are ethanol numbers as well.
Old 03-11-2016, 10:33 AM   #708
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
I just got mine from CSG.
First in France I guess (type B 350)
Just need that Ecutek/Delicious, and time to go on track
MaximeT is offline   Reply With Quote
Old 03-11-2016, 09:40 PM   #709
Traktor
Drives: Subaru BRZ Limited
Ace 4-2-1 Header
I installed my header two weekends ago and have experienced some rubbing. There was some minor contact on the skid plate which I flattened out, but the rubbing noise remains. I removed the skid plate last night to rule it out as the source, but am still hearing rubbing.
I was really hoping it wouldn't rub as this is a daily drive for me.
Type B 250 with only 800 miles.
Traktor is offline   Reply With Quote
Old 03-13-2016, 01:32 PM   #710
kch
Senior Misanthrope
kch's Avatar
Probably the OP rubbing on the subframe. Loosen everything up and see if you can move it away from the subframe before re-tightening it. If that doesn't help, you may need stiffer engine mounts.
Old 03-14-2016, 06:33 AM   #711
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
I've been following this for a while and would like to see results of the cs400 when it's fully tested.
That being said does anyone know if the "tinny resonance" I noticed is unavoidable in an equal length header? (the avcs coming on around 3700 makes a cheap Honda civic eBay exhaust note) ***I had the nameless header with catted and resonated FP.
I didn't notice it in the videos but I'm pretty sure it's something mostly heard inside the car. Anyone who knows what I'm going on about please chime in.
Thanks
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 03-14-2016, 04:19 PM   #712
CSG Mike
CSG Mike's Avatar
Thanks
Theoretically yes, by just making a really, really heavy header to damp the sound.
Old 03-14-2016, 04:33 PM   #713
StormTrooper
Hmmm not sure if I want to do that again.... Sold the car due to having a kid sooner than expected. Plan on buying one this coming winter when prices drop.
Guess I'll look into UEL. Sound is part of the pleasure. I don't live close to a track so the cars only purpose will be driving enjoyment.
GR86 MT premium
Old 03-14-2016, 05:23 PM   #714
CSG Mike
CSG Mike's Avatar
The UELs exhibit this less, as a whole, because they're cast headers which are thicker and heavier. Also, the UEL rumble is loud enough to mask many noises.
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
