Old 03-15-2016, 05:02 PM   #225
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
It's usually 4th on these cars since that's the 1:1 gear.
Well then......learned something new lol I'll tell him to run 4th gear next time I hop on. Thanks, but yeah lol I hope everyone finds this heart breaker dyno useful.
Alltezza is offline   Reply With Quote
The Following 2 Users Say Thank You to Alltezza For This Useful Post:
jawn (03-15-2016), Teseo (03-15-2016)
Old 03-15-2016, 05:54 PM   #226
Teseo
Drives: frs
Not bad for just bolts on, for an NA i'd satisfied
Old 03-15-2016, 09:26 PM   #227
nunonuna
nunonuna's Avatar
What part in TN are you in?
Also, where did you do dyno pull?
nunonuna is offline   Reply With Quote
Old 03-15-2016, 10:22 PM   #228
Alltezza
Alltezza's Avatar
Middle Tennessee, apparently our elevation is >600
http://www.whatismyelevation.com/##
I went to Gage Performance since they're literally like 5 minutes from my house.
http://www.gageperformance.com/
If you live out in the Lebanon area there's redstar performance they have a Mustang dyno there I was told Dyno Dynamics and Mustang Dyno read VERY close and are both known as "heartbreakers"
http://www.performancetuningschool.com/
Old 05-22-2016, 06:07 PM   #229
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Did anyone get installation instructions with theirs? I know I can do it on my own with a DIY guide but I'm a sucker for actual manufacturer instructions because I'm super anal about making every install perfect.
I mainly ask because I got more attachment hardware than I was expecting.
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
Old 05-22-2016, 08:03 PM   #230
ryoma
ryoma's Avatar
no instructions with the box. I didn't use all the hardware supplied with mine. it's nice they gave you a lot of bolts and nuts and stuff though. I recently lost one (connected overpipe to front pipe) at the track (guess it wiggled loose) and the bag had plenty of replacements
The Following User Says Thank You to ryoma For This Useful Post:
Keenercarguy (05-23-2016)
Old 05-24-2016, 08:05 PM   #231
adrixe
adrixe's Avatar
Drives: 2014 Subaru BRZ
One question on everyone, just installed mine. And there's one bolt that I had a hard time to tighten. Its the bolt that is closest to the oil pan. Its a tight space and I feel that it will come loose in the near future. What tool did you guys use to get into the tight space?
Sent from my SM-N900W8 using Tapatalk
adrixe is offline   Reply With Quote
Old 05-24-2016, 08:47 PM   #232
ryoma
ryoma's Avatar
some people have used a u-joint or a crows foot. I used a 14mm deep socket with an extender, though I was very careful with the deep socket since it would not sit completely flat. I used a 6 inch extender with the deep socket to clear the header pipes.
though, I need to find time to get under my car and check all the bolts/nuts since after a track day, it sounds like I have an exhaust leak somewhere.
Old 06-17-2016, 02:33 PM   #233
Marx
Marx's Avatar
Drives: '13 Lava FR-S 6MT
Alright! I pulled the trigger on one of these and an OFT, I can't wait to hear all of the rumbles. I've got a heat-related question - I ordered the oil pan heatshield, should I wrap the header as well or will that keep things cool enough in a Colorado summer?
Marx is offline   Reply With Quote
Old 06-17-2016, 11:53 PM   #234
brzd
brzd's Avatar
Drives: Firestorm FRS
Just installed & flashed to stage 2! It's great! A lot quieter than I expected on the stock exhaust. Maybe after driving with an N1 my ears have been damaged LOL
Anyways I have that ticking/hissing/puttering noise under load that other owners have claimed as well. Did it eventually go away?
brzd is offline   Reply With Quote
Old 06-18-2016, 01:19 AM   #235
coxxoc
I used a standard size socket, a universal joint, an extension, and a torque wrench. The normal socket wasn't deep enough to let the universal joint insert fully. If I tried a deep socket, it wouldn't fit because it was too long. I just made sure to line things up carefully so that the universal joint wouldn't come out of the socket and torqued the nut to 22 ft/lbs.
coxxoc is offline   Reply With Quote
Old 06-18-2016, 02:08 AM   #236
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
should be good to go, but a wrap will help keep additional heat out!
Might wanna do it before you install it lol...laziness kicks in
Old 06-19-2016, 11:43 AM   #237
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
I got my headers ceramic coated to keep the heat from getting into the engine bay, and to protect it from salt NJ uses on the roads during winter.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 06-19-2016, 03:15 PM   #238
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
who's still carrying these headers? They seem to have vanished from a lot of the bigger stores on here.
XanRules is offline   Reply With Quote
gruppe, gruppes, header, uel, unequal length
DIY X REVIEW: CNT UEL HEADER INSTALL adamg Engine, Exhaust, Transmission 73 07-27-2023 09:58 AM
P&L Header install, review and impressions D K Engine, Exhaust, Transmission 54 05-30-2019 12:35 AM
Top Speed EL Header Review, Install, and Pictures tomaszjanczak Engine, Exhaust, Transmission 0 10-11-2014 07:27 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 12:50 AM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
