Old 03-15-2016, 01:36 PM   #15
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
My guess is the pump install. It can come unseated enough to bleed off volume and go lean under load when demand is high. Seen it happen a million times. O rings, spacers, etc. it's kind of a crappy install procedure with most pumps and trial and error until you find a combo that works well
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 03-15-2016, 01:40 PM   #16
Ross
Drives: 85 corolla gts
"O" rings between the pump outlet and the housing. Get new ones that are e85 compatible.
Ross is offline   Reply With Quote
Old 03-15-2016, 01:56 PM   #17
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Thanks guys. Ill pick some up and pull my pump to see whats going on when I get a moment. I just got done reading this: http://www.ft86club.com/forums/showthread.php?t=41770 and the associated o-rings. I didnt do the original pump install, I left it for the shop to do when the turbo got installed. So I can not attest as to how it went in.
xkalelx is offline   Reply With Quote
IP Coil Packs bozack Engine, Exhaust, Transmission 6 03-06-2022 01:36 PM
Vendors/Members, Anyone have coil packs in stock? ZionsWrath Engine, Exhaust, Transmission 3 05-12-2015 02:04 PM
Cosworth Power Packs pricing Simon99 Engine, Exhaust, Transmission 175 11-05-2014 10:36 PM
3M tape failing on front lip after time? 1Cor10:23 Cosmetic Modification (Interior/Exterior/Lighting) 14 11-19-2013 01:51 AM
