Old 01-04-2013, 12:39 PM   #29
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Keep us informed as to what they find. I only have about 500 miles on my ACT 6 puck sprung with Prolite flywheel, but I have had zero issues so far.
Old 01-16-2013, 01:09 PM   #30
wu_dot_com
Drives: accord
Talked to ACT engineer last night. they said the lockout issue is not caused by their clutch assembly. the clutch visually have plenty of travel and wear life left. adjusting the clutch peddle travel does not help the situation.
so next off we go to dealership
wu_dot_com is offline   Reply With Quote
Old 09-26-2013, 08:10 AM   #31
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
pmd
Build Thread
Instagram
Old 03-15-2015, 07:23 PM   #32
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
did u get a solution to this issue???
ahaghshenas is offline   Reply With Quote
Old 09-28-2015, 07:38 AM   #33
MrDXB
Drives: GT86 Greddy Turbo Charged
I have my GT86 2013 boosted and i have intalled ACT streetlite clutch kit with flywheel.
I'm facing same issue when car is warm on a traffic light. I can't get it to engage in first gear easily.
but after i move it is very smooth shifting.
Please update if you have found anything
MrDXB is offline   Reply With Quote
Old 03-14-2016, 01:24 PM   #34
jdnguyen
jdnguyen's Avatar
Drives: 2013 FR-S Series 10 and 2010 Camry
I have the same issue with the xtss act clutch kit. Any updates?
jdnguyen is offline   Reply With Quote
Old 03-14-2016, 02:54 PM   #35
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
I have very similar issues to MrDXB.
I have a new clutch kit on order from ACT in lieu of the possibility of a warranty issue and I'm ordering a new clutch Fork.
The issue seemed only happen after the car has been driven for a very long time. But is now pretty constant. It only wants to shift into first second and or reverse if the car is at a roll or if the motor is shut off.
clayrush is offline   Reply With Quote
Old 03-14-2016, 02:56 PM   #36
jdnguyen
jdnguyen's Avatar
I'm going to order an exedy clutch and pressure plate. Maybe I'll order a new clutch fork too.
Old 03-14-2016, 03:28 PM   #37
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
Last week I had this happen with an ACT HD clutch I installed a few weeks ago. I just had to adjust the pedal up a bit and now it goes into reverse, 1st and 2nd fine when standing still.
My pedal was at the factory height when I installed the clutch.
Scenic Driver is offline   Reply With Quote
Old 03-14-2016, 05:59 PM   #38
clayrush
We played with the engagement point and also replaced fluid with no effect. Hopefully I'll see what's up by the end of the week.
Old 03-14-2016, 07:24 PM   #39
Scenic Driver
Have you seen this:
http://www.ft86club.com/forums/showthread.php?t=75445
It's an exedy thread but some people with other brand clutches have had the same issue.
The Following User Says Thank You to Scenic Driver For This Useful Post:
clayrush (03-15-2016)
Old 03-15-2016, 03:45 AM   #40
clayrush
Have you seen this:
Thanks.
I actually read part of that laste year somtime. But following up all i could gather was that they made a revision. And others did better at lubeing.
Old 03-18-2016, 08:35 PM   #41
jdnguyen
jdnguyen's Avatar
I'm going to pull the trans, replace the release bearing and clean and lube the input shaft first. Hope that fixes the issue
Old 04-04-2016, 01:01 PM   #42
jdnguyen
jdnguyen's Avatar
Here is what I discovered. Clutch was getting hung up on the input shaft. Cleaned and greased he shaft and splines liberally. Replaced the release bearing. The pressure plate and fly wheel are slightly warped but within manufacture spec.
Car drives fantastic now. No issues at the moment. Pedal, shifting, and everything feels way better.
Hopefully it lasts the season. I'll let you know.
whining/whirring noise during high load/rpm clutch engagement 7thgear Issues | Warranty | Recalls / TSB 105 06-19-2017 12:04 PM
clutch Engagement Issue? Bu-Tang Issues | Warranty | Recalls / TSB 68 02-19-2017 03:03 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 06:01 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 01:06 PM
