Old 03-14-2016, 01:22 PM   #15
c4lvinnn
Drives: Toyobaruion
Originally Posted by bryzter View Post
No airbag light on NRG hub? did you use any resistors? Does the NRG hub comes with a resistors? Thanks
It comes with resistors but I made my own and didn't use the ones that it came with.
c4lvinnn is offline   Reply With Quote
Old 03-14-2016, 01:42 PM   #16
bryzter
Drives: 2005 BMW 3 series / 2013 Scion FRS
Smile
can I buy the resistors off from you?
bryzter is offline   Reply With Quote
Old 03-14-2016, 01:48 PM   #17
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
If he can't help you out you can buy them here. http://www.frsport.com/Splash-SB-Har..._p_281671.html
Old 03-14-2016, 01:56 PM   #18
bryzter
Thanks ZOMFGAARON I think this is the correct one
http://www.frsport.com/Works-Bell-10...r_p_59074.html
http://www.evasivemotorsports.com/mm...Code=WB-OPTION
Old 03-14-2016, 02:06 PM   #19
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
I use the one linked for both connections with no issue.
Old 05-06-2016, 04:18 PM   #20
pleong
Drives: 2013 Whiteout FR-S
So I have both the SRK-125H and SRK-120H... I want the 120H bc it's a lot shorter and my wheel sits really close to me...
If i remove the clock spring, does that just make the lights on the dash pop up? because I have the 86nanny which turns off my traction and abs... plus it doesn't bother me since my cluster is in my glove box
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 05-06-2016, 06:41 PM   #21
Norville Rogers
Drives: Subaru BRZ
Painful.
Norville Rogers is offline   Reply With Quote
Old 11-01-2017, 07:52 AM   #22
rookietopro_frs
rookietopro_frs's Avatar
Drives: 2013 Scion FRS
Yeah the removal of the clock spring is the source of all your issues.
Edit: I thought nrg fixed this issue and allows installation without removal of the clock spring?
I still have my clock spring installed ... but still figuring out why my traction light stays on & the ABS light. Thought I'd only have to deal with the airbag light.
rookietopro_frs is offline   Reply With Quote
Old 11-01-2017, 07:54 AM   #23
rookietopro_frs
Why did you take your clockspring off? That's the source of all your issues.
I have an NRG short hub, NRG quick release and a Nardi wheel. No issues at all. No airbag light, no TC light, horn works, etc.
Also, make sure the part # for the short hub is SRK-125H. The other ones for Scions (xB, tC, etc) are a different part number.
I'm trying to get time you & have everything working correctly ! Haha
Old 11-06-2017, 07:38 PM   #24
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
It because you rotated the clock spring damaging it internally.
How to use the OEM amp Wiring RandomHero Electronics | Audio | NAV | Infotainment 258 07-04-2024 01:34 PM
Need some help with some wiring timmydatooth Scion FR-S / Toyota 86 GT86 General Forum 41 08-14-2015 10:10 PM
Wiring for DRL Yap Cosmetic Modification (Interior/Exterior/Lighting) 2 01-19-2015 02:13 AM
LF VA Wiring Help OURO3OROS Mid-Atlantic 0 02-23-2014 09:24 AM
Wiring a sub in a BRZ Shizuma Electronics | Audio | NAV | Infotainment 22 06-08-2013 02:02 PM
