Old 01-05-2016, 11:06 PM   #1
ShabbaJays
Drives: 16 Raven Frs
NRG short hub wiring
i just received a nrg short hub and quick release from my girlfriend for my christmas gift and while installing it, i ran into problems with my traction control and sport mode. i was wondering if anyone has ever found a way to wire everything back to normal with a nrg setup. i know that with the works bell hub i wont run into these problems but i just want to see if anyone can help me with the nrg hub. Thanks!
ShabbaJays is offline   Reply With Quote
Old 01-06-2016, 02:08 PM   #2
Ashikabi
Ashikabi's Avatar
I can't really help you here but I'm curious what the steering wheel has to do with the traction control
Old 01-06-2016, 02:24 PM   #3
adamg
Drives: brz
sounds like your clock spring isnt centered properly
adamg is offline   Reply With Quote
The Following User Says Thank You to adamg For This Useful Post:
NyC Zn6 (02-03-2016)
Old 01-06-2016, 11:08 PM   #4
ShabbaJays
i dont have my clock spring on because of how the nrg short hub is. i think i will just buy the works bell hub because everything is more simple. with the nrg hub, i had to remove the clock spring.
Old 01-06-2016, 11:12 PM   #5
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Yeah the removal of the clock spring is the source of all your issues.
Edit: I thought nrg fixed this issue and allows installation without removal of the clock spring?
Old 01-06-2016, 11:33 PM   #6
ShabbaJays
im not sure if they did or not but now im in need of a new clock spring LOL my stupid self took apart my clock spring to see if i can plug it back and tuck everything together but i ended up breaking it so now i need a new clock spring and works bell hub
Old 01-06-2016, 11:37 PM   #7
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Eeek from what I've seen they're pretty pricey, good luck!
Old 01-06-2016, 11:37 PM   #8
Ashikabi
Ashikabi's Avatar
Check the classifieds for part outs
Old 01-08-2016, 10:48 AM   #9
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
http://toyotaparts.bochtoyotasouth.c...FQokHwodz9wLQA
Old 01-08-2016, 12:13 PM   #10
c4lvinnn
Drives: Toyobaruion
Why did you take your clockspring off? That's the source of all your issues.
I have an NRG short hub, NRG quick release and a Nardi wheel. No issues at all. No airbag light, no TC light, horn works, etc.
Also, make sure the part # for the short hub is SRK-125H. The other ones for Scions (xB, tC, etc) are a different part number.
c4lvinnn is offline   Reply With Quote
The Following 2 Users Say Thank You to c4lvinnn For This Useful Post:
danny_d19 (02-02-2016), rookietopro_frs (11-01-2017)
Old 02-02-2016, 02:47 PM   #11
ShabbaJays
@c4lvinnn I received the nrg short hub which on ft86speedfactory says that it is compatible with the frs but it requires me to remove my clock spring. The regular nrg hub that is the short one allows you to keep the clock spring and also includes resistors.
Old 02-03-2016, 12:59 PM   #12
c4lvinnn
Drives: Toyobaruion
What?
Are they selling you the old ones and not the revised ones? What's your part number?
Old 02-07-2016, 02:13 AM   #13
ShabbaJays
Originally Posted by c4lvinnn View Post
What?
SRK-120H, it doesnt have the conical shape in the back like the works bell one has where you could fit the clock spring. I just installed my works bell and all the light turned off but now after using it for a day, the abs, traction, and airbag light popped up again. I removed everything to see if any wiring came off but its still all connected
Old 03-14-2016, 11:38 AM   #14
bryzter
Drives: 2005 BMW 3 series / 2013 Scion FRS
No airbag light on NRG hub? did you use any resistors? Does the NRG hub comes with a resistors? Thanks
bryzter is offline   Reply With Quote
How to use the OEM amp Wiring RandomHero Electronics | Audio | NAV | Infotainment 258 07-04-2024 01:34 PM
Need some help with some wiring timmydatooth Scion FR-S / Toyota 86 GT86 General Forum 41 08-14-2015 10:10 PM
Wiring for DRL Yap Cosmetic Modification (Interior/Exterior/Lighting) 2 01-19-2015 02:13 AM
LF VA Wiring Help OURO3OROS Mid-Atlantic 0 02-23-2014 09:24 AM
Wiring a sub in a BRZ Shizuma Electronics | Audio | NAV | Infotainment 22 06-08-2013 02:02 PM
