| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: 16 Raven Frs
NRG short hub wiring
i just received a nrg short hub and quick release from my girlfriend for my christmas gift and while installing it, i ran into problems with my traction control and sport mode. i was wondering if anyone has ever found a way to wire everything back to normal with a nrg setup. i know that with the works bell hub i wont run into these problems but i just want to see if anyone can help me with the nrg hub. Thanks!
I can't really help you here but I'm curious what the steering wheel has to do with the traction control
Drives: brz
sounds like your clock spring isnt centered properly
i dont have my clock spring on because of how the nrg short hub is. i think i will just buy the works bell hub because everything is more simple. with the nrg hub, i had to remove the clock spring.
#5 | |
A Demon
Drives: Raven GT86
Yeah the removal of the clock spring is the source of all your issues. Edit: I thought nrg fixed this issue and allows installation without removal of the clock spring? |
im not sure if they did or not but now im in need of a new clock spring LOL my stupid self took apart my clock spring to see if i can plug it back and tuck everything together but i ended up breaking it so now i need a new clock spring and works bell hub
A Demon
Drives: Raven GT86
Eeek from what I've seen they're pretty pricey, good luck!
Check the classifieds for part outs
Drives: 10 Series #974 6m/t
#10 |
Drives: Toyobaruion
Why did you take your clockspring off? That's the source of all your issues.
I have an NRG short hub, NRG quick release and a Nardi wheel. No issues at all. No airbag light, no TC light, horn works, etc. Also, make sure the part # for the short hub is SRK-125H. The other ones for Scions (xB, tC, etc) are a different part number.
#11 |
@c4lvinnn I received the nrg short hub which on ft86speedfactory says that it is compatible with the frs but it requires me to remove my clock spring. The regular nrg hub that is the short one allows you to keep the clock spring and also includes resistors.
#12 | |
Drives: Toyobaruion
Are they selling you the old ones and not the revised ones? What's your part number? |
#13 | |
#14 | |
Drives: 2005 BMW 3 series / 2013 Scion FRS
No airbag light on NRG hub? did you use any resistors? Does the NRG hub comes with a resistors? Thanks |
| How to use the OEM amp Wiring | RandomHero | Electronics | Audio | NAV | Infotainment | 259 | 09-07-2026 11:57 AM |
| Need some help with some wiring | timmydatooth | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 08-14-2015 09:10 PM |
| Wiring for DRL | Yap | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 01-19-2015 01:13 AM |
| LF VA Wiring Help | OURO3OROS | Mid-Atlantic | 0 | 02-23-2014 08:24 AM |
| Wiring a sub in a BRZ | Shizuma | Electronics | Audio | NAV | Infotainment | 22 | 06-08-2013 01:02 PM |
