MisterSheep
Old 02-27-2016, 09:49 PM   #295
ort895
ort895's Avatar
i just want the damn pops and crackle on downshifts lol
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Old 02-28-2016, 08:07 PM   #296
eddieflyinv
eddieflyinv's Avatar
Originally Posted by VeilSide View Post
The overrun function is working perfectly. Just set the RPM delta to -10 or whatever and set a desired angle in the Base Timing Idle (in gear) table.
Unfortunately it seems that the pops and bangs trigger the knock sensor and the IAM is constantly kept at 0
I was thinking too ive had my IAM at 0 before for an entire log but after exiting and then re entering the diagnostics it went to normal... Doubt its actually at 0 lol
Sent from my LG-H812 using Tapatalk
eddieflyinv is offline   Reply With Quote
Old 02-29-2016, 04:42 PM   #297
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
What will give you the loudest pop? -15 or -5?
shaynek is offline   Reply With Quote
Old 02-29-2016, 10:48 PM   #298
_gt86_user
Inactive
Drives: .
-15 in Base timing B
_gt86_user is offline   Reply With Quote
Old 02-29-2016, 11:00 PM   #299
shaynek
shaynek's Avatar
I did -15 but it sounds like popcorn. i have headers and a catback exhaust so i'm guessing it's only loud when your straight piped
Old 03-01-2016, 12:08 PM   #300
_gt86_user
Inactive
Drives: .
Yeah it really only works well with a full catless system (front pipe as well)
Old 03-01-2016, 04:27 PM   #301
shaynek
shaynek's Avatar
lol time to upgrade the front pipe haha
Old 03-02-2016, 03:27 PM   #302
VeilSide
Drives: GT86
Your are right, after another key cycle everything was back to normal. IAM staying at 1 and nice crackles and bangs
Still experimenting with some other values to get it also in higher gears.
VeilSide is offline   Reply With Quote
The Following User Says Thank You to VeilSide For This Useful Post:
eddieflyinv (03-06-2016)
Old 03-08-2016, 07:03 AM   #303
eddieflyinv
Has anyone considered adjusting the Desired Overrun Mass Airflow Tables ? Wondering if adjusting the numbers in those tables to lower values would help with the higher rpm crackles. Less air + initial enrichment = richer mixture that explodes in the exhaust ?
Just figure its an idea as those values rise quite high in the higher rpm range, and with the miniscule amount of fuel we are dropping in there it may be too much airflow and not enough fuel ? Since we cant change the enrichment based on engine speed we could maybe adjust the requested airflow to achieve the same burbles and pops in lower rpm ranges..
Not sure of the side effects though as lowering the numbers at high rpm may change engine braking operation and feel, it makes sense that at higher rpm it requires more air, but would it damage anything to lower the desired airflow ? Id imagine engine braking would become more uncomfortable but im not sure how that would actually play out...
Any experts have a cautionary warning for me before I try it ? Lol
The Following User Says Thank You to eddieflyinv For This Useful Post:
nerve86 (10-08-2022)
Old 03-10-2016, 02:23 AM   #304
504
504's Avatar
Drives: 2014 86 GTS
I'd love to see some video of this new overrun method of crackle
504 is offline   Reply With Quote
Old 03-10-2016, 10:33 AM   #305
ort895
ort895's Avatar
Old 03-10-2016, 10:12 PM   #306
eddieflyinv
Aha im actually getting the gf to take a video tonight, i decided to skip modifying mass airflow and instead played around elsewhere and I have it working pretty well will upload later
Old 03-11-2016, 12:51 AM   #307
eddieflyinv
So I still havent gotten it above 3krpm. Unless its between shifts, works well there.. Buuuut this is how its currently working. (there was slight feathering after initial crackle on the first and third pass)
above 3krpm feathering does work well and loudly, but unfortunately it wont crackle on its own above that. Not a clue why at this point in time. Still playin.. I want to figure out a way how.
It does work in all gears however, as long as I am at or under 3000 and within my negative timing rpm ranges, louder burbles noticed in the car during periods of stock base timing idle (34.14) due to the enrichment, but crackles only with negative timing.
Fuel Cut @ 7000rpm across the board
Resume @ Stock
Enrichment @ 0.8ms
Delta Activation @ -15
Base Timing Idle @ Modified and rescaled (will edit with screenshot when I get to my computer)
Old 03-12-2016, 06:28 AM   #308
VeilSide
Drives: GT86
I use OEM fuel cut and resume, enrichment still at 0, delta at -10 and Base Timinge Idle rescaled up to 7000 rpm. With this it bangs and crackles up to redline at times.
I am using +10° at the time but it is still very loud at times so I want to go further with the positive timing.
I have the impression the real influence is within the Overrun Fueling Cut Counter RPM Threshold table, but I still dont know what exactly this does.
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 05:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 06:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 08:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-18-2014 12:07 AM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 03:12 PM
