| Software Tuning Discuss all software tuning topics. |
#15 | |
Time Traveller
http://www.e85locator.net/State%20Pa...locations.html |
#16 | |
Fast enough
Drives: 2013 Subaru BRZ AT
The one on 109 & I 40 is consistently 78-79% E. I do have flex fuel though so I never think about it. I've seen as low as low 60's in E content. |
#17 |
Still 17!
Drives: 2014 Silver BRZ Limited
That first link of Daemano's shows more than I've ever been able to find online. Thanks.
BTW....Went back to that Shell that I got the bad gas from and apparently they had switched the pump to "Pure fuel" 87 no ethanol without taking off the "E85" Sticker that was just above the pump handle!! Grrrrrr. Probably the worst scenario I could imagine for an Ethanol Tune! No ethanol and 87 octane!!! I wanted to go inside and raise hell....But probably not that guys fault. Hope I didn't hurt my engine.
'14 BRZ LIMITED-OFT (W.W. TUNED)-PERRIN-K&N-WHITELINE-DIODE DYNAMICS-GRIMMSPEED-REXSPEED-FT86-TAPTAP-OLM-GOODYEAR-OSRAM-WEIR-ENKEI-TOMEI EL
| The Following User Says Thank You to MGPAX For This Useful Post: | DAEMANO (02-25-2016) |
#18 | |
Drives: FT86
Here is a log from a stock car running stock tune in South Africa the best fuel they can get in that country is 95 R0N, it about as good as USA 89\87. This guy has been tracking his car as well as do his mates. Its not blown up and all the other 86\brz in that country will be same. Note his iam is 0.2 and he is still getting knock corrections of -3 degrees each time throttle is opened, this was a road log http://datazap.me/u/steve99/south-af...0&data=2-20-28 its got 30% or more fueling adjustment through trims FLKC can drop timing instantly about 6 degrees and IAM reduction from one down to 0 can drop the timing in the mid to upper rpm ranges another 4 to 6 degrees. Thats a total of over 10 degrees mid to upper rpm, this is about the timing added in an e85 tune. While this is not ideal on an NA motor its good enough to save you in your situation unless you took it a track and beat on it. Boosted well it probably wouldnt be pretty. Last edited by steve99; 02-23-2016 at 11:06 PM. |
#19 |
Still 17!
Thanks for the reassurance Steve! Mine was at -28 LTFT and .03 adv. multiplier with FLKC pulling 4 or so also.
It's good to know the car was handling it.....And I'm glad I checked it!!
#20 | |
junior mafia
Drives: ‘20 sti limited
20 sti limited | 17 bmw m240i | 16 scion im |15 brz limited {prokit, 17x8 +35 rpf1, bfg comp 2 a/s, stg 2, jdl uel, voodoo knob} | 05 honda civic | 06 scion tc | 95 mustang gt | 89 chevy s-10 cameo
| The Following User Says Thank You to perryair For This Useful Post: | MGPAX (02-25-2016) |
#21 | |
Hit the road and I'm gone
Slip, slidin' away.
| The Following User Says Thank You to babydriver For This Useful Post: | Chimera (02-25-2016) |
#22 |
I Love custom Turbo kits
Drives: Limited BRZ
And this is why you get a Flexfuel kit and tune when going E85...
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | xsnapshot (02-25-2016) |
#24 | |
Time Traveller
BTW, I've been running e85 on OFT tune stock (no flex fuel kit or ECUtek tune needed) for maybe 2 years total for about 20k miles. No problems whatsoever. Just had to be the littlest bit mindful that the right gas is going in the car. No big whoop. My buddy @WRB5titch on the board has run the same setup as I for 50k miles. Same great results. For my current setup it's terrific. I'd consider spending the extra $1500 if it was necessary, but so far, it ain't. |
| The Following User Says Thank You to DAEMANO For This Useful Post: | phrosty (02-25-2016) |
#25 |
Drives: WRBrz
EBSC - dt.FF - MXP CompRS
#26 | |
Drives: Limited BRZ
FF kit, is less than $500 from Moto East. FF tune + Ecutek license is about $600. (Total between both about $1100). Subtract the $400+ from OFT, and it's around $700 more. The peace of mind if priceless
#27 |
@MGPAX @xsnapshot
Do you guys experience knock over -1 at sudden throttle change? Also what mods are you guys running? I tried e85 last fall before it gets too cold, but I noticed -0.6 fbkc around 4k rpm almost every time and over -1 fbkc at sudden throttle change. The gas I put was always e75(BP @ corner of Moores Ln & Mallory Ln in Franklin) |
#28 | |
Drives: 2013 Asphalt FRS
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
| HELP! WRONG GAS IN CAR | nabil_frs | Issues | Warranty | Recalls / TSB | 85 | 04-01-2014 01:44 AM |
| This must be wrong... | Ongor | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 01-23-2014 11:29 AM |
| What's wrong with this car? | Suberman | CANADA | 41 | 01-14-2014 12:35 PM |
| HELP! WRONG GAS IN CAR | nabil_frs | CANADA | 9 | 05-06-2013 03:49 PM |
| What's wrong with my HID kit? | seven | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 11-28-2012 07:36 PM |
