Old 03-11-2016, 10:16 AM   #4089
TrqlessWonder
Drives: 2014 FR-S
I just used the "contact us" on the Koni-NA site and explained that I had an FR-S and needed the washer. Prompt response and the only question they asked was "what is your shipping address?"
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 03-11-2016, 10:58 AM   #4090
SeanRTR
C-Street AutoX
SeanRTR's Avatar
I thought your car had MCS?
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 03-11-2016, 03:35 PM   #4091
TrqlessWonder
Drives: 2014 FR-S
Nope. too poor/cheap for that. I'm only finally getting ready to pull the trigger on the springs.
I think I may have mentioned a strong interest in sending mine out to be made into double-yellows, but not yet. Heck, someone seeing my car sorta kicked off the brouhaha about the full struts.
-Mike
#24 CS/CSR
Old 03-15-2016, 12:44 PM   #4092
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
....and was right.....
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
Laloosh is offline   Reply With Quote
The Following User Says Thank You to Laloosh For This Useful Post:
TrqlessWonder (03-15-2016)
Old 03-15-2016, 06:19 PM   #4093
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Has anyone autocrossed on the OEM pads for at least 3+ events and then switched to aftermarket? I'm curious what your experience was like doing so and how much of a difference it made in your runs.
Also what is everyone's opinion of the Ferodo DS2500s on the FR-S/BRZ? I run them on my Evo X but it's 1,000 pounds heavier so getting them heated up a little doesn't take long. Do they heat up sufficiently on an FR-S?
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 03-16-2016, 01:18 PM   #4094
AFRichZC6
AFRichZC6's Avatar
I've got Carbotech XP8, which are a bit overkill for autox. I had no issues activating the ABS with the stock pads. After one or two brake applications during the first run to a little heat into them, they bite significantly better. I'd imagine something like the Ferodo DS2500 or Carbotech AX6 would work much more effectively at the lower temps seen at autox.
Edit: As far as making a difference in my runs with the XP8, I feel like I can brake way later in a shorter distance, but these pads are more difficult to modulate versus stock pads - they are grabby and release pretty abruptly.
The AX6 is what I'm switching to as soon as I get them in the mail this week. People tell me they are easier to modulate than the XP8. They're commonly compared against the Ferodo DS2500.
AFRichZC6 is offline   Reply With Quote
Old 03-16-2016, 01:21 PM   #4095
Locust
Custom User Title
Locust's Avatar
Originally Posted by AFRichZC6 View Post
I've got Carbotech XP8, which are a bit overkill for autox. After one or two brake applications during the first run to a little heat into them, they bite significantly better. I'd imagine something like the Ferodo DS2500 or Carbotech AX6 would work much more effectively at the lower temps seen at autox.
I'm fairly certain they work well for auto-cross already I'm just curious how well and if people have issues getting them heated up. Right now I'm on OEM pads and there's a lot of things I want to get done before Crow's but I think brake pads are going to have to wait unless people feel it's a night and day difference.
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 03-17-2016, 03:00 PM   #4096
NJ10
Stiggasaurus Rex
NJ10's Avatar
Drives: '14 WRB Subaru BRZ 6MT
So, the new 2017 Toyota 86 has been revealed (?).
Any ideas where it'll land in the 2017 season?
meh.
NJ10 is offline   Reply With Quote
Old 03-17-2016, 03:06 PM   #4097
AlanLGuy
Drives: Raven 6 speed Manual FRS
Writing my letter to put it in BS. +5 horsepower and torque, it would be too unfair to all the 13-16 BRZ owners. I mean, not only do they get shafted on suspension, but they're also down horsepower now too!
2013 6-Speed Raven Black Scion FRS - Unmolested, for now
2000 Celica GT-S - "Frankenstein" CAI, Boosted2.0 Ported Header, TRD Exhaust, ES Motor Mount Inserts, ES Suspension Bushings, Southbend TZ clutch, Fidanza Flywheel.
AlanLGuy is offline   Reply With Quote
The Following User Says Thank You to AlanLGuy For This Useful Post:
NJ10 (03-17-2016)
Old 03-17-2016, 03:10 PM   #4098
renfield90
The Stig's German cousin
CS arms race. 2nd gear will be taller than the current gen which will lead to better 0-60 times for the magazines, and less shifting for autocrossers.
Old 03-17-2016, 03:46 PM   #4099
Locust
Custom User Title
Locust's Avatar
Well that makes the choice easy for me at the end of this year.
LOCUST
Instagram:
LocustAutoX
Sponsors:
Old 03-17-2016, 04:23 PM   #4100
NJ10
Stiggasaurus Rex
NJ10's Avatar
I guess everyone's pricing out stx builds right now.
But wait, are we safe there either?
meh.
Old 03-17-2016, 04:34 PM   #4101
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
rofl
ineedyourdiddly
Old 03-17-2016, 04:47 PM   #4102
DaWorstPlaya
Drives: 2016 FR-S
But doesn't that also mean acceleration would be slower, which would negate the power advantage?
DaWorstPlaya is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
