#449 |
/scion
Drives: '13 86 M/T
@steve99 thanks for the response. It definitely gives me a better ideas as to what's going on, and great clarification as to how things work. I will reach out to the OpenFlash crew.
"Practice makes better. Only Senna is perfect." - CSG Mike
#450 |
/scion
Drives: '13 86 M/T
@steve99 Another question for you:
Would I be able to run a Zeitronix ECA-2 to simply monitor E% alongside the OFT E85 tune?
#451 | |
Drives: FT86
at some point later if oft release code and tune you should then be able to hook up full flex, or you could go ecutek if that does not eventuate with oft. just check you can power the sensor analyser and display or blutooth module without using o2 or evap plugs. be an expensive display though the flex sensor put out a varing frequency signal this is then converted by the flex analysier module into the 0 to 5v used by the ecu, but you need new software in ecu to repurpose an unnecessary input for flex signal and then interpret and act on that signal |
| The Following User Says Thank You to steve99 For This Useful Post: | LOLS2K (03-04-2016) |
#452 | |
/scion
Drives: '13 86 M/T
#453 |
Hmm any reason why my Cal code and Tune Files don't ?
Also when I go to add a tune (AO1C) in bank 4 it's not compliant and If i try to upload an (A00C) "Module Can not be found" I am trying to upload the updated files I downloaded from the site. "Toyota GT86 Off-The-Shelf (OTS) Tune Files (v2.074) UPDATED 2/18/16" Am I missing something?
#454 | |
Drives: Toyota 86
You can also build yourself an arduino flex fuel sender and output to bluetooth, PLX gauge, or any display you can attach to arduino. http://www.ft86club.com/forums/showthread.php?t=94751 |
#455 | |
/scion
Drives: '13 86 M/T
#456 | |
Drives: Toyota 86
2. The ECA sender/arduino will read the frequency and output a voltage which is displayed in the <primitive LED if ECA-2> gauge. You can put this in anytime you want. 3. The FlexFuel code (EcuTek's or mine) gets the ECU to read the voltage and alters fuelling and timing based on the voltage read. 4. You can interrogate the voltage sent by the ECA sender and display it however you want - arduino, OFT, multimeter; or log the value of the ethanol content used in RAM. |
| The Following User Says Thank You to ztan For This Useful Post: | LOLS2K (03-06-2016) |
#457 |
/scion
Drives: '13 86 M/T
@ztan that really clears it all up for me. Thanks for breaking it down in layman' terms for me.
#458 | |
Drives: FT86
Hmmm something weird going on their. Suggest you flash back stock tune to car . Then erase oft, using openflash tablet manager (connected to internet) Then read in stock tune again load in tunes that match your original calid looks like oft has got confused if that does not work contact the Openflash guys on phone |
#459 | |
Drives: CWP series blue brz
#460 |
Open Flash Tablet - OFT TIPS Trick’s & FAQ
Yea gonna re flash to stock and unmarry marry. Going to start from scratch with the updated tunes. I will knee you guys posted tonight. 👌🏼
#461 |
Drives: 2013 Subaru BRZ
Mine just says not compliant when I try to upload tunes even though they match the CAL that I got from Shiv and website. Gonna start at beginning see if that works while waiting for Shiv to get back with me.
*update* I erased all data and started from beginning and still getting file is not compliant. Not sure what's wrong still waiting for Shiv to get back with me. In mean time might see if I get it flashed at dealership if that don't fix it. Sent from my iPhone using Tapatalk Last edited by drewhusaf27; 03-11-2016 at 01:06 PM. |
#462 | |
Drives: FT86
no point getting the dealer involved its an OFT problem. did you flash back you original tune to cat from OFT then totally erase OFT with open flash manager ? then re read origina tune. Check its calid with OFT then load tunes of that calid. |
| WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 07:13 PM |
| Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 08:27 PM |
| FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 02:08 PM |
| FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 02:49 PM |
| Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 07:14 PM |
