Old 03-10-2016, 07:29 PM   #15
steve99
Drives: FT86
Originally Posted by ShadowReaper View Post
I have a slight exhaust leak and you would assume they would have gaskets ready n hand. I went today they don't have any, might as well place an order.
I have the stock ones in front of me, but I'm iffy on re-using them. It looks a little rusty and worn.
dont reuse exhaust gaskets, they will leak after a while. they are designed to crush to shape and can only be used once
ShadowReaper (03-10-2016)
Old 03-10-2016, 07:42 PM   #16
Ashikabi
Ashikabi's Avatar
Fteightysix.com sells the oems cheap. Or villagescion.com
Old 03-10-2016, 09:02 PM   #17
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
The dealership already has some in the way. Might as well stick around for that, as it will be quicker.
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 03-16-2016, 01:04 AM   #18
Chloroform
Drives: WRB Limited MT6
Well, Chloroform, I'll check the newspaper and if JBLM isn't firing artillery and I hear loud sounds up here in Puyallup, I'll figure it's your car ......
It's actually not too bad, the cold start can be kinda obnoxious but is fine after 20 seconds. It's only loud when I get in on it
Originally Posted by Brayden_23 View Post
In for the sound clips you post when it's all done!
I filmed it with my phone and an old go pro, so the sound isn't the best lol
[ame="https://www.youtube.com/watch?v=uKJmcTFBi1o"]Subaru BRZ UEL Dezod Exhaust - YouTube[/ame]
Chloroform is offline   Reply With Quote
Old 03-16-2016, 01:16 AM   #19
Oh, OK, ..........I'm glad to hear those sounds were from your car and not just the HMARS test firings at JBLM .........
Yep, your car sounds like it's on a track ......
Old 03-17-2016, 03:18 PM   #20
rocket12
insta: f_de_pinho9
rocket12's Avatar
Drives: Toyota GT86 Std
Hey, Cholofrom sorry about this but im also new to exhausts.. when you get a exhaust do you need a tune for it to run properly?
rocket12 is offline   Reply With Quote
Old 03-17-2016, 03:50 PM   #21
Ashikabi
Ashikabi's Avatar
If it's a cat back, no. If it's headers yes.
Old 03-17-2016, 11:31 PM   #22
Brayden_23
Drives: Asphalt 2015 FRS
Can you elaborate a bit more on this? I understand that without a tune, it will most likely throw a CEL. And I know that a tune will make the most out of the header. But you can still put one on and not tune it, right? I'm in this situation and as long as no damage will come of it, the tune is coming a little further down the road.
Brayden_23 is offline   Reply With Quote
Old 03-18-2016, 12:31 AM   #23
secret.squirrel
secret.squirrel's Avatar
Drives: GT86
Essentially there are two sensors in the manifold (headers) that look for differences in the exhaust gasses before and after the cat in the manifold. When you go with a decat manifold the sensors don't read the differences they are expecting and the engine will throw up a CEL. don't worry, no damage will be done, no limp home mode or power drop, all that happens is the cruise control will be disabled.
The stock map on the ECU was designed with the catted factory manifold in mind, including accounting for the restriction of the cat etc etc. The freer flowing exhaust allows a modified and better mix to be combusted, but the ECU needs to be told this through an aftermarket tune.
Basically, without a map the engine can breathe better but the ECU doesn't know how to make the most of it. With a map, the ECU is given parameters to capitalise on a freer exhaust.
As for the catback, this system is installed after all the factory sensors so will have no effect on what the ECU sees. A small gain may be had from it however, due to the fact that again the aftermarket component will tend to be freer flowing and allow better passage of exhaust gas.
secret.squirrel is offline   Reply With Quote
The Following User Says Thank You to secret.squirrel For This Useful Post:
Haeb (03-18-2016)
Old 03-18-2016, 03:03 AM   #24
steve99
Drives: FT86
If your going to start engine mods suggest you read Basic Bolt on Mods guide below
Old 03-18-2016, 11:43 PM   #25
Brayden_23
I have read that previously. So it is correct to say that if I change the header, but don't tune right away, the only risk is to possibly have a CEL? (The header I ordered is catted)
Someone once told me off the forums some theory about changing the header without a tune messes with cylinder temps/firing or something like that. Just looking for confirmation that my motor won't blow up which I don't think it would..
Old 03-18-2016, 11:54 PM   #26
Ashikabi
Ashikabi's Avatar
It probably won't hurt anything but I wouldn't push it till you get a tune
Old 03-19-2016, 04:01 AM   #27
steve99
Drives: FT86
people run catted and even uncatted headers without tune (they use 02 spacer to help wil cel code)
the fueling and timing is uneffected by header ie the ecu will run same timing and fueling it ran before header, the ecu will adjust fuel trims itself so it runs the same fueling even if header flows better. the main thing tune does is adjust the intake and exhaust valve timing to take advantage of the better gass flow of the header and they will also adjust many other parameters.
no it wont blow up :-), you just miss out on a lot of the possible gains
intakes can upset ecu much more than headers
Teseo (03-20-2016)
Old 03-20-2016, 08:50 PM   #28
Brayden_23
Perfect, that's exactly what I was wondering! Thank you for the information. Hopefully it won't be long until I get it tuned. Was hoping to use the OFT but I don't have Windows..
ROOKIE QUESTION TPMS!! brz23 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 03-01-2015 06:05 PM
Help out a rookie? Outride Forced Induction 37 02-04-2015 01:04 PM
BRZ holds its own in Auto-X with rookie driver mtimney Tracking / Autocross / HPDE / Drifting 4 08-11-2013 12:24 PM
Adventures of a rookie in Autocross djfuller Tracking / Autocross / HPDE / Drifting 9 04-01-2013 09:30 PM
