Drives: WRB Limited MT6
Rookie Exhaust Question
So I'm finally getting ready to pull the trigger and order my exhaust for the BRZ, and I just wanted some extra insight on if everything's going to work.
I'm planning on a 1320 Header with their OP, then doing a catted motiv front pipe and then a Dezod cat back. Now, I know that I'll be throwing a code for not having the cat in the header, but it's my understanding that that will go away with a tune. Am I missing any other exhaust parts, like do the exhaust gaskets usually come with the parts or is that something I should just pick up on my own? Also, I know this setup is going to be loud but does anyone know just how loud it's going to be? Thanks in advance for reading this huge mess of a post. |
#2 | |
![]() humfrz |
#3 | |
Drives: frs
Oh dang, I didn't even think about getting new nuts and studs. Is there a website where I could order the whole set? Or should I just go to a dealership and order them?
Drives: frs
Inactive
Drives: .
You might want to hang on to your stock exhaust pieces just in case. I'm pretty sure it's gonna be loud as fuck.
| The Following User Says Thank You to _gt86_user For This Useful Post: | Mr.Impreza (02-04-2016) |
Fteightysix sells oem gaskets. Much cheaper than grimmspeeds
Y u do dis?
just installed one of these with a buddy, you'll want to invest in a swivel socket.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
#10 | |
Drives: 2013 Raven FR-S
that and some long extensions for the ratchet. other than that, everything is a piece of cake. gaskets from dealership were like 8 bucks each I think. definitely don't cheap out and reuse them. also, instead of buying the catback, I'd invest in a used OFT so you can get the benefits of your header first while also seeing if you want to go any louder. if you do header, FP and catback all at once, you might regret it. piece by piece for the exhaust starting at the headers would be my advice. |
| The Following User Says Thank You to cdq85 For This Useful Post: | Dream20b (02-04-2016) |
#11 | ||
#12 | |
Drives: frs
#13 |
Slow I am, boost I must..
Drives: Whiteout 2013 FRS
You'll need new gaskets unless your new exhaust pieces come with them (mine did), id reuse oem bolts and studs if you can. Header to over pipe i had to buy a couple bolts but that should be it. Gaskets and re use stock bolts if you can. if your headers are UEL you may want to invest in a u-joint for your socket as some of the bolts con be hard to get to if not. OFT is the easiest way to go tune wise, I love mine i highly suggest it!
Enjoy man! |
#14 |
Indulgent Tormenter
Drives: 15' LTD Subaru BRZ DGM
I have a slight exhaust leak and you would assume they would have gaskets ready n hand. I went today they don't have any, might as well place an order.
I have the stock ones in front of me, but I'm iffy on re-using them. It looks a little rusty and worn.
Instagram: Gabe.it.the.ole.college.try |
| ROOKIE QUESTION TPMS!! | brz23 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 03-01-2015 06:05 PM |
| Help out a rookie? | Outride | Forced Induction | 37 | 02-04-2015 01:04 PM |
| BRZ holds its own in Auto-X with rookie driver | mtimney | Tracking / Autocross / HPDE / Drifting | 4 | 08-11-2013 12:24 PM |
| Adventures of a rookie in Autocross | djfuller | Tracking / Autocross / HPDE / Drifting | 9 | 04-01-2013 09:30 PM |
