Old 02-04-2016, 01:42 AM   #1
Chloroform
Drives: WRB Limited MT6
Rookie Exhaust Question
So I'm finally getting ready to pull the trigger and order my exhaust for the BRZ, and I just wanted some extra insight on if everything's going to work.
I'm planning on a 1320 Header with their OP, then doing a catted motiv front pipe and then a Dezod cat back.
Now, I know that I'll be throwing a code for not having the cat in the header, but it's my understanding that that will go away with a tune. Am I missing any other exhaust parts, like do the exhaust gaskets usually come with the parts or is that something I should just pick up on my own?
Also, I know this setup is going to be loud but does anyone know just how loud it's going to be?
Thanks in advance for reading this huge mess of a post.
Chloroform is offline   Reply With Quote
Old 02-04-2016, 03:39 AM   #2
Originally Posted by Chloroform View Post
So I'm finally getting ready to pull the trigger............ Also, I know this setup is going to be loud but does anyone know just how loud it's going to be?
Well, Chloroform, I'll check the newspaper and if JBLM isn't firing artillery and I hear loud sounds up here in Puyallup, I'll figure it's your car ......
go_a_way1 (02-04-2016), olsonpg (02-04-2016)
Old 02-04-2016, 08:01 AM   #3
Teseo
Drives: frs
You will need new gaskets, iirc studs and nuts. Your combo will sound nice deep, growl rumble. Also need a tune to erase cel
Old 02-04-2016, 10:53 AM   #4
Chloroform
Oh dang, I didn't even think about getting new nuts and studs. Is there a website where I could order the whole set? Or should I just go to a dealership and order them?
Old 02-04-2016, 11:11 AM   #5
Teseo
Drives: frs
Dealership have them in stock, still you can buy them online.
Old 02-04-2016, 11:37 AM   #6
_gt86_user
Inactive
Drives: .
You might want to hang on to your stock exhaust pieces just in case. I'm pretty sure it's gonna be loud as fuck.
_gt86_user is offline   Reply With Quote
The Following User Says Thank You to _gt86_user For This Useful Post:
Mr.Impreza (02-04-2016)
Old 02-04-2016, 12:01 PM   #7
Ashikabi
Ashikabi's Avatar
Fteightysix sells oem gaskets. Much cheaper than grimmspeeds
Old 02-04-2016, 12:03 PM   #8
Brayden_23
Drives: Asphalt 2015 FRS
In for the sound clips you post when it's all done!
Brayden_23 is offline   Reply With Quote
Old 02-04-2016, 03:11 PM   #9
Dream20b
Y u do dis?
just installed one of these with a buddy, you'll want to invest in a swivel socket.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 02-04-2016, 03:28 PM   #10
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
that and some long extensions for the ratchet. other than that, everything is a piece of cake. gaskets from dealership were like 8 bucks each I think. definitely don't cheap out and reuse them. also, instead of buying the catback, I'd invest in a used OFT so you can get the benefits of your header first while also seeing if you want to go any louder. if you do header, FP and catback all at once, you might regret it. piece by piece for the exhaust starting at the headers would be my advice.
cdq85 is offline   Reply With Quote
The Following User Says Thank You to cdq85 For This Useful Post:
Dream20b (02-04-2016)
Old 02-04-2016, 08:16 PM   #11
Chloroform
Yeah, I figured on keeping the stock stuff around just in case I get a fix-it ticket =/
Thanks for the input, I'll probably buy an OFT at the same time just so that I can install it all at once and not have to worry about a CEL. I'm pretty used to loud cars (had a straight piped VR6) but I'm not sure how bad it'll be with this car haha. If it does end up being too loud I'll probably ask in the forums again about which parts I should swap out to quiet it down.
Old 02-04-2016, 08:25 PM   #12
Teseo
Drives: frs
Advice, leave the stock front pipe
Old 02-05-2016, 12:05 AM   #13
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
You'll need new gaskets unless your new exhaust pieces come with them (mine did), id reuse oem bolts and studs if you can. Header to over pipe i had to buy a couple bolts but that should be it. Gaskets and re use stock bolts if you can. if your headers are UEL you may want to invest in a u-joint for your socket as some of the bolts con be hard to get to if not. OFT is the easiest way to go tune wise, I love mine i highly suggest it!
Enjoy man!
wise345 is offline   Reply With Quote
Old 03-10-2016, 07:16 PM   #14
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
I have a slight exhaust leak and you would assume they would have gaskets ready n hand. I went today they don't have any, might as well place an order.
I have the stock ones in front of me, but I'm iffy on re-using them. It looks a little rusty and worn.
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
ROOKIE QUESTION TPMS!! brz23 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 03-01-2015 06:05 PM
Help out a rookie? Outride Forced Induction 37 02-04-2015 01:04 PM
BRZ holds its own in Auto-X with rookie driver mtimney Tracking / Autocross / HPDE / Drifting 4 08-11-2013 12:24 PM
Adventures of a rookie in Autocross djfuller Tracking / Autocross / HPDE / Drifting 9 04-01-2013 09:30 PM
