Old 03-08-2016, 06:40 PM   #267
HuntingtonFRS
Drives: 2013 Scion FR-S in White
Is there an ideal engine oil to be used with this HKS kit? Also, if I move to Florida versus West Virginia should the oil be changed accordingly for the kit?
HuntingtonFRS is offline   Reply With Quote
The Following User Says Thank You to HuntingtonFRS For This Useful Post:
zeal86 (03-08-2016)
Old 03-08-2016, 08:39 PM   #268
86Tony
Drives: 2015 AOZORA EDITION
this is from the hks site.... We recommend to use with engine oil cooler and engine oil with high temperature viscosity of #40 or higher. (HKS HR 0W42, Racing Pro 0W40/10W50, etc
86Tony is offline   Reply With Quote
Old 03-08-2016, 08:54 PM   #269
HuntingtonFRS
And in other words that means what standard oil from a parts store? lol
Old 03-08-2016, 09:48 PM   #270
wbradley
Sarcastic SOB
wbradley's Avatar
Mobil 1 0W40
The Following User Says Thank You to wbradley For This Useful Post:
HuntingtonFRS (03-08-2016)
Old 03-08-2016, 11:25 PM   #271
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
Originally Posted by wbradley View Post
I think other than the stock 110 mm pulley with the V3, you can get 100, 95, 90, 85 and 80 mm pulleys. It is on the HKS website.
The bigger blower is sold as a stand alone generic unit if you want to fab your own kit. That requires you configure the mounting plate, select and configure pulleys, piping, etc.
There are shops that could do it if you can pay but that's an awful big supercharger for this motor on a 12:1 CR. You probably need to change the bottom end, and go to 10.5:1 CR, as well as fueling, clutch, etc etc. In Canada I am guessing it will cost $20K easily. At that point I'd be more inclined to just get a big turbo and call it a day.
My 215 PSS are having a tough time getting traction as it is!
with V3 HKS supercharger kit,
We can change pulley size, but it's limited by own impellar speed.
I think 90mm will be the last , possible size for that V3 kit.
V3 kit is good for safe boost with slightly bad gas, and
reliability of supercharger unit.
V2 kit is good for Easy boost upgrade with restrictor's ID
(because it has already smallest possible pulley )
my V2 kit with 42mm restrictor make 11~11.5 PSI over 6000RPM to redline now.
if I enlarge restrictor's ID to 43mm, it will make over 12 PSI easy.
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
The Following User Says Thank You to Yobiwan For This Useful Post:
Andew727 (03-09-2016)
Old 03-09-2016, 07:47 AM   #272
wbradley
Sarcastic SOB
wbradley's Avatar
What size pulley are you using??
Old 03-09-2016, 08:18 AM   #273
Andew727
Drives: Scion FR-S
i live in florida and have a lot of supporting mods to the hks kit. i use 5w-30, all my pressures and temps stay in spec well.
Andew727 is offline   Reply With Quote
The Following User Says Thank You to Andew727 For This Useful Post:
HuntingtonFRS (03-09-2016)
Old 03-09-2016, 10:15 AM   #274
Yobiwan
Yobiwan's Avatar
my kit is V2 and I'm using stock 90mm pulley.
only thing that I change is restrictor's ID. (39mm to 42mm)
and I'm using stock injector, and stock MAF now too.
Old 03-09-2016, 04:48 PM   #275
HuntingtonFRS
Any recommendation on a gauge for boost? I was looking at the Defi 52mm boost.
Old 03-09-2016, 06:21 PM   #276
wbradley
Sarcastic SOB
wbradley's Avatar
I use Torque
Old 03-10-2016, 01:03 AM   #277
86Tony
so how much power are you makin with your hks kit
Old 03-10-2016, 02:13 AM   #278
Yobiwan
Yobiwan's Avatar
I've installed sc kit early winter, and still trying to tune car my self.
My first - but last SC dyno number was 250ish , with 40mm restrictor
& it was rainy day.
I'm using 42mm restrictor now
I feel much faster than before, but I don't know exact number yet .
Old 03-12-2016, 06:51 PM   #279
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Originally Posted by Andew727 View Post
says 17 psi on my box for the 90mm this all depends on pressure drop and efficient pipe bends so on... the smallest is 80mm, i just checked. i need that. and stock V1 is 100mm, v2-v3 are 110
Stock V2 is 90mm. And it's pretty maxed out already with this pulley. With 42mm restrictor it's 11 psi. Unrestricted it goes up to 14 psi. I'm pretty sure that HKS issued the V3 with much bigger pulley (and therefore slower rotation speed) to improve reliability and longevity. If you add the V2=>V3 upgrade kit (intercooler and piping) to the V2 blower it can make 350 wph at 14 psi boost. But for how many miles... that's a big question too me.
Efferalgan is offline   Reply With Quote
The Following User Says Thank You to Efferalgan For This Useful Post:
CxG (03-13-2016)
Old 03-13-2016, 09:05 PM   #280
PureShield
PureShield's Avatar
What octane are you guys running/tuned for? Any owners from Canada?
PureShield is offline   Reply With Quote
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
