Old 03-03-2016, 09:41 AM   #323
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
Originally Posted by Deep Six View Post
Were you on E85? 93? 91? Just curious.
xsnapshot is offline   Reply With Quote
Old 03-03-2016, 11:21 AM   #324
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
BTW there are 4 other cars with blown motors at the same shop in Orlando as I write this so yes there is an issue.
When I hear that there's 4 blown up cars sitting at a shop that tuned them, I'm not inclined to blame the durability of the engine...
ineedyourdiddly
The Following 9 Users Say Thank You to strat61caster For This Useful Post:
continuecrushing (03-03-2016), CSG Mike (03-03-2016), fumanchu1 (03-03-2016), go_a_way1 (03-03-2016), Jaden (04-20-2016), spitfire481 (03-03-2016), uRBAN_Metal (03-03-2016), xkalelx (03-03-2016), Yoda (03-03-2016)
Old 03-03-2016, 12:03 PM   #325
kch
Senior Misanthrope
kch's Avatar
Mine popped recently after about two weeks of forced induction. I went with the "safest" supercharger system
Your sig says you have the HBP, though, which isn't exactly safe on pump gas. Sucks that you threw a rod, though.
Old 03-03-2016, 02:38 PM   #326
Andew727
Drives: Scion FR-S
It can happen to anyone which is not the same thing as saying it will happen to everyone. More track days, adding power, especially forced induction simply increases the likelihood that something will break and it will probably a rod.
Mine popped recently after about two weeks of forced induction. I went with the "safest" supercharger system, had it conservatively tuned to 20 degrees of advance and a 7K limiter, have the JR oil cooler and a full blown radiator but it still threw a rod accelerating onto a freeway which cut a trench across the top of the block.
Moral of the story is that blame is not an issue, understanding the potential risk and how modifications will change the odds is. You can not bet your motor that having a good tune and cooling provides any guarantee, they just change the odds a little more in your favor. I will be starting a new thread soon focused on the choices to be made when replacing a blown motor, Thankfully I have the resources to do what I want and I really expected to eventually have a built motor or a V8.
add me to that thread when you start it. im building my motor still. would like to share and be educated as much as possible on other failures. thanks for the info.
Andew727 is offline   Reply With Quote
Old 03-03-2016, 02:46 PM   #327
Andew727
Drives: Scion FR-S
Originally Posted by makinen View Post
Hi,
Did he do machining similar to this?
http://www.ft86club.com/forums/showp...9&postcount=24
you have to machine aftermarket rods to work with the stock pistons?!?!?!?!?!?!
dont tell me this...
Old 03-03-2016, 02:52 PM   #328
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
I was going to ask about that as well. That doesn't seem right. The only reason you would have to do that is if you have interference issues with the piston and wrist pin. No one else has ever mentioned doing that before going when going to upgraded rods and pistons so I am going to disregard that modification.
EDIT: Looks like he was having interference with that rod selection and stock pistons. For the cost and trouble, I will just be replacing with new pistons when I get to that point.
xkalelx is offline   Reply With Quote
Old 03-03-2016, 03:12 PM   #329
Andew727
Drives: Scion FR-S
i ended up going with a different set of rods than the skunk H beams, but still a little alarming. ive had enough problems with this machine shop being slow and dont need another delay haha.
Old 03-03-2016, 03:36 PM   #330
blueap2
Drives: '14 FR-S
If I'm not mistaken, all aftermarket rods will need tapering at the small end to fit the OEM piston.
Talked to the guys at Pauter and they will be doing this mod for me when I buy.
blueap2 is offline   Reply With Quote
Old 03-03-2016, 05:19 PM   #331
xkalelx
xkalelx's Avatar
Ugh. Well, that should make it an easy decision for most people then to go ahead and upgrade to aftermarket pistons. Im not an expert by any means, but paying extra money for an extra operation that inherently weakens (you know what I'm saying, dont argue with me) the small end of the rod to retain a stock piston seams so crazy to me. Just apply the cost of modifying the rod towards better pistons and have a more bulletproof setup.
Old 03-03-2016, 05:28 PM   #332
xsnapshot
Fast enough
I think he may have been on E85. I'd be really curious to find out for sure though.
Deep Six when the failure happened were you up high in the RPMs or lower? Who did your tune? You say tuned conservatively to 20 degrees of advance. By that do you mean that you de-tuned up the upper RPM powerband to put less stress on the motor?
That's the strategy that I'm trying....so I'm interested to know!
Old 03-03-2016, 05:33 PM   #333
blueap2
Drives: '14 FR-S
In the general sense you are right @xkalelx.
Just buy a new aftermarket piston and go with that. However, when your power goals are not over 400whp and you already have a new oem short block it does not make sense to get a new aftermarket piston which requires separating case halves, boring, honing... etc. (Which is my case right now)
Tapering rods doesn't affect the small end much since the bottom of the small end is not compromised. The bottom of the small end gets pushed during the power (ignition) cycle. The top of the small end only sees force during the overlap (intake & exhaust) cycles.
The Following 2 Users Say Thank You to blueap2 For This Useful Post:
xkalelx (03-03-2016), Yobiwan (03-04-2016)
Old 03-03-2016, 05:50 PM   #334
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
agreed
and also the stock piston isn't half bad
the top ring groove is hard anodised for a start
given this forums appetite for high ratio with boost then I can see the appeal for 350bhp builder
Matt@Cosworth is offline   Reply With Quote
The Following 4 Users Say Thank You to Matt@Cosworth For This Useful Post:
ajc209 (03-03-2016), toeout (03-03-2016), xkalelx (03-03-2016), Yobiwan (03-04-2016)
Old 03-03-2016, 08:25 PM   #335
xkalelx
xkalelx's Avatar
^^ valid points.
Old 03-03-2016, 08:29 PM   #336
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Multiple tuners and all four besides mine were turbo kits installed elsewhere.
This shop is just very experienced with building Subaru motors and the owners are very good friends of mine.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following User Says Thank You to Deep Six For This Useful Post:
CSG Mike (03-04-2016)
kill brain cells, not facts
FlexFuel and Facts Shiv@Openflash Software Tuning 74 05-07-2025 04:28 AM
Anyone Else? Hearters Blowing when off. Kiske Issues | Warranty | Recalls / TSB 7 04-09-2014 05:22 PM
How cold is your a/c blowing? jermyzy Issues | Warranty | Recalls / TSB 68 08-18-2013 03:29 PM
Supra Blowing Up radroach Off-Topic Lounge [WARNING: NO POLITICS] 2 07-21-2013 09:14 PM
Facts you may or may not know about your GT86/BRZ/FR-s FiRStsc10n Scion FR-S / Toyota 86 GT86 General Forum 41 07-09-2013 03:05 PM
