Old 10-15-2015, 04:50 PM   #15
pepe
Drives: gt86
Originally Posted by boomslang View Post
+1, anyone know?
+1
pepe is offline   Reply With Quote
Old 10-19-2015, 10:56 AM   #16
pepe
Drives: gt86
I answered you. Blitz has only thread 1 / 8pt. Buy one and have to return
Old 10-19-2015, 10:25 PM   #17
w3bhead
Drives: A Car
I have the same setup as Hagbard except I used the Oil Sandwich plate from Blitz. I had the part imported from Japan.
Sent from my C6833 using Tapatalk
w3bhead is offline   Reply With Quote
Old 10-20-2015, 07:07 AM   #18
pepe
Drives: gt86
bud your sensors... 1/8 " PT? or use 1/82NPT and adapter?
Old 03-02-2016, 02:11 AM   #19
curtdragon
Drives: Acura TSX
Not to bump an old thread but this one should work as well. I just ordered it:
https://www.rallysportdirect.com/par...ndwich-adapter
curtdragon is offline   Reply With Quote
Old 03-02-2016, 07:43 AM   #20
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Thats will not work unless you get a spacer and a longer bolt that that filter threads on (it's 5:45am I can't remember what it's called lol) to or grind the lip around the filter off. I have far more experience dealing with these on our car then I care to admit.
Old 03-02-2016, 08:26 AM   #21
Cole
Not a troll
Cole's Avatar
Correct. Looking at that link, RSD even answers a question about it fitting the FRS/BRZ. Protip, short answer is no
Cole is offline   Reply With Quote
Old 03-02-2016, 08:31 AM   #22
curtdragon
Drives: Acura TSX
Thanks guys. I'll look again today and maybe get the beatrush one because the Blitz one won't work for what I want... not sure why it only has two ports of the same size
Old 03-02-2016, 09:35 AM   #23
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
I currently have both a Trust (greddy) sandwich plate as well as Mishimoto sandwich plate on my car. I started with the trust one as it was the only one on the market when I bought it then was going to switch my prob to the mishimoto one however due to the way everything fits in there with the oil cooler it was not going to work so I stacked them on-top of each other anything taller then a cusco oil filter will probably not fit hahaha
Old 03-02-2016, 10:25 AM   #24
curtdragon
Drives: Acura TSX
Well I think the sensor I have is also 1/8 pt sao it will work. I just thought it looked larger so if I can actually find the Blitz one in the states to order I'll get that.
Old 03-05-2016, 03:06 PM   #25
curtdragon
Drives: Acura TSX
Anyone with the beatrush unit know if you use just one oring or both?
Old 03-12-2016, 11:06 PM   #26
Rinzler_ft86
Rinzler_ft86's Avatar
Drives: 2013 brz limited edition
Just bought mishimotos adapter just to findout it doesn't fit.. what a waste of overnight delivery
Sent from my SM-N920P using Tapatalk
Rinzler_ft86 is offline   Reply With Quote
Old 03-13-2016, 10:45 AM   #27
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
What one, they have a few styles. Did you also get the spacer?
I will get a pic of what mine looks like if I get a chance today for you
Old 03-17-2016, 01:31 PM   #28
Tainen
Drives: First SWP BRZ-L
is getting your oil temp from the sandwhich plate an accurate sample location? Is it post cooled oil or pre-cooled?
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
FS: GReddy T518Z Turbo Jefffrs Engine, Exhaust, Bolt-Ons 2 08-15-2014 12:08 PM
Greddy Sandwich Plate 12002802 Captain Snooze Australia Classifieds 2 07-09-2013 07:41 AM
Casting Defect Sandwich Plate Dezoris Issues | Warranty | Recalls / TSB 1 01-22-2013 03:04 PM
Heads Up BRZ Available In So Cal ZmZMWagon Southern California 17 06-18-2012 03:10 PM
TOYOTA FT-86....SCION! Back off and get your own sandwich! Raiden Scion FR-S / Toyota 86 GT86 General Forum 9 08-07-2010 05:45 PM
