#15 |
Drives: gts 86
im also running the crawford aos, 10,000km's now with no issues and no oil in the intake tubing
#16 | |
Sarcastic SOB
Running a Cusco catch can and installed it before going FI. Thought the instructions in Japanese might be wrong and ignored the pictures showing hook up to crankcase vent. Attached to PCV instead. It collects very little oil. Should I be getting a lot more oil from the CCV? Edit: Just checked my throttle body this morning and it's dry as a bone.
#17 |
Drives: Velocity Orange 86 GT
With my experience the Crankcase vent produces more vapours in a FI build and can be a little more difficult to see depending on where it vents to in the intake stream. I can only speak from my street and track use.
#18 | |
Drives: 2013 BRZ black
#19 |
![]() ![]() wtf...
#20 |
Sarcastic SOB
^^^That's not a ton.
Where do you have the lines re-entering the intake? I have the can re-entering from the PCV to the intake manifold where the original rubber tube went from the PCV. The stock crankcase tube re-enters the intake just past the MAF. If that's how you have everything routed that would indicate the crankcase vent catch can isn't catching all of it. My throttle body looking so clean indicates little/nothing getting thru. Maybe due to low miles (~22500), thicker oil (0W-40) and or my piston rings holding up well and letting thru less blow by. I am running 8.5 Lbs max boost but very few miles since FI as I had to remove the blower all last year, so total maybe 1000 mi on it. The true test will be track days next year.
#21 |
Best image I can find ATM. Return lines are roughly 6" from turbo inlet on the intake pipe.
PCV can is by the battery, CCV can is under the turbo. Thats good news then that you arent seeing any indications. Interested in more feedback after track season.
#22 |
Drives: 2025 BRZ, ex-2012 GT86
Then could you please answer a simple question: how, via which hose, this thing returns the caught oil to the engine? Through the PCV apparently? But PCV is there to prevent anything from re-entering the engine, right?
#23 |
Drives: 2014 BRZ
I was running a Crawford AOS in N/A form. Been running a JDL kit for a month now...had some issues with an incorrectly setup wastegate, along with unsecured EVAP hoses causing boost leak. In the midst of trying to find out what my problem was, I deleted the AOS at the advice of my tuner and JDL implored me to cap off my intake manifold plenum and let the PCV just vent. For some reason the car just feels like it does not breathe as well as it was prior to having the pcv set up as intended by Subaru...but it could just be me being paranoid. Where are people putting a check valve in their AOS units?
#24 |
I'm in the same boat. I recently purchased a SC kit and do not know if a catch can is needed.
#25 | |
Indulgent Tormenter
Drives: 15' LTD Subaru BRZ DGM
Instagram: Gabe.it.the.ole.college.try |
#26 | |
Time Traveller
The reason why not everyone has the same result is that each engine seals differently when cold & warm. It's on a case by case basis, but I'd say it's such an inexpensive item to add (in relation to the cost of all F.I. kits) that every boosted car should probably have one as a precaution. The image posted above (i've posted again below) shows what this looks like. It's not a lot, but would likely be trapped by a baffled catch can.
#27 |
Drives: White 2014 BRZ
Or you could save your money and just vent to atmosphere on both sides???
That's what I do...not sure if any downsides other than smell/emissions.
JDL Turbo kit - Ecutek, HRI tuned.
#28 | |
Drives: Toyota Celica
| The Following User Says Thank You to dchan8 For This Useful Post: | R2RO (04-12-2019) |
| Oil Catch Can for Turbo Setup | tonytduc | Forced Induction | 15 | 03-23-2016 11:16 PM |
| Radium Dual Catch Can Kits With AVO Turbo Kit | tonytduc | Forced Induction | 1 | 01-11-2016 03:10 PM |
| What is the difference in catch can? Turbo set up questions? | Mikeez | Engine, Exhaust, Transmission | 0 | 01-27-2015 06:44 PM |
| (wish to buy) space converters. Turbo UEL please. radium catch can | Mr. | Want-To-Buy Requests | 9 | 10-20-2014 11:24 PM |
| High HP turbo catch can setup | Dan@AWD | Forced Induction | 32 | 08-06-2014 08:52 AM |
