Old 02-19-2016, 05:05 PM   #15
Uplink
Uplink's Avatar
Drives: anything you let me
Originally Posted by philooo View Post
I have installed my APR just like in the photo above and I had a slight rub may be 1/16. I tried to sand it down by hand but the carbon is hard as metal...ery well built ! So I decided to let the rotor do their work ... and they rubbed in a little bit and now it is as tight as can be.
Could I see how you router your ducts ? I see that you kept the washer fluid container, I have no idea how it fit with that thing in place ?
That was actually APR's photos. I'll send more when I get home tonight.
But yes, I fully intend to keep the reservoir because the car is a daily.
Uplink is offline   Reply With Quote
Old 02-20-2016, 12:25 AM   #16
Uplink
Uplink's Avatar
Here are the two complete .PDF's. I'm gonna say they are wildly optimistic about that driver side duct's functionality. Also, I'm just realizing that the routing they use might interfere with the lines for an oil cooler. See the attached pic from Perrin's manual.
Edit: Added second oil cooler pic.
File Type: pdf Scion FR-S Brake Inlet Duct Installation.pdf (151.2 KB, 167 views)
File Type: pdf Scion FR-S Rotor Backing Plate & Hose Installation.pdf (401.9 KB, 284 views)
Old 02-20-2016, 08:33 AM   #17
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I sold my APR duct kit bc of this. Unless you have the mishimoto oil cooler with the banjo fittings (like Michele), that hose is not going to fit nicely.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
Uplink (02-20-2016)
Old 02-21-2016, 01:04 AM   #18
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
It will also fit with the Maximal kit too, their lines run down under the airbox instead of around the frame horn.
Old 02-22-2016, 06:58 AM   #19
endless_pain
Pissin off regressives
endless_pain's Avatar
Drives: They have engines.
Not sure. When did you order yours? I haven't personally picked up the set yet because the prices went up so I'm waiting on a sale.
From the pictures it looks REALLY close and barely has room for deflection.
Got them BNIB from a fellow member here. Before the BBK, last year APR replaced one side (Great customer service BTW) because it was rubbing the oem disk, and that new plate side still rubbed the AP disk.
endless_pain is offline   Reply With Quote
Old 02-23-2016, 06:23 PM   #20
MicheleAbbate
MicheleAbbate's Avatar
Drives: Grr Racing FRS & BRZ
Send a message via AIM to MicheleAbbate
@MicheleAbbate Thanks for putting this together, great shots! Did your kit come with instructions? I e-mailed APR and they gave me a link to the .PDF (not readily available from their support page) with fairly detailed steps. If anyone needs it, PM me.
One important note for people that still have all the factory plastic in place, there are splash guards at the engine side of the control arms that need to be cut significantly to feed the hoses through to the calipers. These are APR's how-to pics.
Just seeing this. No, mine didn't come with any instructions at all. Which is what kind of prompted me to make the post
www.GrrRacing.com - Won Scion's first Road Racing Championship in 2011. Raced the Grr Racing Scion FRS from 2014-2018. Have lots of OEM Part FS. lol Check my thread. Now I race in Trans Am TA2.
MicheleAbbate is offline   Reply With Quote
Brake Cooling Routing with Turbo Kit pleong Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-08-2014 03:15 PM
APR Brake Ducts msile Cosmetic Modification (Interior/Exterior/Lighting) 23 09-08-2014 01:30 PM
Brake Air Ducts kombatlion Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 07-17-2014 04:39 PM
Project Mu Brake Ducts Now Available! Xero-Limit Brakes, Suspension, Chassis 1 06-11-2014 09:42 AM
Brake Ducting/Hose Routing? swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-13-2014 03:20 PM
