Old 02-17-2016, 04:24 PM   #1
rosol16
Not A Member
rosol16's Avatar
Drives: 2014 Mustang GT
Groaning sound
At about 30mph with wheel turned slightly like less than a degree I get a groaning sound similar to that of a power steering pump if you know what that sounds like. I would assume its not the power steering pump because we have electric steering. I will get a video if I can. It leads me to believe its a wheel hub/bearing?
rosol16 is offline   Reply With Quote
Old 02-17-2016, 04:31 PM   #2
raven1231
Did you check your trunk?
N1cotine (02-23-2016)
Old 02-17-2016, 04:35 PM   #3
Any suspension mods? Hit anything? Aftermarket wheels?
fumanchu1 (02-17-2016), rosol16 (02-18-2016)
Old 02-17-2016, 04:47 PM   #4
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
My guess without picture or video/sound to back it up would be in line with tcoat's reasoning. Something must be hitting or rubbing somewhere (check the clearance in the wheel well, and possibly take a look while someone else turns the steering from one end to the other). If that fails you could try to replicate the noise while parked and if able to locate where the noise is coming from.
fumanchu1 is offline   Reply With Quote
The Following User Says Thank You to fumanchu1 For This Useful Post:
Old 02-17-2016, 04:48 PM   #5
Welp, the first thing I would do is check the tires pressures.
Next, I would rotate the wheels, front to back.
While I had the wheels off, I would inspect the brakes for a dragging pad and see if I had a lose caliper.
Also, check for a lose wheel bearing.
If none of that fixed it, I would have the alignment checked.
All that is ....... what I would really do, is take it up to my local auto shop and have them find and fix it .......... while I went next door and had a burger.......
rosol16 (02-18-2016), Tcoat (02-17-2016)
Old 02-18-2016, 03:52 PM   #6
rosol16
Not A Member
rosol16's Avatar
So all stock everything suspension and wheel wise. Clearance is plenty everywhere. I can't replicate it while parked you have to be moving and it only occurs at 29-31mph. I can't get the noise at any other speeds. I live on base so most of my driving is 30 as that's the speed limit for all but a few roads. When I get a chance Ill rotate them then alignment would be my last resort. I don't have a garage or jack/stands and you can't do maintenance in the on base parking lots anyway so will have to borrow a buddy's driveway/garage for a day. I recently just purchased a Honda Grom so I've been riding that a lot recently so no real hurry to go spend money on an alignment.
Old 02-18-2016, 04:11 PM   #7
fumanchu1
CAn't tell if lying(first part) or temporary moment of senility. I approve of the latter method, burgers are great
humfrz (02-18-2016)
Old 02-18-2016, 05:06 PM   #8
The first part is what I "think" should be done (by "someone") to try to identify the problem.
The second part is the way "I" would take care if the problem ......
I may have "brain farts" and "senior moments" ........ but, I am NOT ........ NOT .......... what were we talking about ....... ??
Old 02-18-2016, 05:07 PM   #9
fumanchu1
Pretty sure we were talking about burgers rofl
humfrz (02-18-2016)
Old 02-18-2016, 05:37 PM   #10
Pat.Thornton
Pat.Thornton's Avatar
Drives: 2014' 86
I had a similar issue last year after the winter. I was driving on complete sheets of black ice and I ended up hitting a curb very lightly with a front wheel(luckily I had steelies on). After this incident I had very similar problems. Over 30ish mph it would make a vibrating feeling/ groaning noise when I turned to the right. It turned out to be a wheel bearing that I had to have replaced, and everything works great now. Hope this helps you
Pat.Thornton is offline   Reply With Quote
The Following 2 Users Say Thank You to Pat.Thornton For This Useful Post:
FRSBRZGT86FAN (02-18-2016), humfrz (02-18-2016)
Old 02-18-2016, 06:51 PM   #11
Another vote for a bad wheel bearing.
@rosol16 have you , or any other driver, whacked your car's wheels against a curb lately .... ??
Pat.Thornton (02-18-2016)
Old 02-19-2016, 01:09 PM   #12
rosol16
Not A Member
rosol16's Avatar
Negative sir have never hit anything well other than my actual accident but this sound is recent I've had the car for about a month from the body shop and it(the sound)only occurred like within the past week
Old 02-19-2016, 01:19 PM   #13
extrashaky
Drives: 2014 BRZ Limited
My bet is just road noise. These cars make a lot of sounds, most of which are best ignored.
Can you post a recording of this groaning?
Old 02-19-2016, 04:01 PM   #14
Could your accident have messed up the suspension/wheel bearings/hub ..... ??
I'll still tend to think you have a bad wheel bearing/hub......
Pat.Thornton (02-23-2016)
Does this sound deal sound decent ? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 29 11-21-2015 10:02 AM
What is this sound? trsiidno Issues | Warranty | Recalls / TSB 5 01-14-2015 06:04 PM
Drone (Worn Wheel Bearing SOund) Sound From Rear qbzee007 AFRICA 8 11-14-2014 01:04 AM
Groaning from Front End when Traction Lost Tt3Sheppard Issues | Warranty | Recalls / TSB 7 02-08-2014 04:35 PM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 09:57 AM
