#71 | |
Drives: Scion FRS
mounting location of what? What version of the kit are you using? i have the V2 kit with the injector upgrade Where did you mount the oil cooler? Note that HKS sells 2 versions of the oil cooler, one for N/A setups which mounts in front of the rad and the other for FI setups which mounts in front of the passenger wheel (i got the FI unit). How does it do in winters for warm up? i'm lucky enough to have a beater so the car is stored during the winter months Do you track and monitor oil temps, air intake temps, ambient temps? Yes! i have oil temp/pressure and a boost gauge the car is fine as a daily, only times i would have issues is when i'm stuck in bumper to bumper traffic for hours on end but it would never get to a point where i have to pull over to let the car cool off. On the track, it does get hot near the end of a 15min session but every car gets hot at the end of the session. |
| The Following User Says Thank You to FRSCanuck For This Useful Post: | CxG (01-22-2016) |
#72 | |
Drives: Pearl White '13 ZN6
It's good to know that the FI kit works well on the track and in traffic. 2 more questions 1) after installation if some one wanted to make some ducting into the wheel wells would there be room with FI oil cooler that you have 2) if someone got the FI oil cooler and then went with the HKS supercharger would parts of the oil cooler need to be uninstalled to mount the SC properly? Thanks for all the help and quick response I greatly appreciate it! Sent from my D5803 using Tapatalk |
#73 | |
Drives: Scion FRS
not 100% sure as i've never tried, here's a pic of the setup so you get a better idea ![]() 2) if someone got the FI oil cooler and then went with the HKS supercharger would parts of the oil cooler need to be uninstalled to mount the SC properly? only thing i can think of is uninstalling the oil lines prior to installing the s/c |
| The Following User Says Thank You to FRSCanuck For This Useful Post: | CxG (01-25-2016) |
#74 | |
#75 |
Slow I am, boost I must..
Drives: Whiteout 2013 FRS
$4100 with their standalone tuner. i believe around 270whp on pump and 320whp on e85 on base maps I've seen around 400-420whp on the kit.
#76 |
Drives: 2013 FR-S, HKS V2 S/C
We haven't had anyone "max out" a 7040L on a FA20 yet but it's essentially a belt-driven 59 lb/min turbo. ~59 lb/min on a 2.0L is enough air for ~450 hp at the crank on gas. We have S2k guys at that level with this blower, I'm sure the FA20 crowd won't take very long to catch up. Do you have a comp. map for your turbo so we can compare apples to apples?
#77 | |
Drives: 2010 Nissan GTR
There are 744 members in the group as of this morning and growing everyday ![]() There are LOADS of customers & dealers with our kits making 400+ whp. Our new 58mm Inducer Garrett Ball-Bearing (GTX3076R Sized, Custom Billet Compressor Wheel) turbocharger just released. I expect to see several making over 500whp with that option this year on built motors. SHIV @ OFT is about to release his new E85 tunes for this kit, and you're going to see a wealth of people making above 400whp. Stay tuned! |
| The Following User Says Thank You to spdbydesign For This Useful Post: | MisterSheep (01-26-2016) |
#78 |
That's awesome and you should be proud of all your accomplishments!
I was just curious if you had a compressor map for your turbo so anyone reading this thread could compare. That's all. |
#79 |
Killed Scion
Drives: 2013 FR-S Whiteout
We have a member of Norcal86 who has been running a custom E85 tune by shiv and he's making 450whp on the SBD kit
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
| The Following User Says Thank You to MisterSheep For This Useful Post: | spdbydesign (01-26-2016) |
#80 | |
Shiv @ OFT has not supported ethanol tunes for their device with this kit. But I'm happy to announce Shiv is currently finalizing his calibration and will have dyno data to share soon. Since he owns the kit personally, on his personal car, this has expedited the process of his E85 tunes. 400-450whp is going to be par for the course in 2016 with our customers, can't wait!
#81 | |
2013 Rocketbunny V2 FRS
Ag Wheels x Airlift x SBD Turbo x Seibon x Nardi x Spec D x Valenti |
#82 |
Drives: 2013 BRZ Premium
#83 |
I've decided on your kit and will order soon unless something happens and I want e85 but don't want to stick with my OFT!
#84 |
Lots of companies provide Ecutek tunes for this kit.
| Tags |
| :popcorn:, why not? |
| HKS Supercharger V2 vs. Greddy Turbo Kit vs. Crawford Turbo Kit | Ogremair | Forced Induction | 27 | 09-10-2015 04:39 AM |
| Supercharger vs Turbo MPG ? | LoCo | Forced Induction | 23 | 06-27-2015 05:24 PM |
| Which is better turbo or supercharger? | Ryan_FRS86 | Forced Induction | 94 | 05-18-2015 12:26 PM |
| Looking for a turbo or supercharger kit!! | Anthony7515 | Want-To-Buy Requests | 11 | 05-16-2014 08:25 AM |
| HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! | rickspecd | Forced Induction | 4 | 07-12-2013 11:50 AM |
