go_a_way1, MisterSheep, Sarlacc, Tcoat
Old 01-22-2016, 03:41 PM   #71
FRSCanuck
Drives: Scion FRS
Originally Posted by CxG View Post
Questions about your oil cooler and set up.
What mounting location did you use?
What version of the kit are you using?
Where did you mount the oil cooler?
How does it do in winters for warm up?
Do you track and monitor oil temps, air intake temps, ambient temps?
I really would love to know how it does for a daily that sees winter but gets tracked hard on a hot day. Any info greatly appreciated.
mounting location of what?
i have the V2 kit with the injector upgrade
Note that HKS sells 2 versions of the oil cooler, one for N/A setups which mounts in front of the rad and the other for FI setups which mounts in front of the passenger wheel (i got the FI unit).
i'm lucky enough to have a beater so the car is stored during the winter months
Yes! i have oil temp/pressure and a boost gauge
the car is fine as a daily, only times i would have issues is when i'm stuck in bumper to bumper traffic for hours on end but it would never get to a point where i have to pull over to let the car cool off. On the track, it does get hot near the end of a 15min session but every car gets hot at the end of the session.
FRSCanuck is offline   Reply With Quote
The Following User Says Thank You to FRSCanuck For This Useful Post:
CxG (01-22-2016)
Old 01-22-2016, 03:58 PM   #72
CxG
Drives: Pearl White '13 ZN6
Ah sorry the mounting location I was talking about was for the oil cooler lol asked it twice
It's good to know that the FI kit works well on the track and in traffic.
2 more questions
1) after installation if some one wanted to make some ducting into the wheel wells would there be room with FI oil cooler that you have
2) if someone got the FI oil cooler and then went with the HKS supercharger would parts of the oil cooler need to be uninstalled to mount the SC properly?
Thanks for all the help and quick response I greatly appreciate it!
Sent from my D5803 using Tapatalk
CxG is offline   Reply With Quote
Old 01-25-2016, 09:46 AM   #73
FRSCanuck
Drives: Scion FRS
2 more questions
not 100% sure as i've never tried, here's a pic of the setup so you get a better idea
only thing i can think of is uninstalling the oil lines prior to installing the s/c
CxG (01-25-2016)
Old 01-25-2016, 01:13 PM   #74
CxG
Thank you, you've been a great help!
Old 01-26-2016, 03:00 AM   #75
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
Originally Posted by spdbydesign View Post
What is the cost of the HKS S/C Kit?
What does the kit make HP wise maxed out?
Our $2999 base kit w/ Custom Ecutek Tune is capable of 450whp with fuel upgrades.
$4100 with their standalone tuner. i believe around 270whp on pump and 320whp on e85 on base maps I've seen around 400-420whp on the kit.
wise345 is offline   Reply With Quote
Old 01-26-2016, 11:43 AM   #76
Scott@HKSUSA
Scott@HKSUSA's Avatar
Drives: 2013 FR-S, HKS V2 S/C
We haven't had anyone "max out" a 7040L on a FA20 yet but it's essentially a belt-driven 59 lb/min turbo. ~59 lb/min on a 2.0L is enough air for ~450 hp at the crank on gas. We have S2k guys at that level with this blower, I'm sure the FA20 crowd won't take very long to catch up. Do you have a comp. map for your turbo so we can compare apples to apples?
Scott@HKSUSA is offline   Reply With Quote
Old 01-26-2016, 11:50 AM   #77
spdbydesign
spdbydesign's Avatar
Drives: 2010 Nissan GTR
I prefer physical results, which we publish near daily in our Facebook Owner's Group. (You are welcome to join!)
There are 744 members in the group as of this morning and growing everyday
There are LOADS of customers & dealers with our kits making 400+ whp.
Our new 58mm Inducer Garrett Ball-Bearing (GTX3076R Sized, Custom Billet Compressor Wheel) turbocharger just released. I expect to see several making over 500whp with that option this year on built motors.
SHIV @ OFT is about to release his new E85 tunes for this kit, and you're going to see a wealth of people making above 400whp.
Stay tuned!
spdbydesign is offline   Reply With Quote
The Following User Says Thank You to spdbydesign For This Useful Post:
MisterSheep (01-26-2016)
Old 01-26-2016, 12:02 PM   #78
Scott@HKSUSA
That's awesome and you should be proud of all your accomplishments!
I was just curious if you had a compressor map for your turbo so anyone reading this thread could compare. That's all.
Old 01-26-2016, 12:04 PM   #79
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Stay tuned!
We have a member of Norcal86 who has been running a custom E85 tune by shiv and he's making 450whp on the SBD kit
Instagram: trevor.parque
spdbydesign (01-26-2016)
Old 01-26-2016, 12:10 PM   #80
spdbydesign
The main issue, is up until this point, E85 users have been limited to Ecutek.
Shiv @ OFT has not supported ethanol tunes for their device with this kit.
But I'm happy to announce Shiv is currently finalizing his calibration and will have dyno data to share soon.
Since he owns the kit personally, on his personal car, this has expedited the process of his E85 tunes.
400-450whp is going to be par for the course in 2016 with our customers, can't wait!
Old 02-19-2016, 01:09 PM   #81
wise345
wise345's Avatar
Late response but any idea when shiv is expected to released OFT E85 tune for the kit?
2013 Rocketbunny V2 FRS
Ag Wheels x Airlift x SBD Turbo x Seibon x Nardi x Spec D x Valenti
Old 02-19-2016, 01:31 PM   #82
spdbydesignchris
spdbydesignchris's Avatar
Drives: 2013 BRZ Premium
I'm not exactly sure, as he's independent of SBD, but I'm sure he's eager to make money....so it will be sooner than later
spdbydesignchris is offline   Reply With Quote
Old 02-20-2016, 01:12 PM   #83
wise345
wise345's Avatar
I've decided on your kit and will order soon unless something happens and I want e85 but don't want to stick with my OFT!
Old 02-20-2016, 02:15 PM   #84
spdbydesign
Lots of companies provide Ecutek tunes for this kit.
:popcorn:, why not?
HKS Supercharger V2 vs. Greddy Turbo Kit vs. Crawford Turbo Kit Ogremair Forced Induction 27 09-10-2015 05:39 AM
Supercharger vs Turbo MPG ? LoCo Forced Induction 23 06-27-2015 06:24 PM
Which is better turbo or supercharger? Ryan_FRS86 Forced Induction 94 05-18-2015 01:26 PM
Looking for a turbo or supercharger kit!! Anthony7515 Want-To-Buy Requests 11 05-16-2014 09:25 AM
HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! rickspecd Forced Induction 4 07-12-2013 12:50 PM
