#281 | |
[/IMG]i just checked an OFT 700C Stage 2 rom and its there, make sure to use the appropriate OFT Defs from here for your calid http://www.ft86club.com/forums/showp...&postcount=411 the OFT Zip files is what youre looking for, and just the right one for your calid. just confirming you do use OFT to flash ? and what is your calid? |
#282 |
Drives: BRZ Limited; GR86
did you guys change the values for 7600 rpm? My 91 only went up to 7400. now my e85 goes up to 7600
#283 |
Drives: 2013 brz limited
Just test stg2 UEL on my car, there are pops between 2500 to 3000rpm, but if I go over than that, no pops... Borla v2 UEL, Motiv HFC front pipe, invidia N1
#284 |
Inactive
Drives: .
Yup that sounds about right, as I recall a few people saying they couldn't get anything above 3500rpm usually.
#285 |
Drives: Subur / Scion
that really great man thanks for the info and video. Great stuff really.
#286 | ||
Sent from my LG-H812 using Tapatalk |
#287 |
Drives: 86
Hi, what about this?
![]() Overrun Fueling RPM Resume Threshold will rich out the AFR from 7000rpm. Base Timing Idle (In-Gear)(Above Threshold) will retard the ignition until 1000rpm. This should bang-bang until 1000rpm if you just lift your foot. Last edited by denso; 02-22-2016 at 01:36 PM. |
#288 | |
Try it out
Yeah its an auto, deal with it.
#289 |
Drives: 86
Yea I will but my car is logged out atm until march....
damn winters in germany
#290 | |
Is that safe? Sent from my iPhone using Tapatalk |
#291 |
Drives: 86
I dont know, I didnt test it yet.
This should be the tables we are looking for in my opinion. It seems logical. I'll try it if I get my car back out of its sleep. I talked to a friend of mine (MTR Performance, check out at facebook!) Hes very good at VAG Software (Audi TTRS, Golf 6R/7R,...) VW Golf 7R e.g. are using this kind of overrun settings and the cars are sounding great at decelleration. |
#292 | |
#293 |
Drives: GT86
The overrun function is working perfectly. Just set the RPM delta to -10 or whatever and set a desired angle in the Base Timing Idle (in gear) table.
Unfortunately it seems that the pops and bangs trigger the knock sensor and the IAM is constantly kept at 0
#294 | |
IAM steady @ 1 after a couple hundred kms Sent from my LG-H812 using Tapatalk |
| rom tuning for pops and backfires | andrew5826 | Software Tuning | 110 | 12-23-2016 04:39 AM |
| First romraider defs are up | jamesm | Software Tuning | 95 | 01-13-2015 05:29 AM |
| Transient Ignition Retard Tables from RomRaider | Ralph Spoilsport | Issues | Warranty | Recalls / TSB | 31 | 05-24-2014 07:48 AM |
| OFT-Help with Romraider/FFS and Launch Control-issues | continuecrushing | Software Tuning | 9 | 04-17-2014 11:07 PM |
| Possible backfires | Bg8780 | Engine, Exhaust, Transmission | 0 | 05-22-2013 02:12 PM |
