Old 02-16-2016, 04:39 PM   #29
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Originally Posted by swarb View Post
The only reason why I would want a key is if the battery ever died and I could push start/clutch start it. Not sure if it would work with the keyless versions of these cars.
Don't worry - even with the key, you probably won't be able to push start it.
Apparently, the HPFP means that our cars, regardless of key fob or transmission type, will not allow bump-starting.
I tried for half an hour when my car wouldn't start a few weeks ago in an indoor parking garage, and the CAA guys basically said "don't bother"
If I'm not mistaken, the manual also says bump-starts are a non-starter (giggle).
daiheadjai is offline   Reply With Quote
Old 02-16-2016, 04:49 PM   #30
Scott@HKSUSA
Scott@HKSUSA's Avatar
Drives: 2013 FR-S, HKS V2 S/C
Keyless + a sequential style automatic shift lever REALLY screws with people.
http://www.roadandtrack.com/new-cars...sler-shifters/
I don't know about you guys, but I get so excited whenever I reach my destination that I just fling the door open and jump out. "Yay. My Jeep made it to point B!"
Scott@HKSUSA is offline   Reply With Quote
Old 02-16-2016, 05:22 PM   #31
I have no trouble bump-starting mine. Easy-peezy.
daiheadjai (02-16-2016)
Old 02-16-2016, 06:26 PM   #32
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Originally Posted by PandaSPUR View Post
I could be wrong, but doesnt our car have sensors both on the inside and outside so that certain features are locked depending on where the car thinks the key is at?
So a signal amplifier attack like that could allow a person to unlock your car, but you shouldn't be able to start it. I needa double check the manual later, but I think thats how it works.
This. In addition, the pad to unlock the doors on the handle won't work if it thinks the key is inside. If someone amplified the signal too much it wouldn't even unlock the doors. I guess a more effective attack would be to intercept and then clone the signal off the driver. Akin to remotely reading the magnetic strip from a credit card.
Old 02-16-2016, 07:27 PM   #33
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
edit: Oh well. This won't help shut off the engine but still...
The Following User Says Thank You to Packofcrows For This Useful Post:
Ultramaroon (02-16-2016)
Old 02-16-2016, 08:03 PM   #34
daiheadjai
daiheadjai's Avatar
In fairness, I only tried it a couple times - and I was trying this on level ground with limited room to maneuver. Pushing it back into my parking space to wait for CAA for a boost = not a whole lot of fun.
Did you make use of a hill or anything?
Old 02-16-2016, 10:40 PM   #35
Oh, It'd be impossible alone without a good long running start. I have a congested on-ramp where I shut down at the top and inch my way down. I bump-start out when it's my turn.
I've never had a car with such a tight engine. The compression is unbelievable.
Old 02-16-2016, 10:50 PM   #36
Originally Posted by Packofcrows View Post
You've shared some of your thoughts. It's scary in there!
LED keyless start BRZ PLEASE HELP natasharae36 Cosmetic Modification (Interior/Exterior/Lighting) 0 06-17-2015 08:08 PM
FRS MONOGRAM KEYLESS nickhabi Scion FR-S / Toyota 86 GT86 General Forum 3 08-02-2014 05:13 PM
Do we really have keyless entry? ZackZ Scion FR-S / Toyota 86 GT86 General Forum 4 10-22-2013 10:04 PM
Keyless Locking bdbx18 Electronics | Audio | NAV | Infotainment 4 12-16-2012 05:38 PM
Keyless ignition for my FRS Gixxersixxerman Electronics | Audio | NAV | Infotainment 1 11-30-2012 11:09 PM
