Old 02-14-2016, 04:56 PM   #15
stevesnj
stevesnj's Avatar
Keep it on a 2amp charger for about 6-10 hours then the next day repeat the process. This should descale and get you back up to charge. Make sure your water level is at the Max line and ONLY use distilled water to top off. An alternator is not the way to charge a battery since it will not properly charge a battery even if you drove around for hours.
My 2016 Build thread
Old 02-14-2016, 04:58 PM   #16
BlueSTaR
BlueSTaR's Avatar
Drives: 13 BRZ Limited & 16 Hyperblue
My wife had a defective battery. Subaru swapped it out.
BlueSTaR is offline   Reply With Quote
Old 02-16-2016, 04:28 AM   #17
TruckTruck
Drives: 2013 frs, 2014 frontier
I think I will look into a tender, the next question is will it hurt to pull the battery because I will have to keep the battery and tender in my apartment.
TruckTruck is offline   Reply With Quote
Old 02-16-2016, 07:03 AM   #18
jarnojvv
jarnojvv's Avatar
Drives: 86|Fortuner|FJ|Mustang|SwiftSport
Nope, use the right tools, open the cells slightly and ventilate while charging.
-JvV-
jarnojvv is offline   Reply With Quote
Old 02-17-2016, 12:15 PM   #19
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
no problem at all.
just you need to carry battery around
also it's resetting all your setting like ECU, radio, etc
Old 02-17-2016, 12:28 PM   #20
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
This is not entirely true.
It IS true that you should not allow your alternator to recharge a completely dead battery as this can stress the alternator.
However, if the battery was "just a little too low to start the car" (but it still cranked), then it is perfectly OK to jumpstart the car then recharge the battery using the car's alternator by driving for a few hours.
It is NOT ok to Jump-start a car with a completely dead battery and THEN let the car recharge the dead battery.
In that case it is best to put the battery on a low current charge and leave it for 24-48 hours (disconnected from the car is best)
Walmart sells a $20 maintenance charger that seems to work well for long term storage but they typically will NOT recharge a dead battery.
justatroll is offline   Reply With Quote
The Following 2 Users Say Thank You to justatroll For This Useful Post:
stevesnj (02-17-2016), zc06_kisstherain (02-17-2016)
Old 02-17-2016, 12:42 PM   #21
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
I have been storing my car for the winter in a heated garage. I wanted to just start it every weekend to make sure fluids moved around and battery would get charged. However I forgot about it for a month or 2 and the battery was dead, no problem just jumped it and ran it for a while no issues. Week later its completely dead again. Is this just cause its sitting for a week or bad battery. This is the first car I have ever stored so I wouldn't be surprised if I am missing something.
You shouldn't be starting it unless you are taking it out and driving it
oil will not reach temp just idling, and you will create more issues
either take the battery out (like you said) or hook up battery tender in the garage ( thats what i did, ran the tender underneath so i can close the hood properly and use a cover )
There is countless threads about winter storage, really depends on how in depth you want to go
you may be able to salvage your battery now by using a trickle charger or tender (difference: trickle constantly applies low voltage, tender monitors voltage )
I'm not a professional by any means, this is the info I gathered from the internet
BlueSky is offline   Reply With Quote
Best two way dash cam that uses car battery and it's own battery? azynneo Electronics | Audio | NAV | Infotainment 14 01-22-2016 11:23 PM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 01:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
Battery tray for Braille 21lb battery? lordtakuban Engine, Exhaust, Transmission 4 09-10-2013 09:55 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 04:59 PM
