Drives: 2014 Scion FR-S, 1998 Honda Accord
CEL P2109 P2119
I was trying to start my car and I realized that I had two CEL codes. Used an OBDII and found out I had these two codes. P2109 - Throttle/Pedal Position Sensor A Minimum Stop Performance and P2119 - Throttle Actuator Control Throttle Body Range/Performance. Anybody have any idea whats wrong and how I can go about fixing it? Thanks in advance.
EDIT: this issue that I am specifically facing may be related to a crash. Other thread link: http://www.ft86club.com/forums/showthread.php?t=101580 Last edited by driftking96; 02-15-2016 at 07:22 PM. |
#2 |
You might try taking off the negative battery terminal for a minute ... then re-clamp it.
That will reset the ECU and maybe the codes won't come back. Maybe it tossed the codes because of the cold ...... it just sneezed. OR ....... maybe: http://www.autocodes.com/p2119.html humfrz Last edited by humfrz; 02-15-2016 at 02:42 AM. |
#3 | |
Sent from my ONE A2005 using Tapatalk |
| The Following User Says Thank You to driftking96 For This Useful Post: | humfrz (02-15-2016) |
