MisterSheep
Old 02-15-2016, 05:03 PM   #1
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Science behind the different strut bars?
Has there been a thread yet that goes over all of the differences between the strut bars that are available for this car? I saw the TRD carbon fiber one and starting thinking to myself.. Wouldn't that not create much of a difference? I know it's carbon fiber, while carbon fiber not being flimsy like paper, but would it perform less than lets say the Cusco bar where it's thicker, probably sturdier, and has more points of contact to the strut towers. I'm guessing it's another, pay for the name, part huh?
Instagram: trevor.parque
Old 02-15-2016, 05:06 PM   #2
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
It's a pretty small improvement, regardless. The tiny strut bars that we have from the factory do a pretty good job. I went with the Grimmspeed because it was priced right, and has an almost OEM look about it.
jawn is offline   Reply With Quote
The Following 2 Users Say Thank You to jawn For This Useful Post:
Brzzee (02-20-2016), MisterSheep (02-15-2016)
Old 02-15-2016, 05:10 PM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Well I can tell you that you want something that goes completely around the strut tower. I think you want ones with hinges too for performance, but honestly this part makes such a little difference in handling I haven't looked much into them lol
Old 02-15-2016, 05:13 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
tortional flex on the carbon one will be better (stiffer) but points of contact are probably just as important as material used.
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post:
go_a_way1 (02-15-2016), MisterSheep (02-15-2016)
Old 02-15-2016, 05:50 PM   #5
DAEMANO
Time Traveller
Hysterisis...
I've posted this a few times. It goes into some detail about the thoughts behind the BRZ tS (including its' strut bar).
http://www.motortrend.com/news/subar...s-first-drive/
....Hysteresis is the lag between when the steering wheel of a vehicle is turned and when the vehicle actually begins to turn. Reducing hysteresis has been achieved in sports and race cars by increasing body rigidity via traditional braces and stiffeners. Slop in the chassis from soft springs and rubber bushings can be lessened via harder durometer substitutes, including solid mounts or metal spherical bearings (which the tS also has in the rear suspension linkage). These provide little to no give whatsoever but then introduce other problems, chiefly harsh ride quality, as road vibrations have nowhere to dissipate but up through the seat, steering wheel, and ultimately the driver’s fillings.
This is where the innate flexibility of the BRZ’s chassis and the controlled flexibility of the tS parts seem to work together. STI engineers explained that the flexible strut tower brace and draw stiffeners promote rigidity only in certain directions. The spherical bearing equipped strut tower brace apparently adds structural support across the shock towers for great steering response while also allowing for a bit of vertical movement that is key for maximum tire contact, and a smooth ride...
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
8R6 (02-22-2016), MisterSheep (02-15-2016)
Old 02-15-2016, 06:23 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
^^ that engine bay looks familiar...
DAEMANO (02-15-2016)
Old 02-15-2016, 06:33 PM   #7
DAEMANO
Time Traveller
You get all the good shit.
So jelly...
Old 02-15-2016, 07:02 PM   #8
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
I haven't tried others, but I have the TRD bar, and I can say there's a positive difference in feel and response.
I'd imagine it'd be quite difficult to compare, measure, or even feel the difference between different brands. Only way to find out is to try them all back-to-back lol. I'd just get any one that you can trust is a quality piece, such as GrimmSpeed, Beatrush, Cusco, STI, or TRD.
Old 02-20-2016, 06:04 PM   #9
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
You would want a strut without hinges... Drive a car with a Grimmspeed vs Cusco, and you can tell a difference. I have a Grimmspeed bar.
Old 02-20-2016, 06:21 PM   #10
I don't ever plan on running a bar because I am firmly in the placebo camp.
That being said, don't even bother considering anything that doesn't transmit the axial load in a perfectly straight line with the least possible moment couple between the tower and bar end. The mounts must be super stiff in reaction to the cantilevered load.
jarnojvv (02-20-2016), Tor (02-21-2016)
Old 02-20-2016, 06:52 PM   #11
ryoma
ryoma's Avatar
I had always thought that strut tower bars over the engine is pretty much useless since you have the engine bolted in there. am I wrong?
Old 02-20-2016, 10:59 PM   #12
Kostamojen
Drivetrains are not part of the structural rigidity of most cars.
Old 02-20-2016, 11:05 PM   #13
boredom.is.me
Custom User Title
I'm big on the placebo thing too. Most people put a filter on and feel like they just got a shot of nitrous. I honestly can't say the same for the GS STB though. Just being honest. No it's not a, "OMG NO WAY, THIS IS TOO REAL!!!!"
The Following User Says Thank You to boredom.is.me For This Useful Post:
Ultramaroon (02-20-2016)
Old 02-20-2016, 11:49 PM   #14
Haha... I'm with you. The GS looks legit; straight and to the point. It won't transform the chassis into an Ariel Atom but I'm sure it's noticeable.
Strut tower bars? MattHoffman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-08-2015 10:56 PM
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 05:41 PM
WTB: Cusco strut bars Trashed675 Brakes, Suspension, Chassis 1 04-24-2013 07:40 PM
FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! NJA Brakes, Suspension, Chassis 18 04-07-2013 06:00 PM
Strut Bars? Which is best? DriftEightSix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-02-2013 08:48 PM
