Old 02-10-2016, 04:38 AM   #15
FRS Justin
Drives: 2013 Asphalt FRS
After everyone post there ideas I will be taking them to businesses I know can make it happen lets shoot for 2 or 3 pages and I will get the ball rolling to see what or if I can make some of this happen...
I'm impressed with everyone's ideas to the point in personally investing in developing some of the ideas posted. Maybe I can get a production of 10 to 20 of some of these items and do a group buy to keep cost low. I will post pics of some of the items to get input before a production run.
It's going to take some time but what else do I have to do.....
Of course I will follow the forum rules for venders if or when that time comes. Thanks everyone
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following 2 Users Say Thank You to FRS Justin For This Useful Post:
Bonburner (02-10-2016), go_a_way1 (02-10-2016)
Old 02-10-2016, 05:52 AM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
* Also .. lift spacers & if needed, extra hardware (eg. longer bolts), that are made to ensure to work & fit with most popular cascam plates. Be it raceseng, rce, or whichever else. Made of several 5m or 1/4" thickness plates that can be stacked to get needed hight.
* different brake cooling back plates like these for most popular BBKs (sprint kit/willwood/RR/stoptech/APR/brembos/stock ..)
* +1 to "Better yet, something that can fit some wheels/tires, jerry can, jack, tools would be awesome!" - i see it in form of something that can be inserted inside space saver wheel. Should have space for small fire extinquisher, tools, first aid kit without taking any boot volume to mount those. When designing this one needs to think of:
1) ease of removal (if/when one needs this wheel in case of flat tire or removal for weight reduction prior trackday)
2) good securing of items inside so that they doesn't rattle on bad roads
* OBD angled connector with on/off switch for multiple wifi modules/OFT and optionally two or more selectable output ports (IIRC they cannot work at same time), so that one can simply switch off OBD devices to not drain battery and so that one doesn't have to damage port with frequent plug in/out.
* Some quietening kit for most common rattle sources in this car. For example for rear seat U latches, some velcros to fix tooling foam pieces in place (but allow removal if needed)
* thin metal sheet or cheap replaceable thin plastic front bumper underside protection (not full engine pan, just something to bolton from below of stock bumper to not scrape it on eg. cerbs/thick snow/ice between wheeltracks). Thought of something like this, but covering whole bumper underside starting from very edge of lip and thinner, maybe even slightly angled up in front of bumper's front lip to ease sliding above/over, not breaking off, not just something at very lowest point of bumper. It:
1) should be cheap (so that easily replaceable if damaged)
2) should fit stock brz / fr-s bumpers
3) no aero. There are lot of frontlips/splitters in market already. Make someone just for protection of stock.
4) thin. To not reduce already low clearance. If sliding off the track into snow pile something thick can increase chance of damaging bumper or scratching ocasions in general. Especially on lowered cars.
5) made of 2-3 pieces to reduce shipping packaging dimensions
6) unpainted to reduce price, and to not worsen looks in cases of scraping
One of variants i also had in mind - maybe instead of thin metal some precut thicker protection film (not for whole bumper, just underside).
Dream20b (02-13-2016), go_a_way1 (02-10-2016)
Old 02-10-2016, 06:40 AM   #17
twag4
Drives: frs
Rear bumper diffuser section (that matches OEM black bottom part of the bumper) that eliminates the awkward hole for the reverse lights/rear fog light triangle- for turning tails into turns and turn signals into reverse lights.
twag4 is offline   Reply With Quote
Old 02-10-2016, 08:03 AM   #18
churchx
churchx's Avatar
Drives: 2014 GT86
twag4: i'd insist that it still may house stock rear lights though. So that said diffuser section may be universal for all countries, including ones where regulations require all stock equipment to be still installed and working, not for limited countries with more relaxed regulations, or 'for offroad use' only.
Bonburner (02-10-2016), FRS Justin (02-10-2016)
Old 02-10-2016, 09:07 AM   #19
Ashikabi
Ashikabi's Avatar
Under tray should have a how for oil drainage whether plug or fumoto valve
The Following User Says Thank You to Ashikabi For This Useful Post:
Old 02-10-2016, 09:40 AM   #20
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
A proper rear end/ fake diffuser replacement that works with a future super quiet ACE muffler with single exit. Lotus style.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
The Following 2 Users Say Thank You to MaximeT For This Useful Post:
FRS Justin (02-10-2016), Shark_Bait88 (02-22-2016)
Old 02-10-2016, 09:54 AM   #21
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
A million times this !!!
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
The Following User Says Thank You to olsonpg For This Useful Post:
Old 02-10-2016, 09:56 AM   #22
olsonpg
olsonpg's Avatar
We need a phone app too! To make out forum addiction more accessible.
Old 02-10-2016, 10:07 AM   #23
Ashikabi
Ashikabi's Avatar
We have this. It's called tapatalk. It sucks
The Following 3 Users Say Thank You to Ashikabi For This Useful Post:
FRS Justin (02-10-2016), lamawithonel (02-11-2016), nickmerronesucks (02-10-2016)
Old 02-10-2016, 12:48 PM   #24
kch
Senior Misanthrope
kch's Avatar
Side pipes. I want to pretend I drive a viper.
Although I'm too low to fit them
The Following 2 Users Say Thank You to kch For This Useful Post:
FRS Justin (02-10-2016), go_a_way1 (02-10-2016)
Old 02-10-2016, 01:23 PM   #25
Ashikabi
Ashikabi's Avatar
Put them out the fake side vents
Bonburner (02-10-2016), FRS Justin (02-10-2016), JohnJuan (02-11-2016)
Old 02-10-2016, 01:53 PM   #26
Icecreamtruk
Drives: Track preped NA FRS
Rear diffuser
A rear diffuser. I know there are tons out there, but those usually go under the stock diffuser and below the exhaust. The one I would be interested into would replace the stock diffuser plastic, only on the center, and would leave enough space for the exhaust to poke out. Either dual or single exit or give the option of where to get the exhaust exit. Something like this photo, but with space for an exhaust on each side.
Icecreamtruk is offline   Reply With Quote
The Following 3 Users Say Thank You to Icecreamtruk For This Useful Post:
FRS Justin (02-10-2016), MaximeT (02-10-2016), olsonpg (02-10-2016)
Old 02-10-2016, 02:08 PM   #27
twag4
Drives: frs
Me too. Just want the bottom black part to not have the stupid hole that holds the reverse lights and rear fog light. We don't get anything but a stupid red triangle with no fog light in it in the US. It is stupid. I wouldn't mind just to cut out the black part, and have something to go in its place, using the factory painted part.
The Following User Says Thank You to twag4 For This Useful Post:
Old 02-10-2016, 03:23 PM   #28
churchx
churchx's Avatar
Drives: 2014 GT86
twag4: in such case - rear diffuser/insert that looks single piece from outside, but has grooves from inside, so that one can easily cut out for mounting stock lights there. = same diffuser that can be used without changes world-wide.
EDIT
Hmm .. thinking about this more .. why not make 3(!) originally closed exhaust cutouts in this same fashion as for lights? So that this difuser can be used for single right, single left, dual and single centered exhaust exits with looking stock-ish with any combination of exhaust exits?
Selling BRZ, parting out parts (STI, Toms, TRD parts) ucsmfu Canada Classifieds 32 09-16-2015 12:17 PM
Edirb racing seats (manufactured by Bride racing) DavidBob Other Vehicles & General Automotive Discussions 7 08-21-2014 01:25 PM
Buying computer parts compared to suspension parts Anomie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 12-09-2013 11:56 AM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 10:30 AM
