Old 02-09-2016, 08:56 PM   #1
mcbrawr
Drives: 2014 BRZ Limited
Final Drive + 18" Wheels?
Tax refund coming in, plan on getting FD and some new wheels/tires. Not sure if this question has been asked before SO here goes nothing.
Ideally 4.67 seems to be the FD most suited for my needs. Weir only sells 4.56 & 4.88, and I refuse to pay 2.5-3x the price for MFactory gears. If I were to get 18" wheels and the 4.88 FD, would that put me around 4.67 because of the wheels making the gear ratio longer? Or would the difference in diameter drop me below the 4.56?
'14 BRZ Limited | SBD500X + HRI Tuning | Tanabe Concept G Exhaust | XXR 527 18x8.75 | Hankook Ventus V12 EVO2 245/40/18
mcbrawr is offline   Reply With Quote
Old 02-09-2016, 10:32 PM   #2
steve99
Drives: FT86
will depend on the profile and width of the tyres you put on the wheels ie the amount of rolling diameter change over stock tyres, as well as final drive ration selected.
Old 02-09-2016, 10:35 PM   #3
mcbrawr
4.88 with 235/40/18 or 225/40/18
Old 02-09-2016, 10:39 PM   #4
stevo585
Drives: White 2014 BRZ
Look on tire rack they give you the diameter. I have 245/35r18's all around and they are the same diameter as stock. Which is the primary reason I went with that size.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 02-09-2016, 10:44 PM   #5
mcbrawr
So what outer diameter should I be aiming for to drop the overall gearing of the car to a 4.67 range?
Old 02-09-2016, 10:56 PM   #6
stevo585
Something narrow and like 16" wheels. Not really feasible or cosmetic. Most tires decrease the final drive.
Old 02-10-2016, 01:28 AM   #7
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
If you were one of those kids in high school math thinking to yourself, "I'll never use this, why do I need this, this is so stupid!" I bet you're kicking yourself now.
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
swarb (02-10-2016)
Old 02-10-2016, 02:22 AM   #8
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Why not 16s or 17s?
Carlitoz3 is offline   Reply With Quote
Old 02-10-2016, 03:22 AM   #9
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Warning! MATHS inside
The difference between 4.88 and 4.67 is about 4.3%. Using the tire size calculator at http://www.1010tires.com/Tools/Tire-Size-Calculator I found, strangely enough, that 215/45/18 is the closest, (the exact same profile as stock, only 18" instead of 17"). It comes in at 4.06%. Putting you at 4.68, rather than 4.67. Does that answer your question?
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
Old 02-10-2016, 09:00 AM   #10
mcbrawr
Haha, ironically I am an engineer and graduated 1-2 courses short of a mathematics degree as well. EE's don't know anything about gearing is all!
The Following 2 Users Say Thank You to mcbrawr For This Useful Post:
Freeman (02-10-2016), Hyper4mance2k (02-10-2016)
Old 02-10-2016, 09:26 AM   #11
swarb
Numbers are still numbers.
What wheel size are you planning on running? widths/offsets?
How low do you plan to go?
And how much power/grip do you have and want?
245/40-18 is a pretty good size, but would be slightly shorter(bigger number) than 4.67 gears. Just beware if you go too low, since you are planning to get a bigger diameter tire, there will be less room in the wheel wells.
And how did you come to the conclusion that 4.67(or 4.88 with taller tires) is the setup you are after?
The Following User Says Thank You to swarb For This Useful Post:
Old 02-10-2016, 11:20 AM   #12
mcbrawr
18x8.75 +35
1" drop (Eibach Pros)
Stg 2 OFT beta tune (~200whp 93oct)
I looked at the RPMs I would be hitting in 70 on the highway at 4.56 and 4.88, and somewhere in the middle is a happy medium.
Old 02-10-2016, 11:44 AM   #13
swarb
18x8.75 +35
So you want to get the 4.88 and a bigger diameter tire to emulate the gearing of a 4.67.
As mentioned above, 4.88 to 4.67 is about 4.3%
215/45-17 compared to 245/40-18 is about 4.3% also. (Reconfirm yourself)
So that IS the tire size you need. 245/40-18.
Good luck and thank me.
The Following 2 Users Say Thank You to swarb For This Useful Post:
mcbrawr (02-10-2016), Spectre20 (02-10-2016)
Old 02-10-2016, 12:19 PM   #14
Spectre20
Spectre20's Avatar
Drives: 2013 BRZ Limited
Interesting thread. I'm about to do the same exact thing but never really thought about how much the wider wheel/tire diameter would effect the aftermarket final drive.
Spectre20 is offline   Reply With Quote
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 01:49 PM
WTB: 4.56 Final Drive jaorocks1 Want-To-Buy Requests 0 11-04-2015 08:36 PM
3.3 Final drive? Manji Engine, Exhaust, Transmission 18 01-01-2015 03:51 PM
Saturday 3/23 DRIVE: Last chance to drive "The Most Dangerous Road in California" PMok Northern California 173 05-02-2013 03:11 PM
Subaru BRZ First Drive Review by Automobile Magazine - "A Great Drive" Sport-Tech BRZ First-Gen (2012+) — General Topics 36 12-07-2011 04:13 PM
