Old 12-02-2011, 10:54 AM   #1
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
Post Subaru BRZ First Drive Review by Automobile Magazine - "A Great Drive"
Automobile magazine has a first drive up of the BRZ:
http://www.automobilemag.com/reviews...brz/index.html
Generally a rave but they knock the car on one characteristic I've been concerned about - steering feel from the fully electric-assisted rack.
First Drive: 2013 Subaru BRZ
December 02, 2011 / By Jason Cammisa
A half century or so ago, the car market was blossoming with sports cars. These were generally simple machines that were often unreliable and impractical -- and very often not particularly fast. They came with funny little names like MG and Triumph and Sunbeam and Alfa Romeo and Datsun, and their owners weren’t much concerned with zero to sixty. Or top speed. Or peak lateral acceleration. No, the cars had a simple task: to put a smile on your face.
Somewhere along the way, we’ve become lost. We’ve become obsessed with Nürburgring lap times and launch control, and modern sports cars are dying off. The Mazda RX-8 just breathed its last rotary breath. The Lotus Elise has retreated to its British shores. The Mazda Miata soldiers on, but generating nowhere near the sales numbers it once did.
And out of nowhere comes this (let’s be honest) totally doofus idea: Toyota and Subaru team up to build a rear-wheel drive, normally aspirated sports car. Oh right, Toyota, the purveyors of the Prius, plus Subaru, the company that makes turbocharged, all-wheel drive hotrods and a weird looking crossover thing that Melissa Etheridge fans adore? This was a recipe for disaster.
Out of the most disastrous recipes occasionally comes the most endearing dish, and this is one of those times. The BRZ is a delightfully fun car; a complete package that combines light weight and great handling with just enough power to have fun -- but not too much that you can only enjoy it for three seconds at a time.
For all the Internet armchair warriors complaining about the meager power output, let us be the first to say: the BRZ doesn’t need a turbo. It doesn’t WANT a turbo. And anyone who says the car should have a turbo is missing the point. Like the Mazda RX-8 and Miata, the Porsche 944 and original Boxster -- and all of those cars from decades ago -- the BRZ is fun because of handling, not because of a sledgehammer that hits when you mash the gas pedal.
The 2.0-liter flat-four engine produces 100 hp per liter, but it does so in a way unlike any other normally aspirated four-cylinder. It doesn’t rev to 8000 or even 7500 -- it’s not high-strung at all. Redlined at 7400 rpm, the flat-four soundtrack is mellow, and since the intake resonance tube pipes intake noise from only two cylinders into the cabin, it’s deep, staccato, and almost bi-plane in its exhaust note. There’s no screaming or wailing -- and once the tach needle moves past 2500 rpm, where there’s a big valve timing change, the torque curve remains effectively flat until just before 7000 rpm. It’s the flattest, broadest torque curve this side of an electric motor. This engine, code FA20, shares effectively no parts with the FB20, the 2.0-liter in other Subaru applications. It’s physically smaller than the other engines, and will be used only in the BRZ -- for now.
The six-speed manual transmission has a high-effort, short-throw shifter and a light clutch, and it’s a bit easy to stall the BRZ off the line because its flywheel weighs only 20 lb, some 9 less than an STI’s. The reduced reciprocating mass, along with the FA20’s shorter intake runners, means the engine responds more quickly to throttle blips, though, and the tradeoff is worth it. A six-speed Aisin automatic is optional; it can perform shifts with the torque converter locked, and blips the throttle on downshifts. It’s smooth, too. It’s great. But it’s the wrong transmission for this kind of driver’s car.
The BRZ, like so many other modern cars, uses electrically assisted steering. Subaru engineers say they went EPS for fuel economy and because it’s easier to tune than a hydraulic setup. They’ve done a fine job of tuning the effort -- it feels natural, building linearly with cornering loads. Like all EPS systems though, the additional rotational inertia of the assist motor dampens out most of the steering feel, and that’s a shame. Still, the rack-and-pinion system is highly accurate, and it’s quick, with an overall ratio of 13:1. The small (14.4-inch) steering wheel turns 2.5 turns from lock to lock.
The BRZ’s entire engineering mission was a low center of gravity and low polar moment of inertia (meaning that as much as possible of the vehicle’s mass is located inside the wheelbase and as low as possible.) Subaru says the BRZ has a lower center of gravity than everything but the Porsche Cayman R and 911 GT3, and that its polar moment of inertia is less than the (mid-engine) Porsche Cayman or Mazda RX-8.
While we certainly can’t verify those claims, after driving the BRZ on a handling course, we have no reason to doubt them, either. The BRZ turns in eeee-mediately with minimal, very well-controlled body roll. The front and rear of the car react in unison -- you never get the feeling that the two ends of the car are doing different things. The BRZ settles into steady-state understeer, but don’t let that fool you: the standard limited-slip differential allows you to nix that handily. Indeed under heavy throttle, the BRZ goes -- and stays -- neutral, and is incredibly easy to control at the limit. Breakaway at the rear is slow, deliberate, and progressive; the exact opposite of so many modern cars whose engineers seemed to only care about achieving maximum grip, not what happens when you exceed it.
Subaru made it very clear that the BRZ’s handling benchmark was the Porsche Cayman. We’re not sure exactly which benchmarks the engineers targeted, but from the wheel, we’re not feeling it. In lateral grip and turn-in response, sure -- but in chassis balance, the Porsche is in a different league. The Cayman exhibits slightly less understeer in terms of static balance, but the big difference is that the Porsche allows you to quickly and dramatically adjust the car’s line with the gas pedal. The BRZ won’t trailing-throttle oversteer; once it’s settled into a corner, the only way to adjust the line is to add power.
On the other hand, the BRZ is far, far easier to control because of it. To complain about the lack of corner-adjustability is unfair -- the Porsche is, after all, a mid-engine car that costs twice as much as the Subaru. That we’re even discussing them in the same sentence is a testament to how good the BRZ is.
It’s great in other ways, too -- it’s 9 inches shorter than the Cayman, but seats two additional people. The BRZ’s front seats are highly supportive and very comfortable, though the rears are for very short trips or very short passengers. Still, they’re there, and the rear seatback folds (as one piece) allowing enough room for a set of track tires, according to Subaru. That’s cool.
The steering wheel is adjustable for rake and reach, though even extended as far as it’ll go, it’s a long reach for long-legged drivers. And the pedals are spaced a bit too far for easy heel-and-toeing. Trunk space is meager, at 6.9 cubic feet, and Subaru made no mention of an available sunroof.
Not that we would have opened it on the course -- especially the high-speed oval. We saw an indicated 132 mph in the manual-transmission BRZ, and the 2.0-liter was still pulling. It seemed a long shot that it would make it to 143 mph, which is the estimated top speed an engineer gave us. On the other hand, a BRZ automatic couldn’t pull past 128 mph, and that same engineer estimates it will make it to 137 mph – so perhaps the track was headed up a slight grade. The manual transmission car should be able to hit 60 mph in just under 7 seconds; the automatic just over -- but there’s enough low-end torque to easily spin the 215/45-WR17 Michelin Primacy HP tires off the line.
Wait, wait, wait! The BRZ isn’t about the numbers! A sports car doesn’t need to look good in the stats box, it just needs to be a great drive. And the BRZ is a great drive. If you’re looking for smoking 0-60 numbers and crazy top speeds that you’ll never get to, there are certainly other cars that better fit your tastes. The BRZ needs a convertible top more than it needs a turbo -- because that, not horsepower, is the only thing holding this car back from being the modern-day equivalent of those wonderful 1960s sports cars.
Sport-Tech is offline   Reply With Quote
Old 12-02-2011, 02:53 PM   #2
Sabastian
will rain on your parade.
Drives: 2007 Mini Cooper, 1996 Mazda MX-5
I wouldn't worry too much about that. Steering feel is wildly subjective, much more so than most aspects of a car's handling. If it makes you feel any better, the EVO review praised the steering feel, saying that it was even better than the Porsche 911's electrically assisted system.
Sabastian is offline   Reply With Quote
Old 12-02-2011, 03:29 PM   #3
maximumunicorn
Drives: '05 Legacy
They definitely left some room under those fenders for wider tires (not too wide, mind you). Looks like this car is going to be great! Thanks Scion FR-S for posting this up!
maximumunicorn is offline   Reply With Quote
Old 12-02-2011, 03:31 PM   #4
Longhorn248
Hook 'em
Longhorn248's Avatar
Are these the first pics of the US spec BRZ? Seems to be the Limited trim level with the leather/alcantra seats and fog lamps.
Longhorn248 is offline   Reply With Quote
Old 12-02-2011, 03:31 PM   #5
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
looks to be the US spec, LHD with the cheaper nav option that shows on Subaru.com
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 12-02-2011, 04:52 PM   #6
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
And climate controls are in fahrenheit instead of celsius
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-02-2011, 05:02 PM   #7
KevinDuMa
Drives: 2004 Honda S2000
Could this also be the limited? It has half leather/alcantara seats, fogs, decklid, seat warmers?
KevinDuMa is offline   Reply With Quote
Old 12-02-2011, 05:08 PM   #8
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Interesting, a rather well articulated review. The writer seems to "get" the point of the car very well, along with the heritage and thesis a simple sports car is supposed to achieve: putting a smile on the drivers face.
I am at odds with the steering feel comment. First he says it's natural feeling, but then he claims he can feel the EPS motor damping the steering feel. So, natural, with a filter? I suppose that's better than artificial and jittery [MINI Coupe]. Combining that with EVO's comment about the steering feeling better than the new 911's EPS, that means the steering is good, maybe great, but not as amazing as a benchmark manual or hydraulic rack.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 12-02-2011, 05:21 PM   #9
ryun84
ryun84's Avatar
Drives: 04 PSM WRX Wagon
Wasn't it also mentioned somewhere that push-button start was Limited model only?
2004 WRX Wagon PSM. Link to my car journal HERE.
ryun84 is offline   Reply With Quote
Old 12-02-2011, 05:24 PM   #10
Speedjunkie
FR-S Ready
Drives: K24 RSX with Fully Built Head
Anybody notice that the last picture is a guy in the Scion FR-S? You can tell by the key in ignition and the HVAC controls(Scion Fuked up here)
Speedjunkie is offline   Reply With Quote
Old 12-02-2011, 05:24 PM   #11
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
No limited badge... but if it's true that there will be two versions, then I'd have to assume yes..
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-02-2011, 05:27 PM   #12
Speedjunkie
FR-S Ready
i hope scion has a limited version as well that gives P2S and better HVAC
Old 12-02-2011, 05:30 PM   #13
Dimman
Kuruma Otaku
Dimman's Avatar
Hmmm...
I want to see this curve badly now. And try to figure out what they did.
Because titanium.
Old 12-02-2011, 05:54 PM   #14
madfast
Drives: 2010 Evo X MR-T
yep. also look at the side mirror with camo on it. the last pic was definitely from an earlier event where they drove the prototype...
madfast is offline   Reply With Quote
brz review, brz reviews, brz test drive review, brz test drive reviews, subaru brz review, subaru brz reviews, subaru test drive review
Toyota 86 first drive review (Car Guide) a6ela Scion FR-S / Toyota 86 GT86 General Forum 22 03-14-2012 12:34 PM
Autoexpress Toyota 86 first drive review Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 14 12-30-2011 06:08 PM
Autocar Scans: Toyota 86 First Drive Review and Recap of Great Japanese Coupes Boxer-4 Scion FR-S / Toyota 86 GT86 General Forum 5 11-30-2011 06:23 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 05:58 PM
First Drive Review of Toyota FT-86 / Scion FR-S Mule! [Car magazine] Gabbo1976 Scion FR-S / Toyota 86 GT86 General Forum 201 11-01-2011 02:58 PM
