Drives: Whiteout RBv1 FRS
FRS front grill modification
So I like the look of some 86's without the front grill, but hate the look of the styrofoam painted or stock crash bar painted. So I'm wondering if anyone has any pictures of the front grill cut out below the solid section that covers the styrofoam/crash bar?
Poor photo shop example of my car to illustrate what I mean
#2 |
Drives: Asphalt 2015 FRS
An alternative to painting the foam or crash bar would be to swap out the crash bar for an aftermarket one (such as the beatrush option). Obviously this isn't as safe as the OE bar but racecar. They are more narrow so you can't see it from the grill area
#3 |
Yes I've considered that, it's an option. The plus side would be sweet Beatrush bling, downside would be an even bigger opening showing off my lack of FMIC or oil cooler haha
#4 | |
Drives:
Here mine... ![]() ![]() ![]() ![]() ![]() __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram | zeal.eightsix Last edited by zeal86; 02-10-2016 at 12:37 AM. |
#5 | |
You could also just switch out the entire grill for some kind of wire mesh from the home improvement store to switch up the look. I think the FRS looks good with the open mouth regardless of what it's filled with |
#6 | ||
Before I cut the stock one I'll definitely give it a shot with it totally out to see how I like itQuote:
#7 | |
Drives: frs
I would like to remove mine because it gettin dull. Clean build by the way |
#8 | |
Drives:
OP...I cut off and dremeled the tabs off the bumper that the grille mounts to as I did not plan on re-installing it. As long as you don't do that you could always go back if you don't like how it looks. __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram | zeal.eightsix |
#9 |
JHerbert Racing
Drives: 2013 Scion FRS
I'm loving the polished and powder coat idea. I will definitely be doing this with the remaining winter months.
| The Following User Says Thank You to Takumi788 For This Useful Post: | zeal86 (02-09-2016) |
#10 |
Drives: 2013 Raven FR-S
Use it as an excuse to go turbo. Can't go wrong with a polished or anodized black (what I will be using) FMIC...
Three pedals, six gears, and nothing but time.
#11 | |
Drives:
You don't even have to powder coat... I did because I was having some other things coated so I just added the brackets... you could just use duplicolor metal cast paints... duplicolor has many colors avaliable...this paint works pretty well at mimicking an anodized finish. Check it out. Painted tow hook with Duplicolor Metal Cast ![]() __________________________________________ projekt zeal86 build zeal.eightsix Facebook Instagram | zeal.eightsix |
#12 | |
Drives: BRZ. R34 GT-T
Heres a cheaper alternative to the Beatrush crash bar that I just ordered. http://www.enjukuracing.com/products...scion-frs.html Plan on giving it a shot of red for some extra bumper opening sweg for anyone that cares to look.
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
#13 |
Finally found someone who has the grill modified like I was thinking of doing. Since I have fogs now I think the leftover honeycomb would look out of place (IMO). Won't be doing it anymore
#14 |
Drives: Asphalt 2013 FR-S
Looks like the car has a big dirty buck tooth.
Build Thread: http://www.ft86club.com/forums/showthread.php?t=87104 // Save the fenders
| The Following User Says Thank You to BDotG For This Useful Post: | RedEdTed (03-15-2016) |
| Is the FRS front grill removal? | mit_peid | DIY (Do-It-Yourself) Guides | 23 | 02-27-2016 12:00 AM |
| front grill | PipeLovoo | Exterior Parts (Aero, Lighting, Etc.) | 8 | 05-28-2014 10:11 AM |
| front grill | PipeLovoo | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 05-21-2014 11:53 AM |
| BRZ Front Grill Photoshop | mikeTee | BRZ Photos, Videos, Wallpapers, Gallery Forum | 16 | 11-16-2013 05:18 AM |
| Front bumper grill. | |-Goku-| | Issues | Warranty | Recalls / TSB | 20 | 09-04-2012 07:42 PM |
