#281 |
Drives: GT86
I looked at my A00G definition file and the corresponding memory addresses do not match the ones given here. This will result in non functional tables... and most likely a bricked ECU if I would try to flash it.
Does someone have the correct memory locations for the tables for a A00G cal ID? |
#282 | |
Drives: UK GT86
.: Stealth 86 :.
#283 |
Drives: GT86
I am running a modified OFT Stg2 UEL A00G...
#284 |
Drives: FT86
#285 |
Drives: GT86
I think the calid is not the problem here. My ECU is an A00G so OFT lets me only flash A00G roms. I know that OFT uses newer version of the FW internally. But files are exactly the same content-wise (except checksums).
What I need are the locations of these 2 tables in my G rom, as the following addresses do not match it. |
#286 | |
Drives: UK GT86
.: Stealth 86 :.
#287 |
Drives: GT86
After some searching I just tried to change the calid on the posted defs...
![]() https://raw.githubusercontent.com/TD...R_ZA1JA00G.xml ... it worked ![]() From a difference analysis I saw that the "ecuid" has changed. Could this be a problem? And, is this definition otherwise compatible with current OTS 2.072 tunes? Just to be absolutely sure...
#288 |
Drives: GT86
Ah, as it looks the ecuid is the difference between A00G and A01G roms...
So I need to use the A01G definition for my "pseudo" A00G tune. Thank you ;o) |
#289 | |
Drives: UK GT86
.: Stealth 86 :.
#290 | |
Drives: Toyota 86 Turbo, Lexus NX300H
it works great . me and neighborhood are happy with this quiet start up mod. [ame]http://youtu.be/GwZuADpFoSc[/ame] -7 is good for me, and I'll test more timing next time. Tomei EL catless header Tomei overpipe modded full 60mm oe frontpipe HKS legamax sports cat back Last edited by Yobiwan; 03-08-2016 at 07:48 PM. |
#291 | |
Drives: '13 BRZ Ltd
If I load the A01C xml definition file from Wayno's zip then I will be able to edit those tables in my tune? And no weirdness/bricking will occur? |
#292 | |
Drives: FT86
#293 | |
DrivinginDreams...Cloud86
Drives: Toyota GT86
Can my tuner enable this in my next revision? I am in underground parking and I nearly go deaf on startup with my full 3" exhaust and UEL. Will this kill my cat?
#294 |
...Just add nauseum
Drives: 2003 (AP1) S2000
Yes he can, no it will not cause any harm.
There are many ways to displace.
-Spartarus |
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 02:14 PM |
| Cold weather knocking during start ups. | JDMenrique | Issues | Warranty | Recalls / TSB | 38 | 01-12-2015 11:53 PM |
| backfire at cold start | FreaQshoQ | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 10-16-2013 06:21 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
| Loud cold start and mpg drop since new | be6sti | Issues | Warranty | Recalls / TSB | 7 | 11-28-2012 01:35 PM |
