go_a_way1
Old 02-07-2016, 11:42 PM   #2983
swarb
Originally Posted by wildpandaz View Post
Should I run 18x8.5 +33 all around or put 18x9.5 +38 in the rear? Tire recommendation? Stock height for now but planning to drop maybe 3/4 inch or airlift in the future. Will I have any problems with this for now on stock height?
8.5 all around so you can rotate tires. You can always add a spacer. 9.5's don't fit well without coilovers.
Old 02-08-2016, 09:43 PM   #2984
wildpandaz
Drives: Scion Frs 2013
Originally Posted by ChrisP View Post
I am running 18x8.5 +33 offset at all four corners with my avid 1 av20s and I also have a 1" drop on trd springs. They are pretty much perfectly flush in the rear and the front pokes just the slightest bit.
I wouldn't go staggered unless you want more understeer.
Here are some pics:
http://www.ft86club.com/forums/showthread.php?t=101152
No rubbing?
wildpandaz is offline   Reply With Quote
Old 02-08-2016, 09:44 PM   #2985
wildpandaz
Spacers are for in case it rubs right? Do you know if it will rub?
Old 02-08-2016, 11:04 PM   #2986
swarb
No rub with springs unless you buy crazy big tires. Air suspension is a whole 'nother game.
Spacer not needed for the fronts at x8.5 +33. You can also use them in the rear for that staggered look.
Old 02-09-2016, 02:27 PM   #2987
ChrisP
No rubbing?
Nope not at all
ChrisP is offline   Reply With Quote
Old 02-10-2016, 07:04 PM   #2988
PollosHermanos
PollosHermanos's Avatar
Drives: 2014 SWP BRZ Limited 6SP
It is hard to say as every car is slightly different. +45 (enkei rpf1 17x9) fit but they can rub at full lock(at the swaybar) or if you add ANY camber(at the strut). Alignment settings and springs and other variables would change it fit.
Also everyone's definition of "safe" is different. I myself would want 20mm minimum clearance and your setup is probably less than that.
I would say try the wheels on and do some circles in the lot and see if you rub and then add spacers as needed.
Yea this sounds like a reasonable approach. So ...
When adding spacers should I do it in a balanced way front to back? ie, if I add 10mm up front should I do the same in the rear?
1990 Laser RS - Lights go up, lights go down ||1992 MX-6 Coupe - Hah ... no || 2001 Integra GSR - Almost rice. Risotto || 2003 IS300 - A nice car but no fun. || 2011 Stage I GTI - Lots of fun. Would buy another
2014 BRZ - That BRZ. So hot right now.
PollosHermanos is offline   Reply With Quote
Old 02-11-2016, 01:47 AM   #2989
swarb
You are just changing your track width and whatever handing properties come with it. You can do whatever you like.
Stock studs are only good for 3-5mm slip on spacers. Some say 5mm is too much. Up to you what you feel is safe. Any more you need a bolt on spacer or longer studs.
Old 02-15-2016, 09:53 AM   #2990
Frank-FRS
Drives: 2013 WhiteOut Frs
Okay, so im looking to buy a set of Avid1 AV50, preferably 18x8.5. The only offsets they offer are +30, +35. My question is, what offset would be best and what would be a good tire size without going less than 225. I will be running stock height. Thanks
Frank-FRS is offline   Reply With Quote
Old 02-15-2016, 10:15 AM   #2991
sNake89
Drives: 2012 GT86
hey guys, need some help.
I bought a set of 18x9.5 + 38 kiwamis. I am not sure what tyres to get.
I was thinking 235/40 fronts and 245/35 rears.
Would this be fine on stock suspension? Would I need coilovers ?
I have been told too many different things IRL so I am so confused right now..
Got it all sorted. Went 235/40 all round. Sits really good but pokes alittle.
sNake89 is offline   Reply With Quote
Old 02-16-2016, 05:07 AM   #2992
swarb
+35 is the better choice for stock height.
You pretty much only have three tire choices. 225/40, 235/40 or 245/35. Look up a tire size calculator and compare to stock. 225 is a slight stretch, 235 slightly too tall, 245/35 best overall choice.
Old 02-16-2016, 05:41 PM   #2993
Frank-FRS
Thanks! Now should I expect an rubbing or poke running a +35
Old 02-16-2016, 06:49 PM   #2994
Leonardo
Country Boy 4 Life
Leonardo's Avatar
http://www.ft86club.com/forums/showt...t=18980&page=3 +35 will look like like this with a 225/40 stock height. Pokes some.
Old 02-20-2016, 02:43 AM   #2995
mclovin85
mclovin85's Avatar
Drives: scion fr-s
hello! new to the forum... im pretty sure this question has already been asked but i just want to make sure... can i fit 18x9.5 +38 offset with 255/38/18 tires on them on a stock frs suspension? will i have rubbing issues or will i be good?
mclovin85 is offline   Reply With Quote
Old 02-20-2016, 12:13 PM   #2996
gkubed
gkubed's Avatar
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
I'm a complete noob to this.
This is what I believe the following setup looks like:
[ame="http://www.amazon.com/18x9-5-Enkei-Raijin-Silver-467-895-8045HS/dp/B00CZCEWFU/ref=sr_1_1?ie=UTF8&qid=1455988118&sr=8-1&keywords=enkei+raijin+hyper+silver+9.5+5x100"]18x9.5 Enkei Raijin, 45mm offset[/ame]
Michelin Pilot Super Sports 245/40ZR18/XL
Eibach Pro Kit 1" drop springs
Will it fit? Could I use spacers to get rid of the additional offset from flush?
Thanks
edit: semi-answering, still looking for more information. The 9.5" wheels won't fit with the springs, but can with coilovers.
gkubed is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
