Old 02-02-2016, 04:55 PM   #2969
TheGuyWithTheFireStorm
Drives: FireStorm MT FRS
A buddy of mine has a set of konig integrams 18x9 +45 on his forester and he is planning on getting something new soon, before I pull the trigger on those, I wanted to know if those would fit without any issues on stock suspension? I think they have 245/40/18 wheels on them. I am also planning on lowering on coils in the future as well.
Thank you in advance
TheGuyWithTheFireStorm is offline   Reply With Quote
Old 02-02-2016, 06:20 PM   #2970
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Originally Posted by Slick View Post
Yeah,no issues with the fronts.
I run 18x9 +35 on 265's with no rubbing on a 1.25" drop and -2.75 camber. You're tucked in 3mm more and a bit less tire, perfect.
Rears should be fine depending on your camber. You might need to dial some more in. Many folks are running 18x9.5 +38 and sit pretty flush but 6mm more outside and inside, plus more tire also than these guys typically run. It's gonna be tight but doable with the right specs.
Noob question. To do minor camber adjustments, do I need any additional parts or should that be adjustable based on my coilovers (Tein Flex A)?
Old 02-02-2016, 06:42 PM   #2971
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
With Tein adjustable tophats, you can alter the camber from the top. You can adjust the bottom via camber or crash bolts.
Rear is non-adjustable unless new aftermarket control arms.
Sent from my SM-N920W8 using Tapatalk
Slick is offline   Reply With Quote
The Following User Says Thank You to Slick For This Useful Post:
PandaSPUR (02-03-2016)
Old 02-02-2016, 07:02 PM   #2972
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
They should fit, albeit a little close. My friend ran 18 x 9.5 +38 on stock suspension with the same tire setup and it cleared.
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
TheGuyWithTheFireStorm (02-02-2016)
Old 02-02-2016, 07:07 PM   #2973
tyler_win_photo
Originally Posted by Jesse1292 View Post
Enkei RS05RR 18x9.5+43 all around. Will also be getting coils and lowering the car about an inch. Was wondering what tire size would be best without having any clearance issues.
I could see 245-255/35 fitting. The only thing is you might get some rub under really hard compression in the rear on the plastic tab at the top of the bumper.
Old 02-02-2016, 07:12 PM   #2974
thanks for the response! It would be so much easier to test fit.. But he just left for school
Old 02-03-2016, 12:00 AM   #2975
PandaSPUR
PandaSPUR's Avatar
Ah damn... I think I might just stick with 9.5" and smaller wheels then. Dont want to mess with all that.
Old 02-07-2016, 07:01 AM   #2976
wildpandaz
Drives: Scion Frs 2013
Should I run 18x8.5 +33 all around or put 18x9.5 +38 in the rear? Tire recommendation? Stock height for now but planning to drop maybe 3/4 inch or airlift in the future. Will I have any problems with this for now on stock height?
wildpandaz is offline   Reply With Quote
Old 02-07-2016, 01:02 PM   #2977
BRZBYE
BRZBYE's Avatar
Drives: 2014 Subaru BRZ (Limited, Black)
You can run wider than 235 easy. I ran a 255/35R18 on 18x9 +35 on ProKit. Just need the right camber and offset.
I would test fit the wheel on its own (with compression) and go from there. If you have clearance, then add crash/camber bolts to tuck it in a bit.
A 9.5" wide wheel is an ask with springs, it will be tight.
I fitted 245/35R18 on 18x9+42 for a customer a few weeks ago and they clear the strut (not the ideal offset).
Originally Posted by jshadeck View Post
Yes it will fit, my pic a few posts back shows a 9.5 +38 wheel, that pic is 235s but i later went to 255s w no issues. With an 18" wheel the tire is not what contacts the spring perch, its the lip of the wheel itself
Attachment 112052
Hey guys, sorry to dig up such an old reply, but I am looking to get a solution for my setup and eliminate the front poke by getting some more negative camber in the front. Is the only solution to go to aftermarket coilovers? Why is that? is there a difference in diameter of the springs and perch? How can I verify that whatever coils I choose will give me a better range of adjustability?
Thanks for any help!
Eric
BRZBYE is offline   Reply With Quote
Old 02-07-2016, 01:10 PM   #2978
Slick
Slick's Avatar
Eric
Any set of coilovers will gain you extra clearance on the inside, allowing you to fit wider wheels and tires with a higher offset.
Without coilovers, you need to run less camber and thus more poke to fit larger wheels.
Old 02-07-2016, 01:17 PM   #2979
Slick
Slick's Avatar
Eric
Any set of coilovers will gain you extra clearance on the inside, allowing you to fit wider wheels and tires with a higher offset #.
Old 02-07-2016, 08:23 PM   #2980
PollosHermanos
PollosHermanos's Avatar
Drives: 2014 SWP BRZ Limited 6SP
My new wheels come in this week and while it appears that they will clear the stock struts there seems to be conflicting info.
Wheels/Tires are Kosei K6R 17x9 +42 with 245/40/17 RS-3s.
Seems like some people are reporting this set-up will rub, others say it's close, others say it will definitely rub and you need spacers in the front.
These are going to be my main track tires/wheels and I'm curious if I DO need to run a 5mm spacer to clear in the front am I better running them all around or this non-nonsensical?
Not my forte, clearly. If this has been discussed before please excuse my crap searching ...
1990 Laser RS - Lights go up, lights go down ||1992 MX-6 Coupe - Hah ... no || 2001 Integra GSR - Almost rice. Risotto || 2003 IS300 - A nice car but no fun. || 2011 Stage I GTI - Lots of fun. Would buy another
2014 BRZ - That BRZ. So hot right now.
PollosHermanos is offline   Reply With Quote
Old 02-07-2016, 09:02 PM   #2981
swarb
It is hard to say as every car is slightly different. +45 (enkei rpf1 17x9) fit but they can rub at full lock(at the swaybar) or if you add ANY camber(at the strut). Alignment settings and springs and other variables would change it fit.
Also everyone's definition of "safe" is different. I myself would want 20mm minimum clearance and your setup is probably less than that.
I would say try the wheels on and do some circles in the lot and see if you rub and then add spacers as needed.
Old 02-07-2016, 11:13 PM   #2982
ChrisP
I am running 18x8.5 +33 offset at all four corners with my avid 1 av20s and I also have a 1" drop on trd springs. They are pretty much perfectly flush in the rear and the front pokes just the slightest bit.
I wouldn't go staggered unless you want more understeer.
Here are some pics:
http://www.ft86club.com/forums/showthread.php?t=101152
ChrisP is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
