Old 01-18-2015, 05:05 PM   #57
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Originally Posted by yomny View Post
Did you have to replace the tb gasket? You have any pics of it? Thanks a million bro, you've saved me a headache as its pretty tough to find info on things like that.
Nope, I didn't replace the gasket. Just take your time and be careful pulling it off, it's just those four bolts.
Unfortunately, I don't have any more detailed photos.
alexand3r is offline   Reply With Quote
Old 01-18-2015, 05:08 PM   #58
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Thats alright man, you've been plenty helpful. I was going to tackle this without removing the TB only to find out it was probably necessary then have nightmares on whether i needed to run to the dealer to grab a gasket. You saved me all that. I just got myself plenty of clamps and port caps to block off and clamp anything necessary.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 01-18-2015, 06:17 PM   #59
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Glad I could help.
I found that the hoses required different sized clamps to get a tight fit, as well. I can't remember the exact sizes, but a little trial tug on each will let you know for sure. I believe I used a stainless core zip tie (as well as the clamp) on one for peace of mind, but the Dorman clamps that I used were pretty crappy so ymmv.
Old 01-18-2015, 07:47 PM   #60
yomny
yomny's Avatar
I got a box with pretty much ever size available lol and some regular ss clamps as well as some that look like they're for fuel lines. Lol after making me go through all this trouble these suckers ain't going anywhere.
Old 08-13-2015, 11:21 AM   #61
Jhood
Jhood's Avatar
Drives: 2014 BRZ Limited [6MT/SWP]
Insane how easy these hoses come off, I had my wastegate line secured to one of these EVAP lines not realizing it pulled it right off. Just finished mine this morning, didn't have to remove anything besides the A/C though.. figured out that if you attach the corbin clamps to the hoses then you can manage to shove them back on the plastic nipple with out the use of pliers. Just some patience with it and all 5 are now snug.
|FBM Stage 1 Build|GTX2867R|
|Moto-East Flex Fuel & Dyno Tune|
|360whp / 265tq (E81 @ 12psi)|
Jhood is offline   Reply With Quote
Old 02-06-2016, 09:21 AM   #62
handsomegirl
Drives: Toyota GT86 2015 Black Aero Kit.
Yep, A/C compressor and TB need to be taken off.
EDIT: Here's a photo of how easy it is with the TB off:
i managed to clamp both sides of mine down by removing the throttle body. haha i pulled on the lines just a bit, and it slipped right off. Should of been clamped down from factory!
handsomegirl is offline   Reply With Quote
Old 02-06-2016, 06:52 PM   #63
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
The throttle body has a rubber o-ring gasket so it is reusable. No need to replace, just re-torque TB bolts to reseal.
Can we make this a sticky thread @Hachiroku?
xkalelx is offline   Reply With Quote
Old 02-06-2016, 08:18 PM   #64
stevo585
Drives: White 2014 BRZ
Should do this even at 5psi or less (ESC)?
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 02-07-2016, 02:29 PM   #65
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
It definitely could.
crazyfrenchbiker is offline   Reply With Quote
Old 02-07-2016, 06:11 PM   #66
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
you people are crazy pulling the ac compressor off and all...I literally unbolted the bracket for the evap solenoid and pulled it out and clamped the hoses. 5 minute job
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 02-08-2016, 10:25 PM   #67
stevo585
Any pics to help? I'm about to do this soon.
Old 02-09-2016, 10:44 AM   #68
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Good bless your small hands
Old 02-09-2016, 10:47 AM   #69
nickmerronesucks
Ned flanders
Feel arouns the back of the intake manifold there is a 10mm nut or bolt. Unbolt it. Then shove hand in through front and pull and itll come out. Install clamps and shove back in and try to bolt it back in
Sent from my SPH-L720T using Tapatalk
797Performance.com
Old 04-14-2016, 10:53 AM   #70
avishenoy1
avishenoy1's Avatar
Drives: 2015 FR-S Release Series 1.0
Found a few pics showing how to remove the evap solenoid assembly in the factory service manual, seems like it can be done without removing the ac compressor.
avishenoy1 is offline   Reply With Quote
DIY clamping the evap vacum ports under the manifold!! charged86 DIY (Do-It-Yourself) Guides 9 04-08-2015 06:56 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Aluminium intake manifold? Hempo Engine, Exhaust, Transmission 18 06-27-2013 01:19 PM
WTB: intake manifold carlitosway6891 Engine, Exhaust, Bolt-Ons 0 06-22-2013 02:24 PM
Custom Hello Kitty Intake Manifold Cover (seriously?) Hancha Group Cosmetic Modification (Interior/Exterior/Lighting) 6 04-01-2013 01:36 PM
