Old 02-05-2016, 03:02 PM   #1
Snyperiflex
Snyperiflex's Avatar
Drives: Scion FR-S Release Series 1.0
Car dies immediately
I just finished installing an Innovate Supercharger 210 (intercooled) kit, loaded in my base tune from Moto-East, but my car will shut off immediately after starting (doesn't even idle, engine fires and then dies).
Found out that my car fires up straight away and idles strong (steady 2k rpm) with the MAF disconnected from the airbox (OEM)
I have gotten codes
P050A - Cold Start Idle Air Control System Performance
B14A1 - Open in Solar Sensor Circuit for AC unit (common non-issue)
U0100 - Lost Communication with ECM/PCM "A"
No knocks or misfires detected
I figure the only reasons my car would be dying immediately is if I have a massive leak or I'm having an issue with tune/connections/pinched wires
If my car had a huge vacuum leak, it shouldn't be able to idle in Limp Mode right?
Anyways, Moto-East said I should take some data logs and send it to them, I have a friend coming with a boroscope to check my wires under the manifold, and I'm gonna have at my car with a vape/carb cleaner looking for leaks.
Any suggestions on what else I could do to help narrow down the culprit?
Snyperiflex is offline   Reply With Quote
Old 02-05-2016, 03:06 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I have gotten codes
Did you get a new MAP sensor? the MAP sensor scaling in the tune will effect the car.
Old 02-05-2016, 03:09 PM   #3
Snyperiflex
No, OEM map sensor
However, I used the supplied MAP sensor extension wire that was included in the kit
I will attempt to run the OEM wires to the sensor without the extension (in case the extension is bad)
Sent from my SM-N910T using Tapatalk
Old 02-05-2016, 03:12 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
No, OEM map sensor
Contact your tuner to see if the tune is for OEM MAP or aftermarket one. Other then that I would think its a electrical issue with a wire not being plugged in. If you had a vacuum leak you would hear it and RPM would hit 2k before the car limits it climbing anymore, unless its really bad maybe the tune just kills then engine at that point I have only had 1 small vacuum leak
Snyperiflex (02-05-2016)
Old 02-05-2016, 04:08 PM   #5
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
^^^ What he said ^^^ Mike has a tune for OEM MAP, but you should consider a 3bar sensor anyways.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
The Following User Says Thank You to zoth For This Useful Post:
go_a_way1 (02-08-2016)
Old 02-05-2016, 04:09 PM   #6
Snyperiflex
If I remember correctly, the 3bar sensors don't work with the innovate/sprintex kit
There has been a lot of problems running the 3bar sensor for reasons unknown
Old 02-08-2016, 03:24 PM   #7
zoth
zoth's Avatar
Ask Mike if a Honda 2.5 will work.
anywhere can i drive a BRZ home immediately ? 8987846 CANADA 6 10-04-2012 04:49 PM
Subaru BRZ Premium Satin White available immediately, Toronto. Looking for good home. jonno CANADA 1 06-18-2012 07:45 PM
