Old 01-14-2016, 08:11 PM   #15
xsl27x
Drives: 2015 Scion FRS, Firestorm
No papers came in the box. I don't believe their website explains it either.
Sent from my LG-D800 using Tapatalk
xsl27x is offline   Reply With Quote
Old 01-14-2016, 08:37 PM   #16
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
@xsl27x has the right idea if you've got a stage 2 tune from OFT or tuning with ecutek for something similiar it's best to remove the 90 degree bend for the O2 sensor bung, otherwise you'll skew values for the tune.
Old 01-14-2016, 08:38 PM   #17
X Factor
Drives: 2013 Red BRZ Limited
So what do you do with the o2 sensor
Sent from my SM-G900V using Tapatalk
X Factor is offline   Reply With Quote
Old 01-14-2016, 08:40 PM   #18
xsl27x
2 sensors go In the stock header. 2 bungs on the 1320 header. Just swap both over.
Old 01-14-2016, 08:41 PM   #19
X Factor
So forget the 90 degree fitting in just install the sensors as they are installed on the stock header is that right
Old 01-14-2016, 08:44 PM   #20
xsl27x
Yes. If you're tuned via OFT or ecutek, you don't need to worry about CEL.
Old 01-15-2016, 09:17 AM   #21
X Factor
Yeah I wasn't concerned about a CEL I was going to have a tune, just trying to figure out what to do with the actual sensors
Old 01-26-2016, 05:10 PM   #22
xsl27x
Pulled the stock header and sensors. Cleaned them up with some MAF cleaner and steel wool, light coat of anti-seize in the bungs and installed. Black in the collector, grey by the flex pipe.
Should be installed tomorrow, just need to source 2 nuts and bolts since the 1320 header doesn't have studs.
The Following User Says Thank You to xsl27x For This Useful Post:
Teseo (01-26-2016)
Old 01-26-2016, 07:25 PM   #23
X Factor
What overpipe are you using?
Old 01-26-2016, 07:32 PM   #24
xsl27x
1320 54mm to stock front pipe
Old 01-27-2016, 02:34 PM   #25
xsl27x
Got the header and overpipe in today. Just gotta find some bolts to mate them together since it doesn't have pressed in studs.
A few notes though:
I had to use the 90° fitting and extender due to space constraints. Without them, the 02 sensor was jammed against the plastic wheel well and I didn't want the sensor to get bent/damaged during normal driving when the engine shifts. I used red loctite on all the adapter joints so hopefully it doesn't rattle.
There is one header nut that is extremely inaccessible. All others can easily be torqued with an 8" extension + 14mm deep socket, no u-joint needed. To get this nut (driver side, under the runners) use a 14mm crows foot on the 8" extension. I hand tightened this as much as I could first, got all others to 22ft lbs, then came back with the crows foot.
Teseo (01-27-2016)
Old 01-27-2016, 03:07 PM   #26
xsl27x
I was able to get the OP in place even after torquing the header all the way down, without raising the engine. Just feed it up through the transmission tunnel and keep rotating towards the drivers side and it will slide into place. Just takes a little finesse and patience.
Old 01-28-2016, 02:05 PM   #27
xsl27x
Here's a quick sound clip. I think I have a slight exhaust leak. Probably at the header/op flange.
https://www.dropbox.com/s/8k5y4nz3o5...34827.mp4?dl=0
Old 02-05-2016, 01:27 PM   #28
rosol16
Not A Member
rosol16's Avatar
Drives: 2014 Mustang GT
Any rattles or anything so far? I really don't wanna spend 600+ on a header when I get OP and Header for less than 500
rosol16 is offline   Reply With Quote
1320 Performance UEL Header? Ronin Sascha Engine, Exhaust, Transmission 53 06-27-2018 06:39 AM
1320 uel header, opinions? Mr_YUzU_FRS Engine, Exhaust, Transmission 2 09-30-2015 06:00 PM
WTB: OFT, Overpipe, EL Header Doobster Want-To-Buy Requests 1 08-20-2015 01:45 PM
FS: JDL UEL Header & Overpipe rever5e Engine, Exhaust, Bolt-Ons 6 12-29-2014 07:34 PM
Header and Overpipe... Scooby South Engine, Exhaust, Transmission 17 04-06-2013 08:35 AM
