Old 02-04-2016, 03:59 PM   #1
Webster10
Drives: 2013 FRS
Weird rattling noise in cabin coming from front left
So, the noise just sounds like a tiny rattling, like something tapping around whenever I ride over any slight bumps. It almost sounds like the "arm" on one of my gauges tapping against the display glass. Or maybe it's something in the front left speaker.
It's very annoying because my FRS is my DD. Please help.
Webster10 is offline   Reply With Quote
Old 02-04-2016, 04:02 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Well you did buy a 30k sports car not a Lexus. Mine has dozen of rattles I have been working to fix. I have a similar one right now actually. I think its coming from under the dash
Old 02-04-2016, 04:04 PM   #3
It is probably two things hitting each other. That is about all I can tell you from a written description.
Would love to help and all but...
go_a_way1 (02-04-2016)
Old 02-04-2016, 04:07 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
And today's post of the day goes to tcoat lol!
Eighty 6 (02-06-2016)
Old 02-04-2016, 04:12 PM   #5
Webster10
Drives: 2013 FRS
I'll try to get a video of it later today. It might be wires under my dash tapping around on something. I believe the source is in the cabin, it's too noticeable to be coming from elsewhere. It really sounds like it's directly under the front left pillar.
Also, does anyone have any experience with an exhuast being so loud that it rattles your back windshield?
Sent from my SAMSUNG-SM-G925A using Tapatalk
The Following User Says Thank You to Webster10 For This Useful Post:
Tcoat (02-04-2016)
Old 02-04-2016, 04:53 PM   #6
I'll second that .......
Old 02-04-2016, 05:04 PM   #7
If it sounds like a gauge dial tapping on the face of the gauge, good luck capturing it on a video.
I suggest you go to an indoor pistol range and ask to test fire a .357 or .44 magnum (without using ear plugs). Then you won’t hear that noise in the dash anymore.
Is that your car that is vibrating the rear glass …… if so, prepare for more rattles.
go_a_way1 (02-04-2016), wireman957 (03-01-2016)
Old 02-04-2016, 05:12 PM   #8
Webster10
Drives: 2013 FRS
It is my exhaust but I'm unsure if it's my back glass or if it's rubbing on something underneath. I only hear the exhaust-caused rattling at 2000-2500 RPM. And yes it does seem like it would be hard to capture the noise of the gauge dial if that is what's causing the inside rattling. Any ideas on what kind of shop I could take it to to get it fixed/checked out?
Old 02-04-2016, 05:31 PM   #9
.................. Any ideas on what kind of shop I could take it to to get it fixed/checked out?
Well, I'd suggest a DIY shop.
Take a ride in the passenger seat and listen and try to isolate the sound.
Consult with the driver as to where he/she thinks it's coming from.
Pull your car into a quiet place.
Open and drink a beer, while you gather up some electrical tape, duct tape, a few pieces of sponge and a few zip ties.
Go hunting ....... tap, shake, push on, rearrange stuff till you hear the rattle.
Blast it with some of your ammunition.
Have another beer and take a nap.
Old 02-04-2016, 05:38 PM   #10
Webster10
Drives: 2013 FRS
If it is the gauge dial tapping against the glass, how would you personally go about stopping that from happening
Old 02-04-2016, 05:46 PM   #11
gravitylover
Check to see if the seat belt strap is snapped closed.
@Tcoat
Old 02-04-2016, 05:47 PM   #12
Oh, my ....... I doubt that is what is making the sound you're hearing.
However, if it was, I would start by trying to move the case of the gauge both from the front and from the rear. If that didn't work, I'd gently tap on the face of the gauge (with a screwdriver handle, covered with a microfiber rag).
Old 02-04-2016, 06:10 PM   #13
Webster10
Drives: 2013 FRS
Yeah, I get that I'm new to cars. I'm 18 so I'm learning... I'm going to attack this fucking rattle from the bottom up (taking off drivers dash panel) and try some different things till I get some results. Thanks for the suggestions team
humfrz (02-04-2016)
Old 02-04-2016, 06:33 PM   #14
Just start hitting things HARD. I am not joking nor being facetious. With small one off rattles this usually works. Even if it just stops it for a short time in narrows it down to a general location.
Weird Crinkling noise coming from center console fitcious Scion FR-S / Toyota 86 GT86 General Forum 14 03-20-2016 05:56 PM
Weird noise from the front drivers side DavidBob BRZ First-Gen (2012+) — General Topics 6 12-05-2014 12:58 AM
weird noise from front left impossible Issues | Warranty | Recalls / TSB 14 11-08-2014 12:22 AM
Metal on metal scratching noise front left wheel Ezk1el Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-11-2014 01:00 AM
What is that rattling noise near the front passenger side window? tzhu07 Scion FR-S / Toyota 86 GT86 General Forum 7 11-03-2013 08:25 PM
