Old 01-29-2016, 10:37 PM   #533
stevo585
Drives: White 2014 BRZ
So back from the track on ~e65 and ran 13.8 @ 101.
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 01-29-2016, 11:07 PM   #534
stevo585
Pics or it didnt happen...so pics . Was about 50 F and also about 40% humidity.
Old 02-03-2016, 10:08 PM   #535
stevo585
So I assume no one uses LiPo batteries? Any reason why you can't?
Only thing I can think of is maybe recharging. Its also hard to find the right voltage.What is the under and over voltage of the controller?
You could do (4) 7.2V packs. Thats 28.8 V.
Old 02-03-2016, 10:10 PM   #536
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Phantom FTS Electric Supercharger Owners Thread
Need a lipo charger for lipo batteries. The controller isn't setup for it. Plus lipo is much more sensitive to heat. And our engine bay gets fricking hot.
Is it possible?
Yeah.
Will it do better performance?
Probably because it makes a huge difference for my rc cars and planes.
Is it best for our setup?
Eh. Between cost and performance increase probably not.
Installed Mods:
Old 02-03-2016, 10:35 PM   #537
stevo585
Yeah I figured charging was the issue.
I might do a dual dump setup (4X) after a while with car audio batteries. There pretty narrow I maybe able to fit them plus the start all in front be about 15 inches. Not wanting to relocate the starter outside the engine bay.
I just want that voltage to stay more stable. Its drops to 21-22V that means there isnt enough capacity.
Old 02-04-2016, 08:03 AM   #538
WNDSRFR
Drives: FR-S,GTI
LiPo's are way too expensive. LiOn's would be the way to go. The only advantage lithium polymer has over lithium ion is weight. That's why they are used in RC airplanes and helicopters. A large enough LiPo to use with the ESC would probably cost a thousand dollars or more.
Old 02-04-2016, 08:04 AM   #539
WNDSRFR
Drives: FR-S,GTI
How about NiCad?
Old 02-04-2016, 07:38 PM   #540
stevo585
yeah it would if you still want 20 ah. But the thing is LiPo can use nearly all their capacity where a lead acid only 50% to 70%.
Might be ok with just 10ah still ~30 seconds of boost. The amp dump is way, way faster too at 30C on average. I bet the voltage would not drop much. If the boost level would go up or not is a different story...
Old 02-04-2016, 07:42 PM   #541
stevo585
How about NiCad?
Those are alot cheaper but don't dump enough amps it seems. Most are like 6C. So you would need ~40 ah. (40 x 6) = 240 amps for 4000watts.
Old 02-05-2016, 07:56 AM   #542
WNDSRFR
Drives: FR-S,GTI
The other thing about LIPO's is their tendency to burst into flame. With the constant charging and discharging they're almost guaranteed to burn your car down. Just look at the "hoverboards".
Old 02-05-2016, 08:54 AM   #543
Sojhinn
Sojhinn's Avatar
Our cars would be inspired by Ferraris!
Installed Mods:
Old 02-08-2016, 08:06 PM   #544
rdub-S
Drives: 2013 FRS
joined the club
Officially a member of the club now. Hope to get it installed this weekend.
rdub-S is offline   Reply With Quote
Old 02-08-2016, 08:07 PM   #545
Sojhinn
Sojhinn's Avatar
Let me know if you need help with anything.
Installed Mods:
Old 02-11-2016, 09:02 PM   #546
stevo585
Anyone set full activation at 50% throttle? Not sure what issues this would cause..I'm sure you could tune it right.
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
