Old 02-02-2016, 12:43 PM   #267
denso
Drives: 86
Originally Posted by RichardsFRS View Post
That car sounds awesome as hell. Except the pops which I'm not sure why you want your car to pop, but your car sounds friggen awesome
Thanks man!
Pops because I tried this "mod". Its already "deleted".
denso is offline   Reply With Quote
Old 02-02-2016, 02:41 PM   #268
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
yea i ran it for a week and switched back lol
The Following User Says Thank You to NyC Zn6 For This Useful Post:
Jonathanlim (02-02-2016)
Old 02-02-2016, 04:19 PM   #269
ort895
ort895's Avatar
Anybody ever get it to pop off throttle. Or to pop on downshifts like the f type? If we could get it to pop on downshifts ill be good to go.
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Old 02-04-2016, 12:37 PM   #270
denso
Drives: 86
no
but what will happen if you set the first value at the g/rev axis to e.g. -10?
anyone tried this? if yes Im sorry
Old 02-04-2016, 02:50 PM   #271
aagun
Drives: 86
that make all the cars impounded ><
if u interested to it i can help
aagun is offline   Reply With Quote
Old 02-04-2016, 02:53 PM   #272
aagun
Drives: 86
Originally Posted by denso View Post
no
nothings happen coz this table for moving only if ur throttle is not active or idling it switch to other map
if u set idle timing to -10 it will be loud as u cold start the car (-15)
try rich it to 11 afr with low rpm idleing and with -5 atdc ^^
Old 02-06-2016, 08:14 PM   #273
Kryptik319
Can anyone who's done this take a screenshot of the tables that need changed in their updated version? I'd greatly appreciate it.
Kryptik319 is offline   Reply With Quote
Old 02-06-2016, 08:50 PM   #274
_gt86_user
Inactive
Drives: .
Check page 12...its just Base Timing B that needs to be changed, pick a number from 0 to -15 and change the first row. Depending on your exhaust setup you may only hear pops with -15 set. Try it out but it kind of gets old after a while IMO.
_gt86_user is offline   Reply With Quote
The Following 2 Users Say Thank You to _gt86_user For This Useful Post:
FRSBRZGT86FAN (02-06-2016), NyC Zn6 (02-08-2016)
Old 02-06-2016, 08:57 PM   #275
Kryptik319
Sounds good, thanks. I'll start somewhere in the middle and go from there, it shouldn't be too hard to hear something with my setup. 1320 UEL header, Motiv op, Megan resonated fp, Private Label track pipe
Old 02-06-2016, 10:22 PM   #276
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
+1 on the fact it gets old after awhile, because you're completely catless @kryptik it's gonna be awesome for the honeymoon phase.
Old 02-07-2016, 01:58 PM   #277
Kryptik319
Brought a smile to my face the first couple times it happens. My car isn't daily driven any more so it'll be fun for a while haha.
Old 02-17-2016, 04:28 PM   #278
eddieflyinv
eddieflyinv's Avatar
Alright I have this working now with no messing around in the Base Timing B table.
I wanted to figure this out so there was no drivability issues in case you hit the 0.15 section of your base timing during normal driving.
I literally Just got this working and tested it for all of 15 minutes so it could use some fine tuning im sure, and im not 100% sure what change did it, but if others want to test and help figure out what works best for different goals that would be awesome.
You will need the fully defined Base Idle Timing (In Gear)(Above Speed Threshold), so I used the OFT Definitions Found Here provided by @Kodename47 - http://www.ft86club.com/forums/showp...&postcount=411
Helpful Links used to figure out what might work
http://www.romraider.com/forum/viewt...10488&start=60 (mostly end of page 5)
http://www.romraider.com/forum/viewt...hp?f=40&t=8411 (read the whole thing, mainly explaining the idea of overrun logic etc)
[IMG][/IMG]
Base Idle Timing (In Gear)(Above Speed Threshold): set @ -5degrees @ 1800rpm @ 176 ECT
Overrun Enrich RPM Delta Activation: set @ -17
Overrun Initial Injector Enrichment: 2.8ms (only set so high to stand out while logging)
Overrun Fueling RPM Resume Threshold: set @ 3500rpm from 176ECT - 230ECT
Overrun Fueling Cut Counter RPM Threshold: Didnt touch it at all (yet..)
This worked extremely well, when off throttle and going to coasting, after a short delay I would get a pop or 2,
between shifts after a short delay I would get a pop or 2 depending on rpm as well,
after decelling a bit, On tip in (rolling back onto throttle) I would get a shit load of pops if I held the throttle at a sweet spot (barely touching it), so almost exactly what the other method did, or If i just got back on throttle quicker it would be just a short tip in pop
most noticeable effect so far is when using heel toe downshift in the lower rpm ranges (2500-3000), the repeated popping and burbling as you drop gears is pretty freaking amazing.
still working on exactly what is causing this to better tune the effect, but I imagine it has alot to do with the base timing idle modifications made, going to play with it a bit more and see what changes to the initial enrichment does.
this was all tested with a stock header (but catless FP and invidia N1), so I am curious to see how the catless guys get on with this,
eddieflyinv is offline   Reply With Quote
Old 02-17-2016, 08:47 PM   #279
ZHoward
ZHoward's Avatar
Drives: 2013 brz limited
stg2
well i open stg 2 file and there are no 176 option and no overrun option....
[IMG][/IMG]
ZHoward is offline   Reply With Quote
Old 02-17-2016, 09:27 PM   #280
_gt86_user
Inactive
Drives: .
You need the fully defined tables for them to show up. You can check for the definitions, I've seen someone on NASOIC that was able to get the pops off throttle without feathering but I never ended up doing the changes, it was basically the same thing that was done here supposedly you only need to change base timing while in gear.
The Following User Says Thank You to _gt86_user For This Useful Post:
ZHoward (02-17-2016)
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 04:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 05:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 07:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-17-2014 11:07 PM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 02:12 PM
