Old 01-31-2016, 01:55 PM   #1
JD001
JD001's Avatar
Drives: Subaru BRZ
Oil Change Made Easy..
Unsure whether you guys seen the following. Interesting idea should see service charges falling.
http://www.castrol.com/en_gb/united-...ge-nexcel.html
The Following User Says Thank You to JD001 For This Useful Post:
humfrz (01-31-2016)
Old 01-31-2016, 02:25 PM   #2
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
1:28 on the video - Hot Lava getting the cell treatment. Neat.
Kestrel is offline   Reply With Quote
Old 01-31-2016, 02:45 PM   #3
chamourian
chamourian's Avatar
Drives: White Aozora BRZ
thats pretty cool! Only downside would be then you have to recycle those boxes instead of just disposing of the oil properly. In theory it would be nice to just buy a new box, return the old box and be done with it, but im sure some people would just throw the boxes away like they aren't supposed to do with the oil
chamourian is offline   Reply With Quote
Old 01-31-2016, 03:01 PM   #4
JD001
JD001's Avatar
Drives: Subaru BRZ
The cartridge unit could work if an exchange system is in place where owners can get new for old.
Old 01-31-2016, 03:05 PM   #5
DANG! ........ then, I may go back to changing my own oil ...........
Then again, ......... I have this bad shoulder .......
Old 01-31-2016, 03:12 PM   #6
JD001
JD001's Avatar
Drives: Subaru BRZ
I have heard that crawling under the car to undo the sump plug can bring on a case of bad shoulder
Old 01-31-2016, 04:17 PM   #7
......... ........... at my age and condition, crawling under a car to do anything can bring on all kinds of pains ......
JD001 (01-31-2016)
Old 01-31-2016, 05:02 PM   #8
ryoma
ryoma's Avatar
looks pretty neat. however, I expect oil changes to cost around $200 now with that system lol
Old 01-31-2016, 05:14 PM   #9
JD001
JD001's Avatar
Drives: Subaru BRZ
It'll give them more time to do the non essentials like topping up the screen wash when it's already full!
Old 01-31-2016, 05:41 PM   #10
gravitylover
Hmm, pull up to auto parts store, open hood, pull cartridge, go inside and exchange for new cartridge with oil of choice and filter with proper flow rates etc., go outside and drop it in, close hood, start 'er up and leave. Sounds good to me. Clean, quick, simple and don't need to deal with recycling of old oil because store and manufacturer take care of it.
Old 02-01-2016, 04:02 AM   #11
Nessal
Drives: Exige, Miata, Ghia
The problem posed with this type of system is if the vehicle burns oil, there is no way to add any back in because the cartridges are sealed. The only solution I see is that they will still have to offer a oil fill...and if they do...they also have to offer a drain plug incase you over fill.
Nessal is offline   Reply With Quote
Old 02-01-2016, 01:55 PM   #12
twag4
Drives: frs
I don't understand this for our cars. This is the easiest car to change oil on that I have ever owned. I have owned 27 different cars and 23 motorcycles. This is the easiest. This seems an unnecessary expense. Even in an apartment parking lot this is easy. Just my opinion.
twag4 is offline   Reply With Quote
Old 02-01-2016, 02:01 PM   #13
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Old news for me. My dad works for Castrol lol! This is something that is going to be build into new cars in like 2020 or whenever they get around to it. It will be something more so for high end BWM, Audi and the likes. It is highly unlikely that you will be able to retro fit this system into a car.
JD001 (02-01-2016)
Old 02-01-2016, 02:09 PM   #14
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
looks to me like we just reinvented the wheel, just because we could.
I can see race applications or something I suppose, but for normal street stuff-it just seems like a larger expense.
EZCarLift Easy car lift portable super easy car lift bren5279 Mechanical Maintenance and Tools 16 09-11-2015 02:57 PM
Deposit made,Should I change Asphalt to Halo White ? xtral Scion FR-S / Toyota 86 GT86 General Forum 45 06-12-2015 03:12 AM
Oil Change Interval Change (Subaru recommended) Flow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 09-10-2014 08:27 PM
Easy Oil Change kuhlka DIY (Do-It-Yourself) Guides 12 06-16-2014 02:39 PM
