Old 01-30-2016, 12:45 PM   #15
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
Originally Posted by tracerit View Post
Does it say it in the title though? An Ace header/4-2-1 competitor would be awesome.
Agreed!
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
Old 01-30-2016, 12:52 PM   #16
Who8myrice
Drives: Ap2
I am downloading new ots file right now. Does e85 tune comes with lc and Ffs already enabled ? Last file had lc on stage2 but on e85stage2 was missing it.
Who8myrice is offline   Reply With Quote
Old 01-30-2016, 02:04 PM   #17
raven1231
Think that might have been the goal. Just easier to reuse and modify they restart altogether
Cole (01-30-2016)
Old 01-30-2016, 02:05 PM   #18
Who8myrice
Drives: Ap2
After new tune, my engine light came on, uo155. I restarted the car but light stays on, my oft says there is no engine light. Should I disconnect the battery ?
Nvm fixed !!
Old 01-30-2016, 02:14 PM   #19
Cole
Not a troll
Cole's Avatar
If I was in the market, this would be my first choice
Cole is offline   Reply With Quote
The Following User Says Thank You to Cole For This Useful Post:
Shiv@Openflash (01-30-2016)
Old 01-30-2016, 02:20 PM   #20
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
What sort of gains do you expect ofh2 have over ofh? Worth upgrading?
cameronjones239 is offline   Reply With Quote
Old 01-30-2016, 02:35 PM   #21
brzzy
@anthonysestito
brzzy's Avatar
@Shiv@Openflash is there going to be any update to the site to purchase the OFH3 with the OFT as a combo like you previously had with the OFT + OFH (original) package?
Don't see it currently on the site but I am on a mobile device if that makes a difference (it shouldn't)
IG: @ANTHONYSESTITO
Old 01-30-2016, 03:50 PM   #22
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Yep! I just updated the website to add OFT/OFH2 and OFT/OFH3 combo packages
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
brzzy (01-30-2016)
Old 01-30-2016, 03:52 PM   #23
Shiv@Openflash
Drives: 2013 FRS
Minimal gains I'd say. Maybe 1-2whp and close to the typical run to run variance on a dyno. It's definitely an evolutionary upgrade, not revolutionary The OFH3 sees a couple who more since it replaces the slightly restrictive (bent and pinched) over-pipe.
TouchMyHonda (03-11-2016)
Old 01-30-2016, 03:53 PM   #24
Shiv@Openflash
Drives: 2013 FRS
Nvm fixed !!
Looks like you fixed it. For others, the U0155 code is a communication code that is triggered by disconnecting any OBD2 device (like the OFT) while it is still communicating (data logging, data viewing, etc,.) with the OFT. No big deal at all. It will clear after a couple of ignition cycles.
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
Kronos (04-07-2016), Mad1723 (04-16-2016), Who8myrice (01-30-2016)
Old 01-30-2016, 03:56 PM   #25
Shiv@Openflash
Drives: 2013 FRS
We experimented with a 4-2-1 design early in the process. But for performance and packaging reasons, it didn't make the cut. Nothing wrong with it but was just not what we were looking for.
tracerit (01-30-2016)
Old 01-30-2016, 04:52 PM   #26
steve99
Drives: FT86
Hey @Shiv@Openflash notced on new site two Open flash managers
1.24.0 & 1.28.0 assume its best to use 1.28.0
also no more template files not needed and more ? and no Windows8 patch not needed ?
Thanks
Steve
Old 01-30-2016, 05:32 PM   #27
Shiv@Openflash
Drives: 2013 FRS
Thanks
Steve
Don't mistake Flash Tablet Manager with OpenFlash Tablet Manager. They are two different applications. Flash Tablet manager is for a restricted version of the (Flash Tablet) that was only sold for a short period of time for Ducati motorcycle.
I will be putting Template files up like last time. I'll put the windows 8 patch up as well (although I don't think it is needed any longer).
steve99 (01-30-2016)
Old 01-31-2016, 01:37 AM   #28
ganz954
ganz954's Avatar
Drives: Subaru BRZ MT WR Blue
What size is the header exit & over pipe diameter?
Did I miss specs anywhere?
ganz954 is offline   Reply With Quote
OFT350 (SBD/ZAGE) on E85 Dyno results Shiv@Openflash Forced Induction 19 02-05-2016 12:00 PM
Australian Dyno Dyno Results Shiv@Openflash Software Tuning 11 07-22-2015 04:57 AM
86 Dyno results Anban AFRICA 18 01-14-2014 06:54 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
TRD cat back, any dyno results MTCRX Engine, Exhaust, Transmission 4 11-26-2012 06:26 PM
