Old 01-26-2016, 03:03 AM   #15
Davegixxer
Davegixxer's Avatar
Drives: 2016 Subaru BRZ
Originally Posted by Sherb View Post
How does the viper alarm or other alarms work with a Brz limited keyless entry?
Yes they do. With an ADS ALCA from idatalink you car will not know the difference between being started normally and being remote started
Davegixxer is offline   Reply With Quote
The Following User Says Thank You to Davegixxer For This Useful Post:
JeremyR (03-17-2017)
Old 01-28-2016, 06:14 PM   #16
Sherb
Drives: Brz
I remember reading that the keyless entry will set off the alarm too is that been fixed also?
Sherb is offline   Reply With Quote
Old 01-28-2016, 08:16 PM   #17
Davegixxer
Davegixxer's Avatar
The idatalink ALCA module does factory alarm integration. When you hit lock on the aftermarket remote, it is locking the doors, arming the aftermarket alarm, and arming the factory alarm. When you hit unlock (or pull use the door button if hooked up d2d) it will unlock the doors, disarm the aftermarket alarm, and disarm the factory alarm. When you remote start it, the ALCA simply sends a signal to the BCM saying "hey, go ahead and disarm the factory alarm but leave the doors locked" and the car is dumb enough to listen.
In short, the factory alarm does disarm correctly on the PTS cars, and, the regular key cars don't have a factory alarm unless dealer added.
Old 03-10-2017, 05:32 PM   #18
kevroq
Drives: 15' Dark Mettallic Gray BRZ Manual
I just installed by viper 5806 alarm/remote start with ADS ALCA bypass module. Not a hard install (professional car audio/security certified installer for over 10 years). These would be my tips.
A. The under dash is very limited space wise, plan where you are going to put things like the brain, bypass, extras.
B. Directechs lists keysense as required for remote start, but if using the ALCA it will do keysense for you and 2 keysense inputs confuses the car.
C. The ALCA will do tach signal for remote start, but, as our cars do the stupid Toyota style high idle when started cold, after the idle drops the remote start will think the car stalled even though it is just idling low. You need to go to the tach signal on the top pass side of the motor for a good tach signal.
D. The firmware for the ALCA as of 1/25/16 has some errors with the neutral safety and the parking brake output. Need to hardware this for reliability.
I can do a full write up soon.
My car is regular key manual trans. Auto trans is easier because you don't have to worry about the tach issues.
Push to start are actually easier too because the whole install is behind the glovebox and does most of it via data. Waaaaay less wires in PTS.
ever do that write up? Have a 2015 brz (manual/pts) and tired of setting the alarm off with pke
kevroq is offline   Reply With Quote
The Following User Says Thank You to kevroq For This Useful Post:
brzzy (03-10-2017)
Old 01-29-2018, 08:26 PM   #19
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Any full update on this install? My car got totaled and I'm removing my old viper system next monday. I had the shop installed it last time but this time I want to install it on my 18 BRZ
turtlefeeder is offline   Reply With Quote
Old 02-01-2018, 08:19 PM   #20
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I'm down for a diy also! I was considering installing the 5906.
kmbkk is offline   Reply With Quote
Viper 5706v Alarm/Remote Start anishb Member's Car Journals 8 01-31-2017 06:10 PM
Shop to install Viper alarm/start? l0aded Southern California 0 05-04-2014 06:57 PM
Anyone do a Viper alarm by themselves yet? hansthegerman Electronics | Audio | NAV | Infotainment 40 02-01-2014 03:31 PM
BRZ/FRS vs Viper TIE Pilot FR-S / BRZ vs.... 43 11-04-2012 08:23 PM
