Old 01-27-2016, 07:48 PM   #15
Originally Posted by roddy View Post
I stand by my original statement...the stock primacy tires are NOT directional. They do have an inside and outside for tire mounting purposes, but once mounted on the rim, it doesn't matter which corner of the car the wheel is placed on.
For rear wheel drive vehicles (non-directional and not staggered), I cross the front two to the opposite rear, then the rears straight up on the same side. I rotate mine at every oil change. When I have the front jacked up for the oil change, I swap the 2 front tires side-for-side while the oil is draining, then when I am done the oil change, it is a simple front to rear exchange to finish the tire rotation...works for me.
Again, I would put the newer tire on the right rear to start, then rotate as normal at your next oil change. It sounds like there is a 1400 mile difference between the original tires and the new one...that's not likely enough to make any difference. I wouldn't sweat it.
The stocks aren't, but loads of guys with aftermarket tires on here need to make sure they do not follow the stock rotation pattern.
Old 01-27-2016, 08:25 PM   #16
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
Originally Posted by PandaSPUR View Post
2015 BRZ manual.
Interesting that it differs between the twins (or MYs?)
mdm is offline   Reply With Quote
Old 01-27-2016, 09:17 PM   #17
roddy
roddy's Avatar
Drives: '13 Ultramarine
Absolutely...agree 100%. That's why I added the non-directional and not staggered part.
I was responding to @PandaSPUR saying the Primacy tires were directional. I should have quoted...
Old 01-27-2016, 09:19 PM   #18
I screwed that up once with directional. The results were more interesting than I would have guessed.
Old 01-27-2016, 09:26 PM   #19
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
My bad, I just looked up a pic of the threads and assumed they were directional since they werent symmetrical.
Old 01-27-2016, 09:30 PM   #20
roddy
roddy's Avatar
No worries...I just wanted you to know they are not directional, so you don't have to worry about swapping sides when doing a rotation.
Old 01-28-2016, 06:48 AM   #21
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Panda
Sorry about confusing you, I did not know stock tires weren't directional. You can flip and flop however to get the best wear in that case.
What the hell is a primacy tire anyway?
RichardsFRS is offline   Reply With Quote
Old 01-28-2016, 08:45 AM   #22
Originally Posted by RichardsFRS View Post
Panda
The stock tire on most (not all for some reason). It is also what people call the "Prius" tire since it is used on the top speced Prius. They don't call it the "Lexus" tire even tough it is also used on them though.
Old 01-28-2016, 10:53 AM   #23
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
My Dad's ES350 actually has the all-season version, in exactly the same size as my FR-S.
JohnJuan is offline   Reply With Quote
Old 01-28-2016, 08:40 PM   #24
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
With just one tire... I would say don't rotate them. O.O just measure with tire gauge & put on according to thickness. Thicker one goes back thinner one goes up front.
Edge Insight CS Monitor (1996 & Newer OBDII Enabled Vehicle) FBPARTS Exterior Parts - The Rest 3 12-02-2015 04:08 PM
Looking to move to a newer tool box Concorazon Off-Topic Lounge [WARNING: NO POLITICS] 15 11-01-2015 09:53 AM
How to use newer revisions of OFT maps? ie 700I to A01I derka-derka Software Tuning 3 09-05-2015 08:21 AM
Rotating Directional Tires for track and autocross RMP Tracking / Autocross / HPDE / Drifting 7 12-03-2014 12:26 PM
Rotating Tires/Wheels ap5512 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-15-2014 01:38 AM
