Old 12-02-2014, 02:37 AM   #1
RMP
Drives: 1992 Isuzu PuP, 2014 FR-S
Rotating Directional Tires for track and autocross
Would rotating directional tires like my RS-3's during autocross events lead to decreased performance in dry conditions? In other words, is the orientation of directional tires only important for wet grip.
I was thinking that I could just rotate tires at the event to even out wear and then rotate back before I leave.
RMP is offline   Reply With Quote
Old 12-02-2014, 04:36 AM   #2
For RS3, it doesn't matter. For some slicks, it does.
RMP (12-02-2014)
Old 12-02-2014, 09:10 AM   #3
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
Rotating them side-to-side doesn't get you much though. The outside edge of the left-side tire is still on the outside edge when you put it on the right side in backwards rotation.
Moving front to back could help (if you are not staggered like I am) because the outer edge of the rears tend to take less of a beating than the fronts. But the directionality of the tire is still in place, so I don't think that is what you were after.
bimmer635csi is offline   Reply With Quote
The Following User Says Thank You to bimmer635csi For This Useful Post:
RMP (12-02-2014)
Old 12-02-2014, 11:38 AM   #4
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
My advice would be to rotate front to back until the tires reach around the mid-point of their lifetime, then flip them on the wheel and run them on the other side, rotating front to back as needed.
raul is offline   Reply With Quote
Old 12-02-2014, 11:45 AM   #5
renfield90
The Stig's German cousin
+1. This is what I do with my Rivals.
Old 12-02-2014, 12:37 PM   #6
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
It is fine to run them in "reverse" in the dry.
Sleepless is offline   Reply With Quote
Old 12-03-2014, 02:15 AM   #7
troek
troek's Avatar
Drives: 2012 Toyota 86
arnt rivals asymetrical? +1 on rotating symetrical tires like others have said.
Old 12-03-2014, 01:26 PM   #8
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Very rarely does the carcass care. The 'tread' is directional, the tire isn't. (in most cases)
And yes, directional tires DOT tires are such for wet grip.
PRO86 | WTCC | STL
Spring Rates - Track / Autocross Dave-ROR Tracking / Autocross / HPDE / Drifting 83 05-16-2023 05:56 PM
Rotating Tires/Wheels ap5512 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-15-2014 02:38 AM
Wide tires for autocross Oneqwkfrs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 09-10-2014 09:22 PM
Anything fun/autocross/track day going on Sunday? skills NY / NJ / CT / PA 0 07-25-2014 05:42 PM
Pedal Dance Imperative for Autocross/Track Black Tire Tracking / Autocross / HPDE / Drifting 5 04-22-2013 12:37 PM
