#519 |
Drives: Scion FR-S A/T, Whiteout
To my understanding, Knock Correction Advance Max A is the amount of timing the ECU is allowed to pull in response to knock for a given load/RPM cell. Setting it to zero may actually prevent the ECU from responding to knock at all, even though the events are still occurring. Remember, the parameters that we log, FBKC and FLKC, aren't the knock events themselves; they're the ECU's response to what it thinks is a knock event (FLKC is a bit different, but the logic still applies). Just because you don't see those parameters logged anymore doesn't necessarily mean knock isn't still occurring.
Said another way, the total ignition timing is the sum of Knock Correction Advance Max A and Base Timing A/B (B is what's normally used; I think A is for limp-home or post-start, not sure which). There are probably some other compensations applied as well. You can achieve the same effect you're going for by rescaling the load axis on Base Timing B and removing timing from there. Since it looks like you're pulling 6 degrees total, I'd go ahead and pull 3 from Base Timing B and 3 from Knock Correction Advance Max A in the affected cells. That way, you still have some headroom in Knock Correction Advance Max A for the ECU to pull timing in response to knock. It may actually reveal that it's still knocking in that range. |
#520 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
OK, someone had to do it!
Here is my prototype rescaled Base Timing B table. It goes up to 4.0 Engine Load because I've logged up to 3.82 Engine Load. Now timing can be pulled from wherever knock is coming from. Load columns 1.4 through 4.0 are all the same, so far. That is where I'll be making most of my changes. I'm also trying a rescaled BTB table with a smoother transition. That's the 2nd pic.
If I say yes, will that make you think I understand?
#521 |
BTB table Update
Here's my current Base Timing B table compared to the table, above, that I started with. You can see how much timing I've pulled from it so far. It's quite a lot. More than I expected anyway.
#522 |
Drives: White 2014 BRZ
The load only goes to 1.7 or so. No need to go past 2.0. I have 1.3, 1.4, 1.5, 1.6, etc on my Ecutek tune for better resolution. I suggest this.
JDL Turbo kit - Ecutek, HRI tuned.
#523 |
No
I have pulled timing because of engine knock that only occurs above 2.0 Engine Load. Look at my post above. I've logged up to 3.82 Engine Load, so I rescaled to 4.0. Both BTB, and KCA tables should be rescaled up to 4.0, so the ECU can compensate accordingly.
#524 |
Well I'm pretty sure it's maf voltage I'm referring to. Maybe I'm wrong not sure. Anyways a reputable tuner told me the Fa20 does not like high load deltas. As in they will knock badly. Be careful.
Either way your resolution is terrible maybe your limited by Rom Raider idk.
#525 |
On another topic what kind of pcv and catch can systems do you guys run. Right now I have nothing...
#526 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
I'm running the mishimoto catch can. As for the check valve.... I can't remember the company and it wasn't cheap for a check valve. Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
| The Following User Says Thank You to Sojhinn For This Useful Post: | stevo585 (01-25-2016) |
#527 |
KNOCKLESS
Here are my latest rescaled KCA and BTB tables. Knockless, so far, so they probably need more timing advance.
#528 |
Drives: 2015 BRZ
My ESC for sale: http://www.ft86club.com/forums/showthread.php?t=100623
#529 |
I'm able to run 22.x degrees at redline, 28 through the midrange with afr around 11.8 if that helps. On 93 octane. This was my knock wall.
#530 |
Can you post a pic of your BTB table?
#531 |
Time Traveller
#532 |
If I could data log I would. When I do eventually get my own ecutek cable I will.
| Jackson Racing Supercharger Owners Thread | enivid | Forced Induction | 6041 | 11-28-2025 08:08 AM |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 06:42 PM |
| Kraftwerks Supercharger Owners Thread | projek_01 | Forced Induction | 4310 | 04-07-2025 01:12 PM |
| phantom supercharger restrictions? | Shinigunz | Forced Induction | 12 | 05-13-2014 03:28 AM |
| Drift-Office : Phantom Supercharger - Tuned! | Drift-Office | Forced Induction | 67 | 10-25-2013 09:51 AM |
