Old 01-24-2016, 01:17 AM   #15
Jonathanlim
Drives: 15' Frs
Yes they have a flex fuel kit. But that's for ecutek.
Jonathanlim is offline   Reply With Quote
Old 01-24-2016, 01:25 AM   #16
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
Ahhh...
wise345 is offline   Reply With Quote
Old 01-24-2016, 05:12 AM   #17
steve99
Drives: FT86
Originally Posted by wise345 View Post
My supra runs E85 and i just didn't know if the FA20 needed a flex fuel kit for some reason. Thanks guys!! I'll pick up an OFT soon!
on a boosted car it much more sensitive to ethanol percentage and octane rating, so you rearly need the flex fuel sensor to adjust fueling timing boost ect very quicky g.
on a naturally aspirated car you have a much wider tolerance to work with so anything from about e50 to e90 is ok if you give the ecu a few miles to learn fuel trims
so if your sensible you can get away without the full flex fuel system.
obviously you will need to reflash to go back to petrol
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Teseo (01-24-2016), wise345 (01-24-2016)
Old 01-24-2016, 01:36 PM   #18
wise345
wise345's Avatar
Cool thanks for the info!
Buying an FRS hello86 Scion FR-S / Toyota 86 GT86 General Forum 3 03-26-2014 04:53 PM
If you are buying a BRZ how old are you? blackmist27 BRZ First-Gen (2012+) — General Topics 205 03-07-2013 08:18 PM
With all these CEL/idle, chirp issues, should I postpone buying? Iixii Issues | Warranty | Recalls / TSB 31 10-11-2012 04:18 PM
Help with buying a BRZ in NJ/NY ft86Fan NY / NJ / CT / PA 6 07-01-2012 06:19 PM
Why I am buying a BRZ BMWDAD BRZ First-Gen (2012+) — General Topics 37 01-01-2012 09:01 PM
